Question about Pride Go-Go Ultra X 3-Wheel Travel Scooter
Scooter goes then studder stops - Pride Go-Go Ultra X 3-Wheel Travel Scooter
What causes my 1993 Nissan altima to studder or idle rough at red light or stopped
-It could be miss fire,bad coil, air leak, injector or spark plug and plug wire. It's hard to tell at this moment.
-First able you needed to check all above to determine which part is bad.
Good luck
Mai
Aug 13, 2014 | 1993 Nissan Altima
My 97 bonneville studders and stops running when engine gets hot 190-200 degrees
Hello. It seems either your water temperature sender is malfunctioning or your ignition module is overheating.
Apr 01, 2014 | 1997 Pontiac Bonneville
Scooter acts like brake are on stops, goes, stops, goes ect.
it could be the free leaver is slipping on or dose the scooter look lopsided from the back if it is could be the axle i had that problem with mine stopped and started and was the axle an expensive repair but was worth it,or battries could be done,
Oct 16, 2012 | Zoom 220 HMV 3-Wheel Travel Scooter
My 1999 4x4 4.3L blazer studders in gear after warm a few mins on city streets and highway, it comes and goes? i have done complete tune up and fuel filter and fuel pump. it studdered less i think af
Check owners manual or manually check to see if there is another fuel filter. Sometimes vehicles have more than one fuel filters which are overlooked until they have problems with them. Most have a filter right along the frame.
Aug 23, 2012 | Chevrolet Cars & Trucks
My 97 Legacy started to studder when stepping on the gas from a dead stop. It does not seem to studder at higher speeds. Do you thing the Fuel filter may need to be changed?
May 10, 2010 | 1997 Subaru Legacy
My jeep studders like it is starving for fuel
It could possibly be your TPS or throttle position sensor. It plugs into the side of the throttle body and tells the injectors how much fuel to squirt. If the voltage source to the sensor is incorrect it may cause the jeep to idle rough.
Sep 21, 2009 | 1994 Jeep Grand Cherokee
When driving car goes studders have to gas more
change plugs (make sure gap is right), plug wires, coil (if applicable) make sure you are using good fuel i rec'''d conoco gas...
if you had work recently done then i would also trace it back to that.
Jul 14, 2009 | 1997 Jeep Cherokee
Pride Go-Go Ultra X 3-Wheel Travel Scooter Logo
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
