Question about Fluke Networks 52801009 test set,ts52 pro w/ abn
Ts 52 dead replaced battery still dead - Fluke Networks 52801009 test set,ts52 pro w/ abn
    Master:
  • 683 Answers
Not repairable, if under warranty send back for replacement or buy a new one
Posted on Feb 01, 2015
How to replace a lamp on my jvc tv
If you haave the original manual, this is discussed at the start of page 91. If you dont have manual, it can be obtained at books.jvc.com
1. Purchase lamp TS-CL110UAA
2. Turn Off and unplugg set
3. Remove lamp cover located on the left side of TV
4. Remove and replace lamp
5. Reset lamp counter in menu for accurate hour information.
Jul 26, 2014 | JVC HD-52G786 52" Rear Projection HDTV
Tip
Hi, I would like some help reg, the T-Mobile MDA charging. I got 2 batteries, 1...
Your battery has been depleted past a chargable state.  This is a due to a bad design in the phone that doesn't monitor the battery power state well enough.  It actually allows the battery to be taken under the minimum amount needed to recharge the battery.
You can fix this, but do so at your own risk.
You can simply purchase a new battery, that will work, just been sure not to let it deplete the battery totally anymore.
Now, on to the fix
-Take out the battery.
-Get any usb cable you can find sitting around. (any usb wire will do, an old printer cable, anything with a usb end that can plug into your computer)
-cut one end of the plug off. You need to leave the side on that connects to your computer. Cut off the side that plugs into a device (printer, camera, web cam, etc)
-Strip the rubber off the wire and expose the wires inside.
-Separate the wires from each other. You will only be using the BLACK and RED wires.
-strip the very end of the black and red wires carefully using a wire cutter exposing the metal wire inside the red and black covering.
-Plug in your home made battery charger to your computer. Careful not to touch any exposed metal, as it will give you a small shock.
****WARNING****
DO NOT UNDER ANY CIRCUMSTANCES ALLOW THE RED AND BLACK WIRE TO TOUCH EACH OTHER
****WARNING****
-now carefully hold the black wire to the negative terminal on the battery (it should be noted with a black circle with a - in the middle). Then touch the red wire to the positive terminal (it will be noted with a red circle with a + in the middle).
Hold the 2 wires there for 20 seconds. Then quickly plug the battery back into the phone, and then plug it into a regular charger. Give it little bit of time, if you've done everything correctly the charge light should come on.
I had to repeat the last step again to get the light to turn on indicating it was charging.
You must not hold the wires to the battery for too long, 20 seconds should do it. You can overload a battery with this trick and actually make it explode if you hold it there too long. You are well within the few minutes needed to detonate the battery due to overcharging by sticking very strictly to 20 seconds.
Just be careful and you'll be fine.
One you get a charge light give it a few minutes in the off position, then try powering up the device and keep it plugged in until you get 100% charge.
Good luck,
Peter
on Jan 08, 2008 | T-Mobile MDA
Black spots on philips tv
Sounds like your light engine may be dirty or just faulty. You might try taking a dry rag and cleaning the lens on the light engine. If you decide to replace it or send it someplace for repair the part number is TS-COP9A-SAA
May 31, 2014 | JVC HD-52G886 52" Rear Projection HDTV
How do I get my dyna low rider to recognize the fob. I can turn of alarm with ts switches but can't use fobs. have new batteries
You need to take the fobs and the bike to your dealership and have them matched together with Digital Technician.
Aug 22, 2012 | 2008 Harley Davidson FXDL Dyna Low Rider
Message on tv said to replace lamp soon. Is this dagerous? I leave the tv on for the dogs during the day.
No its not dangerous, eventually the set will not power up any more and the lamp will need replacement. Having a replacement lamp ready is the best bet it only takes about 3 minutes to replace the lamp. Your model uses the TS-CL110UAA. Whcih is available with the housing from www.tvrepairworld.com they also include installation instructions.
Aug 23, 2011 | JVC HD-52G786 52" Rear Projection HDTV
I have a 52" projection tv went blank the other night came back on and now is showing a double picture
Tv have a problems known as a convergence problems,it dead.The tv convergence board.The 2 STK convergence ICS and some or all the resistors are dead.These parts are dead,must replaced to solved the covergence problems.The shop will cost u $300-350 for parts and labors.
Jul 17, 2010 | RCA D52W136D 52 in. TV/DVD Combo
Fan remote not responding
Hello :
I recommend you to replace the battery . The battery could be dead .
rate please !
Apr 20, 2010 | Hampton Bay AC414-LRU 52'' Kemper...
Tractor engine clicks but will not start need a solution
hopefull your battery is just dead a new battery should fix that problem you can try charge the battery may be okay depending on how long it has sat without bein used.... otehrwise it mat be your starter solinoid it ts the block with 2 poles on it that your positive battery cable goes to, it will most likely be a dead battery tho...
Regards
Brad:)
Sep 21, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mitsubishi Projection TV Model TS 4573 not TS 4545
No if the problem is the screen, you will need to replace the entire screen assembly. some screens come in two parts. The inside of the screen is called the freznal lens, the outside of the screen is called the lenticular lens. Good Luck
Jun 05, 2007 | Mitsubishi TS-4545 45" Rear Projection...
Fluke Networks 52801009 test set,ts52 pro w/ abn Logo
41 people viewed this question
Top Fluke Networks Electrical Supplies Experts
ken skalski
Gene Haynes
Are you a Fluke Networks Electrical Supply Expert? Answer questions, earn points and help others
