Question about Jaguar 2002-2008 Xtype X Type Ac A/c Freon Cooling Line Tube Evaporator Inlet
2004 jag s tpye air bag code b2293 - Jaguar 2002-2008 Xtype X Type Ac A/c Freon Cooling Line Tube Evaporator Inlet
3 Suggested Answers
  • 12 Answers
SOURCE: 2000 s=tpye jag door ajar signal when door is
your spacer may be damaged try as new one may fix problem
Posted on Jul 23, 2009
  • 262 Answers
SOURCE: how to remove rear lower seat on a 04 x-tpye jag
there are plastic clips under the seat unclip them
Posted on Oct 04, 2009
2008 ford f-350 passenger air bag flashes 1-7 code than stays on when truck is started.What does the code mean and can the code be reset without tearing air bag out of truck?
If a SRS fault exists, the RCM sends a message to instrument cluster module to flash a coded sequence which is called a lamp flash code (LFC) on the air bag warning indicator. Each LFC is flashed 3 times after which the air bag indictor will remain lit for the remainder of the key-on cycle. In addition to the self-test at start up, the RCM continuously monitors all of its external and internal circuitry for faults.
While the LFCs are an indication of a general concern in the supplemental restraint system (SRS), the DTCs are more specific. The DTCs can be retrieved from the RCM with a scan tool via the DLC.
DTC a c LFC b Description Action To Take - Continuous Lamp The Air Bag Warning Indicator is Illuminated Continuously (RCM Disconnected or Inoperative, Loss of Battery Feed or Loss of Signal Ground) Go To Pinpoint Test A . B1048 c - Passenger Side Air Bag Cross Link to Another Firing Loop Go To Pinpoint Test B . B1049 c - Passenger Seatbelt Pretensioner Cross Link to Another Firing Loop Go To Pinpoint Test C . B1054 c - Driver Seatbelt Pretensioner Cross Link to Another Firing Loop Go To Pinpoint Test D . B1057 c - Driver Air Bag Cross Link to Another Firing Loop Go To Pinpoint Test E . B1231 13 RCM Crash Data Memory Full INSTALL a new RCM and CARRY OUT programmable module installation (PMI). REFER to Restraints Control Module (RCM) and Inspection and Repair After a Supplemental Restraint System (SRS) Deployment in this section. B1317 Continuous Lamp Battery Voltage High REFER to Section 414-00 . B1318 Continuous Lamp Battery Voltage Low REFER to Section 414-00 . B1342 24 RCM is Faulted INSTALL a new RCM and CARRY OUT programmable module installation (PMI). REFER to Restraints Control Module (RCM) in this section. B1871 25 Passenger Air Bag Deactivate Module Fault Go To Pinpoint Test F . B1884 27 Passenger Air Bag Deactivation (PAD) Warning Lamp Circuit Failure Go To Pinpoint Test G . B1890 27 Passenger Air Bag Deactivation (PAD) Warning Lamp Short to Battery Go To Pinpoint Test H . B2292 33 Restraint System - Seat Belt Pretensioner Fault (Driver Pretensioner Circuit Fault) Go To Pinpoint Test I . B2292 34 Restraint System - Seat Belt Pretensioner Fault (Passenger Pretensioner Circuit Fault) Go To Pinpoint Test I . B2293 19 Restraint System - Air Bag Fault (Driver Front Air Bag Circuit Fault) Go To Pinpoint Test J . B2293 21 Restraint System - Air Bag Fault (Passenger Front Air Bag Circuit Fault) Go To Pinpoint Test J . B2296 42 Restraint System - Impact Sensor Fault Go To Pinpoint Test K . B2434 53 Driver Seat Belt Buckle Switch Circuit Short to Ground Go To Pinpoint Test L . B2435 53 Driver Seat Belt Buckle Switch Resistance out of Range Go To Pinpoint Test M . B2477 54 Module Configuration Failure This DTC indicates programmable module installation (PMI) has not been done to a newly installed module. CARRY OUT PMI. REFER to Section 418-01 . CLEAR the DTC. CARRY OUT the self-test. B2607 57 Harness/Configuration Mismatch This DTC indicates the RCM is configured incorrectly. CARRY OUT programmable module installation (PMI). REFER to Section 418-01 . CLEAR the DTC. CARRY OUT the self-test. If DTC is retrieved a second time, INSTALL a new RCM and CARRY OUT PMI. REFER to Restraints Control Module (RCM) in this section. B2691 53 Seat Belt Buckle Switch Circuit Fault, Front Driver's Side Go To Pinpoint Test N . C1414 29 Incorrect Module Design Level VERIFY RCM part number is correct for vehicle.
