Question about Brother IntelliFax-2820 Laser Fax
Black streaks on the faxes coming in - only occasionally.
    President:
  • 3,085 Answers
On top of the toner / drum cartridge you shoul see a sliding blue tab. Move it back and forth 10 times/
Posted on Jun 19, 2009
My brother MFC 8500 is receiving alright but everything I send out has a big black streak going down the right side of the page. Confirmation page also has big black streak.
Let me see if I got this right.
The received fax is clean but when you send one out it has a black streak on it.
Cool! So far so good.
Makes sense because for sending, the fax scans the original document and parts of the scanning area could be dirty and so on. Therefore a black streak may appear.
The same black streak would also appear when you make a copy, because the original document must also be scanned.
Logical!
However for receiving faxes, the machine uses the internal memory and the print engine only, and the same applies to printing the transaction report, which comes from inside via the print engine.
The scanner has no rol in either situation.
Now I'm lost!
May 31, 2011 | Brother Office Equipment & Supplies
Streaks of black ink down the pages of faxes
Hello.
It might be as simple as changing the ink. If still a problem, the FAX may need cleaning.
Hope this helps.
Apr 02, 2010 | Brother IntelliFAX 4100 Laser Fax
Wide black streak
Yes, you have a burned out scanner block element. It's cheaper to buy a new fax machine
Mar 30, 2010 | Brother BRTPPF4750E...
Faxed documents come out with black streaks on them
Clean the corona wire on your drum unit. It should be a blue tab on the top of the cartridge that you can slide from side to side. Make sure that the blue tab returns to the starting position (there should be an arrow on the tab that will match up with an arrow on the drum unit). If this doesn't work, replacing the drum unit should fix it. Drum units are only meant to last ~4 toner section replacements.
Dec 12, 2009 | Brother IntelliFax-2820 Laser Fax
Papers come out with black streeks on them from my sharp FO 4450
If everything is coming out with streaks, it's most likely your cleaning blade which is part of the drum cartridge. I've also seen this from 3rd party toner. Get Sharp toner for your Sharp fax if you don't have it already. If your black streaks are only on copies and sent faxes, this indicates that your scanner is dirty. It's located where you feed your paper in. Lift this part up and you'll see a strip of glass running front to back about 1/2 inch wide. Clean it and that will get rid of lines.
Oct 12, 2009 | Sharp FO-4400 Fax
Copier, Printer black streaks on copy or all black page
Hello sir; Either drum cleaning blade or drum cartridge needto replace.
Aug 20, 2009 | Brother Office Equipment & Supplies
Thick black streaks on pages coming through the fax
remove the toner cartridge and you should be able to see the matching black streaks on it, if it is the problem .....don't bother trying to clean it , it is supposed to be self cleaning and you can't improve this look...replace
Mar 03, 2009 | Brother IntelliFAX 4100 Laser Fax
The fax streaks
Open the lower part of the number panel by pulling up 1 inch. and clean the small scanner glass.....hard to see.
Mar 02, 2009 | Panasonic Panafax UF-790 Plain Paper Laser...
Blank Streaks
streaks are caused either by the toner, drum, lamp or fuser.
If you make a copy and it does not show a streak then it was done by the person sending the fax. BUT, check this,
open door and take out toner cartridge. look for a thin glass that is on the bottom of the machine and wipe it. Toner spills will cause a black streak.
Nov 15, 2007 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
89 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
