Question about Toshiba E-studio 281c Copier
Toshiba e-studio 281c
Scanner
chad7houston
  • 62 Answers
SOURCE: Toshiba studio 281C problems
You should be able to print on both, but I wouldn't advise it at all. The envelopes are going to jam a LOT and you WILL eventualy get a label stuck inside the machine. Possible....yes. But I don't recommend it. :)
C
Posted on Oct 07, 2008
Bubbabear64
  • 2794 Answers
SOURCE: wrong count
You find that answer out on copytechnet.com. There are authorized Toshiba reps available on there to answer your question.
I don't work on Toshiba unfortunately. If I did I would give you the answer.
Posted on Jan 29, 2009
  • 643 Answers
SOURCE: wrong count
FYI, if copy 1 side of A4, then is count as 1. If both sides, count as 2.
If copy 1 side of A3, then is count as 2. If both sides, count as 4.
That's the default settings on the MFP.
If u want to be copy 1 side of A3 and count as 1, u need to adjust the setting mode.
Press 08 and ON MFP, Enter 346, change "1" to "0".
Posted on Feb 13, 2009
goodgold
  • 389 Answers
SOURCE: Scanner
Begin with installing the driver device, check the conflicts in computer, check the cords, work with computer, bad таботают such device with long USB cord.See in panels of computer management comsumed facility of the scanner, see the tests, this has an ensemble of the decisions, arouse all do anew. Good luck!
Posted on Sep 14, 2009
  • 29 Answers
SOURCE: network initializing message for Toshiba
This is normal each do you turn on the copier for 1 until 5 minutes, next to this time do you have firmware problem.
Do you have a nice day
Posted on Mar 22, 2011
Check the color toner cartridge error message appears. I have changed all the color cartridges. Still same problem. Toshiba e- studio 281c
If changed new toner still showing replace toner cartridge, then probably the toner not able to go inside developer or the developer material is worn out.
Mar 12, 2015 | Toshiba E-studio 281c Copier
Can I join a Toshiba 281c to a home group network?
It can be worked with a desktop pc having windows 7 straightly configured to 281c and if the device is shared. Then u can access the desktop pc and browse 281c and send prints. Better to start with as a simple peer to peer connection use TCP/IP and observe that it can be accessed via Internet browser, If the copier utility page appear alright that means ur connected. Good Luck!!
Feb 22, 2015 | Toshiba E-studio 281c Copier
How do i check the ink/toner levels of Toshiba Studio 281c Printer/Copier
You will need the official software from the toshiba support site install it and it will show you toner levels
Jan 23, 2015 | Toshiba E-studio 281c Copier
How do I check Ink/Toner levels on Toshiba e-Studio 281c
Windows driver
my Toshiba studio 281c printer operates normally while running on windows xp through my LAN. When I try to print on it while running on windows 7, it will not respond, it does appear in the printer list?
Nov 08, 2013 | Toshiba E-studio 281c Copier
Replace heater lamp toshiba 281c
open side cover remove fuser kit and replace heat roll OR heat lamp
Nov 24, 2012 | Toshiba E-studio 281c Copier
My toshiba e studio 281c will not print in colour it will only copy in colour
Your print driver is probably set to monochrome. Usually there are to drivers set up on your computer: a pcl5 for black/white, and a ps3 for color--or vice-versa. Right click your driver; you can change the setting in your preference or properties section.
Oct 16, 2012 | Toshiba E-studio 281c Copier
Toshiba e-Studio 281C ADF not working
Make sure the ADF connector is plugged...
Feb 24, 2012 | Toshiba E-studio 281c Copier
Toshiba E-studio 281c Copier Logo
22 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
