Question about Danby DFF261BSLDB
Will not cool but freezes
Unit freezer works but does not cool
Dh25 the cooling coils get frozen,the appliance sill working even the canister is full.
The normal operating temperature is above 65 F. Much below unless specially designed for low temperature they will freeze up.
They have a frost detector and will defrost but it is very inefficient and not practical. My experience they eventually form a block of ice on the coils. They heat the room in the process so in a moderate area they can raise the temperature and provide needed circulation.
In the past where the temperature is cool I have faced the output into a corner, raised it off the floor and once the unit got started the heat created from the unit kept the air warm enough to avoid freezing up the coils.
Always check for recalls. Some models have had problems and have been recalled. See the link below.
Gree Reannounces Dehumidifier Recall Due to Serious Fire and Burn Hazards...
Hope this has helped?
Jan 13, 2016 | DeLonghi Dehumidifiers
Refrigerator won't cool below 18c.
Makes no sense to me as this refrigerator only has one compressor/evaporator. The freezer should also cool the refrigerator section. Try defrosting the freezer - perhaps ice has somehow blocked any airflow to the refrigerator section.
Apr 08, 2015 | Danby DFF261BSLDB
How to remove filter on ahd50
if this model doesnt have the removable filter on the middle right side then the filter is not removable by std means and unit will need to be dissasembled for this , Now there are a few reasons for unit to freeze , and yes your right one of them is a dirty air filter . and if its gone too far then a dirty condenser coil as well , also if unit is over three years old then it's possible that due to overheating some of the gas chanrge has gotten out , reducing it's efficency making it run longer with no cool down and freezes up , also if your asking it to remove more water than its designed for (setting to high) it will freeze up as well , std moisture for a home is 70 %rh purchase a small meter to measure this ,(some units have one built in) see how much water you really have ?
Nov 03, 2014 | Haier Dehumidifiers
My freezer wont freeze
if it is a chest freezer you have compressor running and no cool you have a freon leak if you have a amp meter check one wire from comp se amp draw if below 1.5 freon missing you have a leak
Nov 14, 2013 | Danby DCF700W1
The top of the unit has alot of condensation on it. so i am wondering if its freezing up inside. Have set point at 55% what can i do to fix the issue
A little condensation is not something to worry about. But, a lot can be caused by a dirty or clogged air intake filter. Which can also cause the cooling coils to freeze.
Turn the unit OFF & unplug it, before removing the filter for cleaning.
Also, maintain 12" to 18' of clear air space all around the unit.
If the unit is in an extremely moist or damp environment, 55% is not really a low setting. 35% would be more appropriate for this type of environment.
Hope this helps you to troubleshoot and solve the problem. Thanks for choosing FixYa.
Sep 23, 2011 | LG LHD459EL Dehumidifier
My dehumidifier freezes up and never gets the humidity to the setting I have established. Do you think it is worth repairing??
If your dehumidifier is freezing up then that probably means it is actually working well. The humidity level in the room is probably just relatively low and you probably have the unit turned up too high for the conditions.
Try turning down the setting on the unit so that it cycles on and off every few hours and does not run continuously.
Also try using some warm soapy water to clean off any dust or oily residue from the cooling coils in the rear of the unit.
The ambient temperature in the room may also be a bit too low, so you can try adding some heat to the room. Since warm air rises, you can even try lifting the unit higher up off the cold floor onto a bench or table where it is warmer.
I don't believe you need a new dehumidifier. Just try a few of the simple tips above and see if it works any better and stops freezing up.
Hope that was helpful, thank you and good luck.
Joe.
May 24, 2011 | LG LHD459EL Dehumidifier
My coils are freezing up
Make sure the filter is clean and plenty of air comes through, when coils freeze it is usually caused by low air flow coupled with lots of humidity and low air temperature in the space to be cooled. Clean the filter, fan and gently brush all dust and debris from the intake of the cold coil and retry it. If the basement is already cool and you are trying to dehimidify you should use a dehumidifier that features defrost controls.
May 26, 2010 | Whirlpool AD50USS Dehumidifier
Unit freezes up and does not defrost
Sounds like the unit may be dirty or the fan is not moving enough air. Most Dehumidifiers do not have a defrost cycle. Air is drawn over the evaporator where moisture condenses and drops out, the air then passes over the condenser where it is reheated. The cool air helps cool the high side lowering system pressures and improving efficiencies. If the filters etc are clean and all the ducts and shrouds are in place and it still freezes you probably have a bad fan motor or possible a small refrigerant leak.
Good Luck,
Gilshultz
Dec 01, 2009 | Whirlpool Dehumidifiers
Ice on dehumidifier
A dehumidifier works by cooling the metal pipes on the back of the unit to create condensation (water vapor in the air). This then drips into the collector bucket. If the unit runs too long the cooling tubes can get too cold and freeze the condesing water vapor. Unplug the dehumidifier and let the ice melt, when u turn it back on, turn it down, it may be up too high. If you find this solution helpful please rate it.
Thanks - Tech101
May 20, 2008 | LG DH404E Dehumidifier
Danby DFF261BSLDB Logo
27 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
