Question about Bosch Garden
Ake 40 bosch chain saw
Won t turn smoothly
SOURCE: Chain Saw, Stihl Model 011, cutting off
I've been messin with my poulan 2150 that was doing the same thing. Good, fresh gas, good spark,etc. I noticed whenever I loosened the fuel cap it would literally spray gas out! alas, I removed the muiffler assy and the darn thing fired up the first pull! I've got the muffler parts soaking in gas right now and I'm sure this the problem. It just makes sense especially if you use the same 'mixed fuel' can for weed eater, blower,etc. Check your's out, it could very well be your problem too! GOOD LUCK
Posted on Apr 29, 2009
  • 120 Answers
SOURCE: The chain has come off my bosch ake 40-19e
first loosen the bolts that hold the bar in place. then find then loosen the adjustment screw. Once it is loose, the chain will go back on the bar. Then tighten the chain so there is only about 1/8" movement. (You will want to tighten the bolt so they are snug, when you are tighting the chain) Once that is complete re-tighten the bolts completely.
Posted on Jun 20, 2009
  • 832 Answers
SOURCE: Bosch Chain Saw D 70745 - fuses checked but will
The lever could be in a safety position. Unlock the safety lever to get it in contact with the switch., and squeeze to run.
Posted on Oct 22, 2009
Testimonial: "Thankyou, but would be helpful on how to release the safety lever"
dontbother10
  • 2220 Answers
SOURCE: I need a chain for my ake 40-19 S chain saw. What
I tried a Google search for "Bosch ake 40-19 S chain" and found many on-line outlets. If you take your chain (they need it to use as a pattern) to a local saw shop or a good hardware they can probably fabricate one in a few minutes and you will save the shipping and handling costs.
Chain installation (bottom) may be helpful:
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 14, 2010
  • 5603 Answers
SOURCE: my bosch ake 35s isn't cutting, what's wrong with
Chain has dulled. Needs sharpening.
Hitting one little imbedded rock in the wood and the chain can be dulled to the point it only burns the wood.
Replace the chain or have it sharpened.
Posted on Apr 12, 2010
Does the chain AKE 40/19 fit chainsaw AKE 40/17
no it's gonna be two inches longer . you might be able to change chain and bar between saws ? i never done that might work , but would be down on power with larger bar 4 sure , but still would cut wood , just dont enter it in any races
Mar 01, 2015 | Bosch Garden
I have a replacement chain for a electric 40cm Bosch chain saw but it can't get the new one on as the chain tensioner will not go back far enough does it ever get blocked and should I take the cover off...
Take the cover off, Take the bar off. Clean it out. Put the chain around the sprocket. Put the bar on. Put the chain around the bar. Tighten the chain a bit. Put the cover on. Tighten the chain.
Feb 22, 2015 | Bosch Saw Chain for AKE 40 / 40-17 / 40-18...
Whats the difference Bosch 1.1 mm chain for AKE 40 / AKE 40-17S / AKE 40-18S / AKE 40-19S Chainsaws
None that I can find. All are .375" low profile, 57 drive links, Gauge of .043". I have only seen .375" (3/8") LP with semi chisel style cutters.
Feb 12, 2015 | Bosch Garden
TIGHTEN THE CHAIN
Are you loosing the bar at the same time if yes then lift the bar up and then tighten the chain and then the bar there are some helpful video's on utube
Jul 24, 2014 | Bosch Chainsaw Chain Saw Blade Ake 35...
Ake 40 18s chain keeps coming off when in use
The only time I saw this was when the saw was run with the chain too loose. The chain should be snug al the way around the bar. If it is run loose for too long the chain will develop burs on the driver links. Now the driver link will not fit in the groove on the bar so the chain is tossed off. Replace with a new chain
Aug 31, 2013 | Bosch AKE 40-19 S Electric Chainsaw
Can I fit a 1.3 mm bar and chain to my Bosch AK40-19s chainsaw
as long as the pitch of the chain is the same as the nose wheel of the bar, then the gauge does not matter as you are fitting a bar and chain with 1.3 gauge.
Dec 27, 2012 | Bosch Ake Pro 1.3 mm Chainsaw Sharpening...
Bosch ake 40 will not cut properly
I do not mean this as an insult but since I have seen it before I have to ask if you put the chain on backwards?
Other then that I know that if you hit dirt, even with a new chain, it will dull it quicker then anything else.
Aug 23, 2012 | Bosch AKE 40-19 S Electric Chainsaw
I need a chain for my ake 40-19 S chain saw. What is the part number? or where can I find it.
Lou
Mar 14, 2010 | Bosch Garden
The chain has come off my bosch ake 40-19e chainsaw, how do I get this back on?
Jun 08, 2009 | Bosch Garden
Garden Logo
26 people viewed this question
Top Bosch Garden Experts
roeb
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Bosch Garden Expert? Answer questions, earn points and help others
