Question about Coffee Makers & Espresso Machines
How to clean vent tubes on keurig - Coffee Makers & Espresso Machines
Recently mu Keurig started acting funny. When I first turn it on, instead of heating up, it just starts to fill my cup. Can't seem to get the "menu" up either! HELP
I watched a U Tube video, a 10 year explained how to clean the Keurig so it would work. Now all you have to do is go to Bed Bath & Beyond. Buy Clean Cup. It cost $7.99 It is a K-Cup put the pod in your Keurig run twice. Take the Clean Cup pod out, run twice with just water. Take a new thin paper clean to clean your needle.
When you close the lid so you make coffee. Surprise Open the top their is needle that becomes impacted with coffee grounds. Throw away the paper clip run a cup water and look at all the mess come out.
Sep 07, 2017 | Keurig Coffee Makers & Espresso Machines
My Keurig only brews a part cup
Most likely you need to change the filter and descale it as well.
I use a CleanCup once a month:
https://www.amazon.com/CleanCup-Single-Machine-Cleaning-Capsules/dp/B00E0QAS34/ref=sr_1_1?ie=UTF8&qid=1480095410&sr=8-1&keywords=keurig+cleaner+cup
I change the filter once every 3 months:
http://www.keurig.com/Accessories/6-Pack-Keurig%C2%AE-Water-Filter-Cartridge-Refills/p/Water-Filter-Cartridges
And I descale it every time I change the filter using this:
http://www.keurig.com/Accessories/Keurig%C2%AE-Descaling-Solution/p/Keurig-Descaling-Solution
Otherwise, the tubing is going to get clogged up in your machine and produce smaller and smaller cups of coffee, not to mention, when you keep your machine clean, your coffee will always taste its best!
Hope this helps!
Nov 25, 2016 | Keurig Coffee Makers & Espresso Machines
Is it true about mold in keurig coffee makers
Any place that heat and liquid can get trapped, mold can occur. This is why descaling is important for traditional coffee makers and even for tea pots. Basically, keep your stuff clean.
Biofilm Slime Bacteria inside the inner tubes of the Keurig Coffee maker
Sep 30, 2014 | Keurig B70 Coffee Maker
Keurig Vue V700 not filling cup
You are experiencing a clog of the upper tube. Not outside but inside the tube. Use a paperclip, open an end force it up the tube to clear the deposits and your in business. Remember to do a Full cleaning now and again with vinegar solution. Keep Filter changes at least every 4 to 6 weeks.
Jan 18, 2014 | Keurig Vue V700 Brewing System - 110774
Keurig machine not pumping water.
Tube from Filter area clogged. Clean that first.
Jan 27, 2013 | Keurig B70 Platinum Brewer
My gaughter put milk in my keurig machine
Not good, all tubes are clogged and need cleaning. Call Factory for instructions.
Nov 02, 2012 | Keurig B60 Coffee Maker
Water pump only draws a bit of water and then the hot water recycles through the vent tube into the reservor. I h ave descaled twice but no luck.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Apr 10, 2011 | Keurig B60 Coffee Maker
I have a Keurig B66, the reservoir water gets heated but then comes back into the water reservoir from the top vent tube. The water coming back into the reservoir is very hot; almost no water goes into the...
Sorry to read about your problem, I hope this helps you out.
you can contact Keurig at 1-866-901-2739 or Keurig.com
You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
ds
sdf
s
fs
f
Dec 22, 2010 | Keurig B60 Coffee Maker
My Keurig will not brew. It says it is brewing and only a about a teaspon comes out. I've already done the paper clip cleaning method. The water eventually comes out of the vent.
the keurig is broken it probably says De-Scale its useless you can try all the vinegar and all the poking i know a site that sells them for cheap!!!!
iLikeNew it has tons of keurig parts
Nov 12, 2010 | Keurig Platinum B70 Coffee Maker
Coffee Makers & Espresso Machines Logo
15 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
