Question about Refrigerators
Estate refrigerator model TT21AKXKQ02 not cooling
3 Suggested Answers
  • 57 Answers
SOURCE: refrigerator cooling to 59 degrees in non freezer compartment
If the fan is running you more than likely have a defrost problem.
Look at the back wall of the freezer section if it is frosted up. it's not defrosting. This keeps the air from circulating through the refrigerator section.
Posted on May 21, 2008
david04928
  • 102 Answers
SOURCE: refrigerator not cooling. freezer works fine.
Try taking the front cover off at the bottom and or the back of the fridge and try vaccuuming underneath.  Make sure you unplug in when you do this.  Then plug it back in and see if that solved the problem.  You have fins and coils underneath that if they get really dirty the fridge will not work properly.  Hope this helps
Posted on Mar 10, 2009
The freezer works properly, but refrig part does not cool to proper temperature. Have checked doors and cleaned behind.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 07, 2011 | Estate Refrigerators
Where is the freezer drain line; it is frozen and dripping into the bottom
It is inder the floor of the freezer...
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 25, 2011 | Estate TT21AKXKQ / TT21AKXKT Top Freezer...
Puddles of water collect on the top shelf on a daily basis
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
Feb 14, 2011 | Estate TT16TKXKQ Top Freezer Refrigerator
Refrigerator bottom will not cool but the top freezer works just fine.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 08, 2010 | Estate TT14DKXKQ Top Freezer Refrigerator
My freezer and refrig stop cooling. Both went at
You have a bad overload / relay on the compressor and incorrect model number so I cannot give you the part number you need .
May 29, 2010 | Estate TS25AFXK Side by Side Refrigerator
Refrigerator side warm freezer side cold
heatman101
Dec 26, 2009 | Estate TS25AFXK Side by Side Refrigerator
Bottom of fridge not cooling
The fresh food compartment is cooled by air being blown from the freezer compartment into the fresh food compartment. Something is restricting that air flow which causes your fresh food compartment to stay warm.
There is a panel, or door if you will, that separates the freezer and fresh food compartments. The freezer temp control determines how much cold air is allowed to escape into the fresh food compartment by opening or closing this panel.
If the panel is restricted from moving (stuck closed, for example), the freezer will get VERY cold while the fresh food compartment will be warm.
Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is restricting air flow from the freezer to the fresh food compartment. It's a free fix and may solve your problem altogether.
If that doesn't help, or helps only temporarily, you may have a problem with panel itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require the help of a service technician
Hope this was helpful. Good Luck.
Aug 29, 2009 | Estate Model: TT16DKXSQ Top Freezer...
Refrigerator not cooling. freezer works fine.
Mar 10, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Refrigerator cooling to 59 degrees in non freezer compartment
May 21, 2008 | Estate Refrigerators
Refrigerators Logo
15 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
