Question about Toshiba 65H82 65" Rear Projection Television
Line are off 65h82 tv
Yes I have the same problem, although I did call toshiba and the guy said to me that it sounds like the projectors came off the track. he gave me this number where you can order the service manuel 1800 321 6993. I also wanna get this issue fixed. I hope this helps you and me!
  • 10,594 Answers
Thanks for Toshiba service phone number.
Posted on Jun 18, 2009
Toshiba 65h82 has sound but no picture, what are likely causes?
Most likely you have a high voltage failure. This TV has 3 CRTs that are driven by high voltage. If one tube fails it shuts them all down. If the HV circuit has failed it may be time for a new TV
Feb 17, 2015 | Toshiba Televison & Video
No picture no sound
One of the most common problem with current TV's is heat. Since they tend to get hot, one of the things that goes out a ton is the fuse or power supply. Depending on the TV and the Manufacturer this can be an easy fix, sometimes you don't even have to solder if it's the power board. I bet if your TV does nothing that's the case. Check around online by your make/model and you'll get a pretty good idea of how easy it is to fix.
I found a Parts purchase list online, but you'd have to know the part number for the ones that are broken.
http://www.searspartsdirect.com/partsdirect/part-model/Toshiba-Parts/Television-Parts/Model-65H82/1100/0333200/50021150/00001
Good luck! Hope this helps and don't forget to rate.
Gtaplytmpt
Jul 22, 2011 | Toshiba 65H82 65" Rear Projection...
Can hear sound but all you see is lines on the tv cant see picture
your blub probably burned out. you'll need to get it replaced.
May 02, 2011 | Toshiba 65H82 65" Rear Projection...
I have a Toshiba 65H82 television with the wavy line problem. I have read the solutions on this site. It talks about the "hyper board." The list of boards in the service manual does not list a...
Hyper board is located under metal shield mounted on signal board in tv, buy repair kit from HERE and replace capacitors in hyper board to solve wavy picture problem in Toshiba 65H82
Thanks.
Mar 29, 2011 | Televison & Video
I have a toshiba 65H82 tv i need to move to my new house. can i lay it down or does it have to be upright?
Move it upright best for the tv.These tvs have chemicals in it three CRT tubes colors guns.
Sep 08, 2010 | Toshiba 65H82 65" Rear Projection...
Toshiba 65H82 Projection TV; location of Convergence resistors
The caps will bleed off within a few minutes of being unplugged. I don't know which caps and resistors he was telling you about but here goes.
Typically along with the convergence IC's the output resistors under the heat sink are at least checked with a multimeter. They are large resistors and should match their color code markings. The caps are probably the caps in the hyper module (hyper board)
Here is a very good tutorial to do this repair or get it done: http://www.dshosu.com/how-to-fix-toshiba-rear-projection-hdtv-wavy-lines/
May 25, 2009 | Toshiba 65H82 65" Rear Projection...
Toshiba 65H82 65" Rear Projection Television Logo
179 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
