Question about Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360)
Can you connect to xbox live w/out ethernet cable???
I believe that the port that you plug in the eithernet cable on my xbox is messed up. I have both a modem and a wireless router set up and want to know if there's a way to connect to xbox live without using the ethernet cable (maybe through the usb cord or something)??? please help!!
  • 41 Answers
Only wirelessly
In case you want to avail a free technical support,
just get in touch with one of the techbuddies they provide free
technical support, you can find them on http://tinyurl.com/n29l7c
Posted on Jun 18, 2009
I dont know how to set up my xbox live with an eathernet cable can you help?
Hi there
Turn off the Xbox 360 by pressing the power button on the front of the console. Afterward, shut off your modem by unplugging its power cord.
  • 2 Insert one end of the Ethernet cable into the Ethernet port located at the back of your Xbox 360 console. After that, insert the other end of the cable into your modem.
  • 3 Replug the power cord into your modem to turn it back on. Once it is active, press the power button on your Xbox 360 to turn it on.
  • 4 Navigate to "My Xbox" then "System Settings." Afterwards, select "Network Settings" then "Test Xbox LIVE Connection." You will be notified on-screen if the connection is successful.
  • Read more: How to Set Up Xbox LIVE with an Ethernet Cable | eHow.com http://www.ehow.com/how_6714462_set-xbox-live-ethernet-cable.html#ixzz0xBK8Zctz
    GOODLUCK!!
    Aug 20, 2010 | Microsoft Xbox 360 Console
    I have a Cayman 3347w wireless router and I am trying to use one of the wired slots to connect my xbox 360 to the internet. the xbox will not connect. is this router xbox compatable?
    Please try the following steps below;
    To make a router connection to Xbox LIVE:
    1. Before you connect any cables, turn off your router, modem, PC, and Xbox 360 console. (Unplug your modem from its power source to turn it off.)
    2. Connect one end of an Ethernet cable to the Ethernet port on your modem and the other end to the Ethernet input port on the back of your router.
    3. With another Ethernet cable, connect one end to one of the router's Ethernet output ports. Connect the other end to your PC's Ethernet port.
    4. With the third Ethernet cable, connect one end to another of the router's Ethernet output ports. Connect the other end to the Ethernet port on the back of the Xbox 360 console.
    5. Turn on your modem, then your router, then your PC.
    6. Make sure your PC can access the Internet. If not, you may need to configure the router for Internet access. For help configuring the router using your PC, check the instructions that came with the router.
    7. Turn on your Xbox 360 console and sign in with your profile.
    8. If this is the first time you've turned on your Xbox 360 console, see Create Your Gamer Profile to get started with both the Xbox 360 system and Xbox LIVE play.
    If you're unable to connect to Xbox LIVE, you can try to diagnose the problem right on your console. Go to My Xbox and open System Settings, then select Network Settings (setup XBOX using Automatic Configuration DHCP), Test Xbox LIVE Connection.
    Hope this helps!
    Mar 28, 2010 | Netopia Cayman 3347W-Ent Wireless Router
    Xbox can't find network on PC.
    the other persons tip is trash mines better ;)
    you can go to your routers2_bing.gif website and enter it manually. Type 192.168.1.1 this might be it or try 192.168.2.1 or 192.168.1.100
    when it shows your routers2_bing.gif info write it down and then put it in your xbox's network by entering it manually. btw the secondary DNS is just 0.0.0.0 if it doesn't give you two. the gateway2_bing.gif is just your routers ip address.
    what else you can do is do port forwarding.
    But the xbox is not a static ip address2_bing.gif so it'll change. what you can do is when it says to put your ip address in your xbox put all the numbers the same as the routers ip address BUT DON'T USE THE SAME LAST NUMBER! so like if your routers ip address is 192.168.1.1 you can use 192.168.1.23 i use 192.168.2.15 but you may not have the 2 in yours.
    http://portforward.com/english/applications/port_forwarding/XboxLive360/XboxLive360index.htm
    a website that'll help
    http://support.microsoft.com/kb/908874
    list of ports you have to open
    any other ?'s email me at mbish1993@yahoo.com
    Nov 19, 2009 | Computers & Internet
    XBOX360 Wireless Adaptor does not see my already set-up wireless network. I have Verizon FIOS as my ISP and a Linksys Wireless-G WRT54G Router. I can plug an Ethernet cord into one of the ports on the...
    Please follow the steps below to setup your Xbox with your Linksys Router:
    1. With your Xbox powered down, take an Ethernet cable and plug it into a numbered port on the router, and plug the other end into the Xbox.
    2. After you have your Xbox connected to the router, start up the Xbox without a CD in the tray.
    3. After you start the unit, you should arrive at the “Xbox Dashboard”. Select the Xbox Live option and press the “a” button on the controller.
    4. After “Xbox Live” loads select the Network Setup and press the “a” button your controller.
    5. On the “IP Address” settings, you can choose “Automatic” or “Manual”, make sure it’s Automatic.
    6. Select the Connect option and press the “a” button on the controller.
    After you use the “Connect” option, the Xbox will detect the network cable, and will ask you if you want to connect to Xbox Live.
    Aug 17, 2009 | Linksys Wireless-G WRT54G Router
    Cannot connect thru the ethernet cable. Can only connect wireless
    The solution that I received yesterday was given to the tech that had worked on my computer and she said that she would follow the information and believed that everything would be working nornally.
    thanks
    May 14, 2009 | HP Pavilion dv9000z Notebook
    Cannot connect ot xbox live my ip address test fails
    if you dont have a router, you can either have the xbox or the pc conneted to the internet, not both. you have to have an eithernet cord or a usb 2.0 high speed usb chord that goes directly from the xbox to the modem. you cannot go from the modem to the computer then to the xbox.
    Jan 24, 2009 | Microsoft Xbox 360 Console
    Why isnt my xbox connecting? i plugged the cble into the rouder and then put the other cable into the xbox and its not letting me connect.
    To make a router connection to Xbox Live:
    7. Turn on your Xbox 360 console with no disc in the disc tray.
    8. If you've already used your Xbox 360 system for offline play, the Xbox Dashboard will open to the Xbox Live area. Select the Xbox Live banner. When you see the Xbox Live Marketplace you'll know you're connected to Xbox Live.
    Jul 02, 2008 | Video Game Consoles & Games
    Xbox live connection problem ?
    is there an Ethernet Cable plugged in the back, or a USB Wi-fi adapter right below the Ethernet Port, or the 2 front USB adapters?
    Jun 02, 2008 | Microsoft Xbox 360 Console
    Xbox 360 to wireless laptop
    Make sure ethernet cable from XBOX 360 is connected to one of the 4 access ports on the back of the router.
    Mar 16, 2008 | Microsoft Xbox 360 Console
    Open Questions:
    See all Microsoft Wireless Network Adapter Xbox 360 Questions
    Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360) Logo
    149 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
