Question about Samsung 710V 17" LCD Monitor
710vt samsung no display. What component can i replace on boardard
All checked. must be component failure
What is the deffintion for expository text
Expository means that some information is being explained in a logical way.
This is different from a narrative text which tells a story.
Dec 16, 2014 | Samsung SyncMaster 710VT TFT LCD Monitor
Hi, I have a samsung syncmaster 710vt, the touch screen one. but the problem is that i have lost my driver CD for the touch screen, so i can't use it in my new computer. Can you please help me, or...
http://www.samsung.com/ca/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=201&prd_mdl_cd=GY17HSSB&prd_mdl_name=710VT&srchword=710vt
Aug 08, 2011 | Computers & Internet
My LCD syncmaster 2243swx screen display only 4 seconds and Black screen. When I touch Source the small box show digital / analog and 4 second display and black screen again.
It could be a power supply in the pc died and then it probably took out the video card. It could be spike in power source took out the PC or components.
The morel hear is prove it. What have you done to confirm it is the monitor have you connected a monitor that works to it like a old one that a friend has does not use it. As it stands not enough data to tell what the problem is.
You could be like a friend of mine He unplugged his PC from the box from the electric outlet to protect it from the thunderstorm and left the modem plugged in and the lighting came through and destroyed the whole system so he had to have a new box built which meant a new motherboard CPU memory hard drive DVD/CD drive power supply.
I just had the thought you could be talking about a TV and a cable company black box in which cause it could be you need to take the remote and change the input.
Jul 05, 2011 | Samsung SyncMaster 710VT TFT LCD Monitor
Just need a remote for my system
I have the samsung AV-R720 receiver But I do not have the remote. Is there a way that I can obtain another one?
May 17, 2010 | Samsung SyncMaster 710VT TFT LCD Monitor
When heated up my Samsung SM 710v goes blank
Could be a lot of things. Fortunately, there is a relatively easy way to figure one of these problems out, but it involves taking the unit apart enough to access the electronic components, which I have never done with a Samsung, so you will have to get some other help to figure that out. Once you can get to the electronics, you turn the set on and wait until it goes blank...then you spray "cool spray" on the various components, one at a time, until the set comes back on. Voila, you found the heat sensitive part, so now you have to replace it. That will be another fun experience, but if you can get that part replaced, chances are you set will work fine.
Another scenario is more complicated, since some part may be drawing too much current, and a shut-down circuit is being triggered. A schematic and knowledge of electronics is needed in this case. Get an estimate before you get it repaired by a shop. Sometimes you're better off buying a new one, unless you can fix it yourself. You could try a low noise fan, blowing on the back of the tv, as an afterthought...might get you by for awhile.
Mar 27, 2010 | Samsung SyncMaster 710VT TFT LCD Monitor
No power replaced fuse ,str and resistor 10w3.3ohm
The components you have replaced fixed a short in the circuit which caused the fuse to blow. A different component is still causing problems. The components you replaced may have failed in a different way so as not to blow the fuse or you are close to fixing the problem. It could be a high voltage component failure or worse a picture tube failure.
Nov 25, 2008 | Samsung Televison & Video
LCD Display Failure
Found this information for a Samsung unit with the same internal components experiencing the same problems. http://www.fixya.com/support/t194959-display_sound. I know this drove me nuts so hopefully it will help others.
Dec 22, 2007 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
My Pc does not want to connect to TV card any more
1 it is due to card not matchig with monitor. 2 whan you install new hardware you will have to change the setting please check it.
Oct 05, 2007 | Samsung SyncMaster 710VT TFT LCD Monitor
How to reset factory settings of samsung sync master710v
Disconnect de power Cord behind the monitor for about 10 minutes. Then reconnect again. If the problem persist you can call the Samsung and talk about your problem. I had the same problem they swap my monitor, because was a fault (if your monitor still in the warranty.
Mar 30, 2007 | Samsung SyncMaster 710VT TFT LCD Monitor
Samsung 710V 17" LCD Monitor Logo
20 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
