Question about Canon Ir1018 Ir1022 Fixing Unit / Fuser Unit - Part Number Fm2-9046-000
Ir 1018 fuser error reset - Canon Ir1018 Ir1022 Fixing Unit / Fuser Unit - Part Number Fm2-9046-000
4 Suggested Answers
  • 153 Answers
SOURCE: Firmware for canon iR 1018
you need a special service tool to load the firmware to the copier and usually only canon sevice technicians have access to it,
you may need to call a canon agent service centre
Posted on Jun 01, 2009
  • 92 Answers
SOURCE: canan ir 1018 make sound
you have to lubricate the gear near the fixing unit,gear on the left door.
Posted on Oct 27, 2009
lpfaff1
  • 11573 Answers
SOURCE: IR 1018. What's the meaning of error code e000197?
The error code E197-0000 (laser scanner motor communication error) may be indicated during the wait state upon power-on.Cause:The tube protecting the crimp terminal on the end of the bias cable that is connected to the transfer guide in therear side of the Registration - Transfer Assembly [1] moves downward, and the uncovered metal portion of theterminal comes into contact with the screw [2]. This causes electrical noise, leading to E197-0000.
press the helpful button and check link below
canon ir7105 error code e000197 0000
Posted on Jan 23, 2016
Canon2202ir E0000-000 This error code deals with the fuser unit. It is saying that the fuser is not warming up. It needs to be reset in service mode.
How can I enter service mode on canon ir 2202? - Fixya
www.fixya.com/.../t25374950-any_one_help_me_enter_service_mode_...
Jan 19, 2015 - In standby mode, press the "Settings/Registration" key. 2. Press the "Reset" key. 3. Press the "Back" key. 4. Press the "Settings / Registration" ...
Error Code ir 2202n - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Nov 22, 2014 - 3 posts - ‎2 authors
... pls help me ....i know how to enter service mode but ......pls help. ... Copier Technical Discussion · Canon. [Error Code] ir 2202n ... ir 2202n. how to print jam history in ir 2202.......i dont know pls help ... mm its a new machine , i need to know how to enter the service mode if u please ... Press the "Reset" key. Error Code canon image ronner 2202N
Aug 21, 2014
Canon IR 2200 error E000001-002
Jun 18, 2009
More results from www.copytechnet.com
Dec 21, 2015 | Office Equipment & Supplies
How can i resolve the error code of E002-0000 on IR 2202? when i switch on it mark that error and refuse to operate please help us
I believe that model number is wrong......You must be referring to a Canon IR 2200 or maybe a Canon IR 2220. The Fuser has a problem when warming up. Replace the fuser or the Fixing film assembly and then the error must be reset in service mode.
Dec 03, 2014 | Canon Office Equipment & Supplies
How do i clear error e000007-0000 on a canon ir 2200 photocopier
Fixing film assembly may need to be replaced if error cannot be cleared. Fixing error codes should be reset by a professional only. Fuser assembly must be examined before resetting the E000, E001, E003 and E007 codes. Enter the service mode this way: Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again. Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here your tech can reset the error codes. Then turn machine off & on again.
Sep 04, 2014 | Canon Cannon Ir 2022 Photocopier
I have IR 4570 error code E0000001-0002 i am reset this function this but this will not solve please help me
If you have resr the error code in service mode and it did not clear.... Odds are you are going to have to replace the upper fuser heating unit with a new fuser film or you may want to replace the whole fuser unit..... The heating element is shorting out...... Good Luck
Dec 25, 2011 | Office Equipment & Supplies
When I turn on my Canon ir 1018 it doesn't stop heating. i.e it doesn't get ready for photocopying. It keeps on turning but doesn't stop in order to get ready.
This sounds like a faulty fuser assy. Basically the machine is warming up but nevers gets to temperature. The lamp has probably blown and for some reason it is not giving any error.
I would put a new fuser in and all should be well.
Jul 19, 2011 | Canon IR1018J Black and White Copier
Canon copier ir 2016 system error E007
i have canon ir2016 photocopier machine and its given me system error, and the error code is E007. i now when its happen so, its the fuser film that is worn out. i change the fuser and fix a new one but still the error is there. what should i do next to clear the error?
May 12, 2011 | Canon iR 2016i Black and White Copier
Have an aficio 1018 copier with an error code SC544 any ideas ?
that's a fuser unit error do an Sc reset and restart the machine if not replace the fuser unit
May 19, 2010 | Ricoh Aficio 1018 Printer
My canon ir 1018 displays this error code e808 and does not print
has the machine been serviced recently? if not, unplug machine for 10 mins, then plug back in. if the code comes back the fuser assembly will need to be replaced.
Apr 13, 2009 | Canon imageRUNNER 1023iF Black and White...
Machine error E04-01
error e04-01 means fuser warm up temperature
problems could be
-fuser thermister dirty ir defective
-fuser lamp is disconnected or defective
-fuser thermostat is defective
Oct 17, 2008 | Panasonic Workio DP-4530 Copier
How to reset error code E000 on IR2000
E000: Fuser did not heat up. check Fuser lamp, check thermistor, check thermostat, if this parts ok try to reset the trouble code. to reset fuser errors, first shut power off and turn on again. Then, go to service mode. Select "User mode" by pressing additional function ( * ) key then Press "ID" key ( # ) on user mode screen. Select menu 7 using cursor key. Press "OK" key. Select 4 item with cursor key. Press "OK" key. Printer reset. YES=( * ) to clear fuser error code E000.
Jul 11, 2008 | Canon Office Equipment & Supplies
Canon Ir1018 Ir1022 Fixing Unit / Fuser Unit - Part Number Fm2-9046-000 Logo
old marine
old marine
