Question about Linksys Wireless-N WRT150N Router
I connect to work via vpn succesfully, fail /linksys router
I connect to work via a vpn succesfully, but since installing Linksys wrt400 wireles router I can no longer connect to my work computer vis MS remote Desktop. Home compuetr is wired to the router which is connected to the internet via cable modem.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 81 Answers
Dial #1-877-778-%8%969# Linksys Router Technical Support Phone Number for instant help. If you are facing any problems regarding your router so call us toll-free 24/7. For more info visit us:
https://goo.gl/KcfqZe
Posted on Apr 03, 2017
    Master:
  • 405 Answers
We are here to resolve your issue on belkin router technical support phone number1-877-7788969. For more information, click on http://resolit.us/Belkin-Router-Support.html
Posted on Oct 25, 2016
  • 41 Answers
Try connecting directly with the modem.
In case you want to avail a free technical support,
just get in touch with one of the techbuddies they provide free
technical support, you can find them on http://tinyurl.com/n29l7c
Posted on Jun 18, 2009
How can i configure my vpn router rv042
need VPN client or VPN router on the other side as well to creat VPN tunnel
Jun 19, 2014 | Linksys RV042 VPN Router
How do I install a VPN on my Linksys WRT350N router?
->Open a web browser on your computer and log in to the router.
->Click on the "VPN" link of the router's control panel.
->Select the "Enable" option for "This Tunnel" and select the "Any" options for the "Remote Secure Group" and "Remote Security Gateway" sections. Select the "Auto (IKE)" Key Management method as well.
->Enter a "Pre-Shared Key" of a length of at least 8 characters or more. This is the key you use when you connect to your Linksys VPN at a later time.
->Click the "Apply" button and your Linksys VPN is set up.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Nov 16, 2012 | Linksys WRT350N Wireless Router
Wrt160n vpn error 800
Error 800: Unable to establish VPN connection
This issue may be caused by a router that has outdated firmware.
Make sure that port 1723 is opened on your router.
For VPN connection , you can try opening port 500, 443-447, 10000-20000 and important port 1723 on your router.
I will suggest you to upgrade firmware on your Linksys router.
After upgrading the firmware, reset the router to factory default and reconfigure it manually.
Open the ports mentioned above and see if that works.
See How to upgrade firmware on Linksys router.
See How to setup Linksys router
Mar 12, 2012 | Cisco Linksys E2000 Advanced WirelessN...
Problem with VPNand Linksys router WRT150N
If that is the case you may forward ports on the router for VPN connection, try to open 47, 500 and 1723 all TCP and UDP protocol.
Here's what you need to do, check the IP address of the computer where you have the VPN software,
here's how:
click start> run> type cmd> hit okay
on the black screen put in ipconfig and check the IP address there,
> when you get the IP address then we can enable port forwarding on the router
> open IE on the working computer on the address bar, type 192.168.1.1
> nothing for username and password is admin in lower case
> then click on the applications and gaming tab on the router,
> and from there, example of how to field that in is like this,
> for aaplication name - VPN1
> for port it is 47 to 47
> for protocol it is BOTH
> for IP address ex. 192.168.1.XX - 192.168.1.100
> then check enable, do the same thing for the rest of the port.
> save the settings and try it again after.
> if it is still nothing, you may connect the computer that has the VPN connection directly to the modem and check if you will be able to connect via VPN
i'll wait for your response, thank you and have a nice day!
Jul 14, 2009 | Linksys Wireless-N WRT150N Router
How can I reset an unknown admin pw on Linksys RV042 VPN Router? I'm the new IT guy here, and I don't have the admin pw for our VPN router (and I need to provide remote access to a colleage working...
you have forgotten your LinkSys router password, the easiest thing to do is to reset your router to the factory default settings.
To restore the router configuration to factory defaults, hold the reset button on the unit for 30 seconds.
Once your router is hard reset, you will need to login and reconfigure it again.
To reconfigure your LinkSys, connect a PC to one of it's Ethernet ports, load a web browser, and go to the URL http://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password to login to your router Password: Admin
On older LinkSys routers, the default username is blank and the default password is "admin." On newer Linksys routers, both the default username and the default password are set to "admin."
Once you are past the login screen, you are able to reconfigure the LinkSys router
Apr 16, 2009 | Linksys RV042 VPN Router
VPN passthrough
What are the settings that you have for your netgear router? Its going to tunnel, right? Try this solutions and see it will work.
1. Access the set-up page of the router, from a browser, type 192.168.1.1
2. Go to VPN tab and select IP SEC VPN
3. Local Security Group, set it to subnet and input the Network Address of the router (LAN IP - 192.168.1.0)
4. Remote Security Group, set it to subnet and input the Network Address of the netgear router (LAN IP, for example - 192.168.2.0)
5. Remote Secure Group, set it to IP only, WAN IP address of the netgear router
6. For Key Managemnt, just make sure that all settings are identical with the netgear router
7. Last go to Advanced Settings and make sure that group settings are identical to the netgear router
Hope it works for you
Jun 24, 2008 | Linksys RVS4000 Router
Gateway to gateway tunneling vpn
can you provide more information:
- WAN IP addresses of both routers
- LAN IP of both routers.
- name of ISP for both
i can provide a solution if i will know these info
Nov 16, 2007 | Linksys RV042 VPN Router
Linksys Wireless-N WRT150N Router Logo
246 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
