Question about Danby DWC283BLS Wine Cooler
Fan making noise every few seconds on Danby wine cooler
5 Suggested Answers
  • 90 Answers
SOURCE: Danby Wine Cooler Chatter
The compressor has rubber grommets that isolate/insolate it from metal on metal. What is happening is that one of these has worn through and now when the compressor kick in or out it shake which is normal but gives you that metal on metal clanking which is not normal. Look at the back and see where the compressor is held inplace by pins you will see rubber donuts/grommets. One or more are wore out. You can probably find some on a unit at a salvage yard on a small fridge and you may be able to buy some an appliance supply warehouse....
Posted on Feb 16, 2008
SOURCE: danby wine cooler repair
I am having a problem with my wine cooler also.I found the upper evap fan not running.So i opened up the control board and plugged the fan that was not working into one of the other 2 sockets,and the fan worked.so i have a circuit board problem.If you go online to sears parts and repair.put in your model# and search,it will bring up a diagram of most of the parts available.And no it doesnt have to be a GE product.
Posted on Jul 08, 2008
SOURCE: wine cooler noise
I wrote up a blog entry for a minor modification we made to our Danby wine refrigerator to silence noise from the upper fan:
http://www.adrianmccarthy.com/blog/?p=79
You can find quieter versions of the fan with the same specs at big computer parts stores (for the PC builders who want quiet computers). The one we got cost less than $20. We also added rubber spacers so that the fan vibration isn't amplified by back panel of the fridge (which otherwise acts like a soundboard). Made a huge difference.
Even with the fix, though, I wouldn't ever recommend the Danby models. Their noisy, and we've had multiple breakdowns in five years. The only authorized repair shop in our area has lousy customer service and high prices.
Posted on Sep 29, 2008
  • 15 Answers
SOURCE: My Danby wine cooler makes
check the fan near the motor or inside it this kind of wine cooler always have fan problem
Posted on Sep 11, 2010
Danby wine fridge making noise
If I checked out the right video it sounds like a fan motor. After a fan motor heats up and with age the fan will leak a little oil, the oil will become to thin and not cote the bearings well enough. It sounds like the fan trying to start back up after stoping. I would track down the fan motor and replace it.
Apr 09, 2014 | Danby DWC283BLS Wine Cooler
My wine cooler works well but it make noise while running, I suspect could be compressor, What should I do?
There is not compressor it a cooler not a fridge... The noise is most likely fans 2 of them one inside and one under the rear cover. remove the bad one take to R Shack ... computer fans are about the same size.
Dec 17, 2011 | Danby DWC283BLS Wine Cooler
My Danby wine cooler fan is making a horrendous noise - it sounds like it's trying to start up and then it gives up. I hav tried tightening the housing screws but this works for a couple of minutes and...
Where is the noise coming from? Check the fan at the back of the upper compartment. They seem to be defective and die after about 3 years (just outside of warranty... how convenient). I'm dealing with the same issue now. (As search on the internet indicates that we're not alone!) When its making that noise, try pressing the back plate around the little fan and see if it changes the noise.
Apr 11, 2011 | Danby DWC283BLS Wine Cooler
Our wine cooler is making a loud noise. We
i got the same model,the noise from the lower back,u can remove the fan out & determine the noise from easy,the bottom have two bolts,easy to remove it.gd luck for u
Jul 02, 2010 | Danby Silhouette DWC512BL Wine Cooler
Noisy Wine Fridge
The problem is likely with one of the two fans. A new fan is available from Danby (1-800-263-2629). My noisy fan is the condensor fan located at the bottom rear of the device. After removing the cooler from under the cabinet, the source of the noise was obvious. You will need to tell them whether it is the upper fan or lower fan. Leave the cooler upright for a few hours before you plug it in so that you do not damage the condenser. Price for the fan from Danby is $20.15 including shipping. Users Manual is available at http://www.danby.com/manuals/DWC512BL.pdf -Ron
Dec 15, 2008 | Danby DWC283BLS Wine Cooler
WINE COOLER NOISE
when the fan comes on so does the compressor,hold the fan with a rag and see which one is making the noise-mike
Nov 11, 2008 | Danby Silhouette DWC512BL Wine Cooler
Wine cooler noise
Had same problem. cooling fan was going out.Replaced fan about a year ago and now it is going out again. Am ordering another fan now
Mar 25, 2008 | Danby DWC513BLS Wine Cooler
Wine cooler noise
Dec 30, 2007 | Danby Silhouette DWC512BL Wine Cooler
Danby DWC283BLS Wine Cooler Logo
62 people viewed this question
Top Danby Furniture Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Dennis Boxerman
Are you a Danby Furniture Expert? Answer questions, earn points and help others
