Question about HEWLETT-PACKARD Elitebook 8460P
5 beeps powers on 5 beeps then stops. Repeats.
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 44 Answers
Hi this sounds like a memory/ram issue you need to power of your machine, remove the power cable & then without the power cable connected, press & hold the power button for 15 seconds until it makes a chime noise, that is a basic power function reset, if that does not solve it, remove the memory cover panel on the under side of your laptop then carefully remove the memory chips blow or vacuum the area & use a dry piece of tissue to very gently clean your memory of any dust, replace the ram chips & re-connect power cord, this should solve it, but if not try starting up again without the power cord, if it's successful without the power cord you'll need a new 1, if not it suggests your ram chips have gone bad & you may need to purchase new ram chips, good luck :-) you can find more info about the 5 beeps here: Computer Does Not Start and Emits an LED or Beep Code
if you need to purchase new memory/ram chips you can get cheap ram here: Cheap Laptop Memory RAM Upgrade Low Prices UK Deals Ebuyer com
If you do need to buy new ram chips, I'd advise buying 2x 4GB modules :-)
Posted on Nov 29, 2014
Frigidaire oven fpcf3091lf eo90 code keeps lighting up and beeping after the power went out.how do I get it to stop I have unplugged it and waited 5 min. But will come back.
http://manuals.frigidaire.com/prodinfo_pdf/Specsheets/FPCF3091L_1011_EN.pdf
Electronic control has detected a fault or error condition. Press CANCEL to clear the display & stop beeping. Try the selected feature again. If the E or F error code repeats, remove power from appliance, wait 5 minutes and then repower appliance. Try the selected feature again. If the fault recurs, record the fault or error code and call for service.
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316902218en.pdf
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316904423.pdf
May 30, 2015 | Frigidaire Ovens
Beeps twice then pauses and beeps twice again(repeats) and wont boot
When your computer emits beeps when you power on the computer, it's usually means that you have a memory issue. Try re-seating the memory modules and power on the computer. If you have more the one module, insert one at a time and power on the computer.
Dec 31, 2012 | Dell Inspiron 530s Desktop Computer
Kidde pe 120 photoelectric sensor smoke alarm emits 3 "beeps" with a pause and then repeats until the 9vdc battery is removed. The house is not on fire and the 120vac power is connected. What might be the...
The 3 beeps, known as temporal pulse, is indicative of an alarm condition. If it stops without a battery, then the unit either does not have power or is otherwise defective.
Jun 03, 2010 | Kidde PE120 Hardwire with Battery Backup...
Consecutive beeps last 10 seconds, silence for 5 seconds, the long beep for 10 seconds...pattern repeats. Nothing comes on screen. I removed single RAM card, tried other slot, same problem. I powered it on...
how many beeps any breaks between beeps and then how many like 3 beeps then stops for 1 sec then beep beep beep stop beep beep beep check to make sure that your installing your memory sticks right and they are seated all the way make sure all cards are seated right all wires are not shorting out and a worst case your cpu is good
Dec 25, 2009 | Biostar K8VGA-M Motherboard
Error and power light blinking.
Here is the Waste Tank Full reset.
Canon BJC-50 BJC-55 BJC-80 BJC-85 M40 M70
1: Unplug Power Cord
2: Hold POWER and RESUME buttons
3: Plug in Power Cord
4: Release buttons after the printers starts up
5: Hold CARTRIDGE and RESUME
6: Press POWER
7: Release all buttons after the beeps
8: Press CARTRIDGE 16 times
9: Press RESUME
10: Unplug the Power cord
Mar 30, 2009 | Canon BJC-85 InkJet Printer
Suddenly started making a beep whenever it has power.
you may need to remove the old drivers download new ones, re install
www.lexmark.com
May 28, 2008 | Lexmark X5470 All-In-One InkJet Printer
Constant beeping after power loss
I'm having the exact same problem and Brother support has been useless.
Mar 02, 2008 | Brother IntelliFAX 885MC Plain Paper...
Oven beepstwice every 10 min.
Looking at the owner's manual, it would seem that the beep is supposed to occur at one minute intervals when cooking is completed. You may need to press the CANCEL pad to make it stop, but I would assume you shouldn't have to. I would assume that when the control panel senses that the door has been opened, it should stop beeping. It sounds like the code in the microprocessor has been corrupted, but only replacement of the chip would fix that. The owner's manual is online at: http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=SS&CttFileID=33043&CDCttType=UM&ModelType=N&ModelName=MW1280STA&VPath=UM/200304/20030418120018750_1_MW1280STA.pdf ( a better URL is http://tinyurl.com/ybpwlm ) You might consider calling Samsung support at 1-800-SAMSUNG (1-800-726-7864) Mon-Sun: 9am-9pm (EST). Good luck.
Sep 05, 2006 | Samsung MW1280STA 1100 Watts Microwave...
HEWLETT-PACKARD Elitebook 8460P Logo
114 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
