Question about Sharp EL-520WBBK Calculator
How calculate modulus using - Sharp EL-520WBBK Calculator
Calculate inverse of mod function of 3-1 (mod26)
The calculator does not have a utility to perform Modulo calculations.
Jan 16, 2014 | Sharp EL-520WBBK Calculator
Mod operation in fx-83gt plus
Like many other Casio calculators, the fx-83GT Plus doesn't provide the modulus function. You have to do it the hard way.
To calculate 19 MOD 10 (which is 9, not 10 as you state in your question), first divide 19 by 10 and note the integer portion of the result (in this case, 1). Then subtract from 19 the product of 10 and the result of the first step. The result of the subtraction is the modulus. 19 - (1*10) = 9.
May 10, 2013 | Office Equipment & Supplies
How can I calculate 121 mod 187 using fx-570ms?There is no mod button in my calculator.please help :)
Divide 121 by 187. Subtract the integer portion (in this case, 0). Multiply by 187.
The lack of a modulus function is a serious flaw in that generation of Casio calculators.
Feb 26, 2013 | Office Equipment & Supplies
How to calculate modulus of function using fx-9750GII ?
To enter the MOD( function on the command line:
  1. Press Menu
  2. Press 1 or select icon Run>Mat.
  3. In Run>Mat screen, press the OPTN key.
  4. Press F6> to pan through the other options.
  5. Select F4:Num and press F6:> to get other tabs
  6. Press F4:MOD
Example: MOD(278,9)=8
An alternative way is to use the Catalog.
  1. Press [Shift][4] (catalog)
  2. Press [ALPHA][7] to jump to letter M
  3. Scroll down from there to reach the MOD( command.
Jul 11, 2012 | Casio FX-9750GPlus Calculator
CASIO fx-115ES I need to calculate and fnd a modulus remainder.I need to divide the number 352 by the number 91 and find the remainder. I need to use the modulus operator. Can this calculator perform...
Actually, the answer is 79.
The fx-115ES does not have a key for the modulus operation. Nor does it have an integer-part or fractional-part operation. However, it is possible to calculate the remainder using integer arithmetic.
Press MODE 4 to shift into integer mode. Then type in 3 5 2 - 9 1 * ( 3 5 2 / 9 1 ) = and see the answer 79. It's a pain as both numbers have to be entered twice, but it does get the job done.
To get back to working with real numbers again, press MODE 1 ( or MODE 2 for complex).
Feb 26, 2011 | Casio FX-115ES Scientific Calculator
How 2 find mod value in casio fx-991ms
there is one button ab/c beneath CALC... if u want to calculate 7 mod 4 then... u should press 7 then ab/c 4 and equal to
u get 1,3,4 and ans is center number... result=3..
Jan 16, 2011 | Casio FX991MS Scientific Calculator
This calculator does not support the modulus operation directly, you have to simulate by a divide followed by a subtraction and a multiplication. Suppose you want to calculate 256 mod 17:
  1. Key in 256 [÷] 17 [=] and get the result 15,0588...
  2. Note the 15 in front of the decimal separator and key in [−] 15 [=]
  3. Get the modulus: [×] 17 [=], result should be 1.
Jan 14, 2011 | Casio FX82MS Scientific Calculator
How to calculate mod or modulus
This calculator does not support this operation directly, you have to simulate by a divide followed by a subtraction and a multiplication. Suppose you want to calculate 256 mod 17:
  3. Get the modulus: [×] 17 [=] and get the modulus, 1.
Jan 12, 2011 | Casio FX991MS Scientific Calculator
Sharp EL-520WBBK Calculator Logo
21 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
