Question about Garden
Parts for Sta Green spreader 4500
Need new part for sta green spreader. Need to replace axle. Where can I find parts?
SOURCE: repair parts for a Republic EZ Broadcast Fertilizer Spreader
I have a problem with a broken handle it looks like there is no parts for the EZ Broadcast Spreader. The sad part is the rest of the unit is in great condition.
Looks like plan obsolescent!
Posted on Dec 16, 2009
SOURCE: Speedy Green Parts
Andy,
Mine broke today! From the Scotts web site they say you can email them or call 1-888-270-3714 for replacements parts. I am calling Monday.
Keith
Posted on Mar 28, 2010
SOURCE: need spreader settings for Scotts Speedy Green 3000
I found this:
For 18-24-12 %50 PPSCU
Product Application Rate:
*LBS PER 1000 SQFT 4
Coverage:
* 12000
Craftsman 3
Craftsman Drop 7
Cyclone 4.25
Earthway 14.25
Lely 4.5
LESCO HD-1 7
LESCO R-94 7.5
LESCO Rotary (80# & 100#) 15
Ortho 3
Precision 6
Red devil 6
Republic 3
Scott's Accu Green 7.25
Scott's Easy Green 26.25
Scott's R7- X F.5
Scott's R8-A J.5
Scott's Speedy Green 1000 6
Scott's Speedy Green 2000 7
Scott's Speedy Green 3000 6
Spyker 4.5
True Temper 1500 \ 5000 5.5
Vicon 28
Posted on Oct 24, 2010
  • 25 Answers
SOURCE: I have a speedy green
listed below are the SpeedyGreen 2000 suggested spreader settings for lime:
(Please note that these are not exact measurements but they are close enough for lime applications)
30# per 1000 sq. ft. - Setting of 10
40# per 1000 sq. ft. - Setting of 7.5, go over the area twice
50# per 1000 sq. ft. - Setting of 7, go over the area three times
Posted on Mar 07, 2011
kel1guy2002
  • 3740 Answers
SOURCE: The little door on the
Hi Dennis. I don't think there are any after market parts for Scotts spreaders. I do recall a wire and a spring on one type of Scotts spreader. There was an eyelet hole just off center that the wire and spring attached to. You could probably rig something up pretty easy. Would be a matter of locating a spring and wire.
Before you get to deep into this... flip it over and look for dried / caked fertilizer on next to thehinge area. I have seen this stop spreader application doors from closing often.
You can ask Scotts here:
http://www.scotts.com/smg/helpcenter/helpCenter.jsp
Kelly
Posted on Apr 26, 2011
Need replacement wheels and axle for 4500 model Sta-Green spreader
Look up the parts on your computer search engine, or on e-bay.
Oct 23, 2017 | Garden
I have a speedy green 1000 and the drop chute will not close is there a repair kit for this machine?
Phil, Check the attached links,instruction and guides contact Scotts if you have to. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Help Center Contact Lawn and Grass Experts Scotts
Scotts Speedygreen 1000 law spreader spring repair
Replacing Rusted Axle on Scotts Speedy Green Spreader
scotts speedy green 1000 parts diagram Google Search
Apr 15, 2015 | Scotts Company Scotts& Accugreeen 2000...
Optimus stereo receiver universal remote codes
go to link below and click the green "Notify Me" button when this item is stocked. We will inform you when we put one in stock. You must purchase a new OEM remote, universals will not work. OPTIMUS STA3750 3760 Remote Control
Apr 17, 2014 | Optimus Sta-3750 Sta-3760 Stereo Receiver...
Sta rite sr400na led11 red
check safety circuit and high limits also check gas pressure
Nov 11, 2013 | Sta Rite Sr400na Max E Therm Pool & Spa...
How to wire motor sta rite p2ra5e 181L
The green wire is the ground and bolts onto the motor frame on the top part,(should see a green screw). the other two wires go to the two posts with screws to clamp down on the wires. It does not matter which way these two are hooked up, one on each post.
Most motors are pre-wired for 220v from the factory. If you have 220v you're good to go. If you happen to have a 115v setup the motor will run at half speed. The motor can be converted to 115v by moving a brown wire and a white wire in the motor. The diagram is on the motor label.Best to verify your voltage first.
Mar 21, 2013 | Sta Rite Sta - Rite 1hp Dura - Glas...
Sta-rite Pool heater boot probem
bad temp sensor heater isn't reading to go on
May 14, 2012 | Sta Rite 333 Btu Natural Gas Heater...
Sta rite heater won't fire. Control board only shows green LED lights. Prior to not firing water temp was 120 degrees. Almost burnt my foot off. Next day heater did not fire at all. Where can I go to...
Could be your heat sensor has gone bad. follow the wires for the sensor from the board to the water manifold. Then simply unscrew the old one and put a new one in. Do this with the system off, good luck.
Sep 17, 2010 | Sta Rite STA-RITE CONTROL BOARD KIT -...
Speedy Green Parts
Replacement parts for your model can be found at amazon, click here and take a look: Amazon com scotts lawn parts. I hope this was helpful. Cheers
Mar 18, 2010 | Scotts Lawn 73740 SPDY GREEN 3000 B/C S 3...
Sta rite heater won't start
TURN THE BREAKERS OFF FO R 20 SEC IF PROBLEMS PERSIST SEE CODE A POST
Dec 06, 2009 | Sta Rite Sr400na Max E Therm Pool & Spa...
Garden Logo
260 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