CARRY OUT programmable module installation (PMI). REFER to Section 418-01 . CLEAR the DTC. CARRY OUT the self-test. If DTC is retrieved a second time, INSTALL a new RCM and CARRY OUT PMI. REFER to Restraints Control Module (RCM) in this section. U0100 14 Lost Communication With ECM/PCM REFER to Section 418-00 to diagnose the communication concern. U2023 14 Fault Received From External Node REFER to Section 418-00 to diagnose the communication concern. U2050 14 No Application Present This DTC indicates programmable module installation (PMI) has failed. CARRY OUT PMI. REFER to Section 418-01 . CLEAR the DTC. CARRY OUT the self-test. If DTC is retrieved a second time, INSTALL a new RCM and CARRY OUT PMI. REFER to Restraints Control Module (RCM) in this section. a DTC: Diagnostic trouble code, retrieved using scan tool.
c Cross-link DTCs will be retrieved in pairs to identify the cross-linked components.
b LFC: Lamp fault code, flashed on air bag warning indicator.
Apr 18, 2017 | Ford Cars & Trucks
2006 lincoln town car air bag light is on 5 beeps 5 times
The five beeps - five times would indicate a code 55 , but factory service info only goes to code 53 .
  • Audible tone - DTCs retrieved
  • Air bag SRS system fault
  • REFER to DTC Priority Table.
Did your air bag light flash at all ? Apparently this will do flash the air bag light codes as well .
Symptom Chart Condition Possible Sources Action
  • Air bag warning indicator is illuminated continuously
  • Fuse
  • Damaged wiring, terminals or connectors
  • A faulty diagnostic connector
  • A faulted RCM
  • A faulty instrument cluster
  • Go To Pinpoint Test A .
  • Air bag indicator flashing
  • Air bag/pretensioner supplemental restraint system (SRS) fault
  • No communication with the restraints control module (RCM)
  • Fuse
  • Diagnostic tool
  • Data link connector (DLC)
  • A faulted RCM
  • Circuitry
  • Go To Pinpoint Test V .
LFC - light flash codes .
Restraints Control Module (RCM) Diagnostic Trouble Code (DTC) Table
DTC a LFC b Description Action To Take - Continuous The Air Bag Indicator is Illuminated Continuously, RCM Disconnected or Inoperative, Loss of Battery Feed, or Loss of Signal Ground Go To Pinpoint Test A . B1231 13 Crash Data Memory Full Install a new RCM and impact sensors. REFER to Inspection and Repair After a Supplemental Restraint System (SRS) Deployment . B1317 Continuous Battery Voltage High CHECK battery voltage; to be below 16 volts. REFER to Section 414-01 . B1318 Continuous Battery Voltage Low CHECK battery voltage; to be above 9.0 volts. REFER to Section 414-01 . B1342 12 RCM Is Faulted Install a new RCM. B1869 NONE
Continuous lamp
Secondary air bag warning sounds if another fault is present Lamp Air Bag Warning Indicator Circuit Open or Short to Ground Go To Pinpoint Test B . B1870 NONE
Secondary air bag warning sounds if another fault is present Air Bag Warning Indicator Circuit Short to Battery Go To Pinpoint Test C . B1891 53 Air Bag Tone Warning Indicator Circuit Short to Battery Go To Pinpoint Test D . B1892 53 Air Bag Tone Warning Indicator Circuit Open or Short to Ground Go To Pinpoint Test E . B1921 14 Air Bag Diagnostic Monitor Ground Circuit Open Go To Pinpoint Test F . B2292 33 Restraint System - Safety Belt Pretensioner Fault (Driver Pretensioner Circuit Fault) Go To Pinpoint Test G . B2292 34 Restraint System - Safety Belt Pretensioner Fault (Passenger Pretensioner Circuit Fault) Go To Pinpoint Test G . B2293 19 Restraint System - Air Bag Fault (Driver Front Air Bag Circuit Fault) Go To Pinpoint Test H . B2293 21 Restraint System - Air Bag Fault (Passenger Front Air Bag Circuit Fault) Go To Pinpoint Test H . B2294 24 Restraint System - Curtain Fault (Driver Side Air Curtain Circuit Fault) Go To Pinpoint Test I . B2294 25 Restraint System - Curtain Fault (Passenger Side Air Curtain Circuit Fault) Go To Pinpoint Test I . B2295 22 Restraint System - Side Air Bag Fault (Driver Seat Side Air Bag Circuit Fault) Go To Pinpoint Test J . B2295 23 Restraint System - Side Air Bag Fault (Passenger Seat Side Air Bag Circuit Fault) Go To Pinpoint Test J . B2296 42 Restraint System - Impact Sensor Fault (Front Impact Severity Sensor Circuit Fault) Go To Pinpoint Test K . B2296 43 Restraint System - Impact Sensor Fault (Driver Side Front Row Impact Sensor Circuit Fault) Go To Pinpoint Test K . B2296 45 Restraint System - Impact Sensor Fault (Driver Side Second Row Impact Sensor Circuit Fault) Go To Pinpoint Test K . B2296 44 Restraint System - Impact Sensor Fault (Passenger Side Front Row Impact Sensor Circuit Fault) Go To Pinpoint Test K . B2296 46 Restraint System - Impact Sensor Fault (Passenger Side Second Row Impact Sensor Circuit Fault) Go To Pinpoint Test K . B2434 51 Driver Safety Belt Buckle Switch Circuit Short To Ground Go To Pinpoint Test L . B2435 51 Driver Safety Belt Buckle Switch Circuit Resistance Out Of Range Go To Pinpoint Test M . B2438 52 Passenger Safety Belt Buckle Switch Circuit Short To Ground Go To Pinpoint Test N . B2439 52 Passenger Safety Belt Buckle Switch Circuit Resistance Out Of Range Go To Pinpoint Test O . B2477 Continuous Module Configuration Error INSTALL a new RCM. B2691 51 Driver Safety Belt Buckle Switch Circuit Fault Go To Pinpoint Test P . B2692 52 Passenger Safety Belt Buckle Switch Circuit Fault Go To Pinpoint Test Q . C1414 15 Incorrect Module Design Level Go To Pinpoint Test R . C1947 49 Driver Seat Track Position Sensor Circuit Short to Ground Go To Pinpoint Test S . C1948 49 Driver Seat Track Position Sensor Circuit Resistance Out Of Range Go To Pinpoint Test T . C1981 49 Driver Seat Track Position Sensor Circuit Fault Go To Pinpoint Test U . - - No Communication with the Restraints Control Module Go To Pinpoint Test V . Your best bet have codes checked with a scan tool .
Jan 23, 2017 | Lincoln Cars & Trucks
What is a b2293 code on 2003 mercury mountaineer
B2293
Pinpoint Test H: LFC 19 and 21/DTC B2293 - Restraint System Airbag Status
Normal Operation
The restraints control module (RCM) checks all of the front air bag circuits for faults. If the RCM detects one of the following faults on any of the front air bag circuits, it will store diagnostic trouble code (DTC) B2293 in memory and, depending on the fault, flash either lamp fault code (LFC) 19 or 21 (or higher priority code if one exists) on the air bag indicator.
Fault Conditions
The RCM monitors for the following fault conditions:
  • low resistance.
  • circuit open.
  • circuit short to voltage.
  • circuit short to ground.
Possible Causes
A driver air bag status fault can be caused by:
  • damaged wiring, terminals, or connectors.
  • a faulty clockspring.
  • a faulty driver air bag module.
  • RCM is faulted.
A passenger air bag status fault can be caused by:
  • a faulty passenger air bag module.
  • RCM is faulted.
21 Restraint System - Air Bag Status (Passenger Front Air Bag Circuit Fault) Go To Pinpoint Test H .
Sep 06, 2016 | 2003 Mercury Mountaineer
I have a code B2293 and air bag light flashing 1-8 Can you help.
B2293 restraint airbags fault
18 right front/passenger frontal deployment loop (signal stage or stage 1 ) shorted to ground/ voltage out of range
Take vehicle to repair shop and have it repaired it will not protect you in a crash
May 21, 2016 | 2006 Mercury Grand Marquis
My 2004 mercury sable air bag light blinks on and off 3 times...tried the battery thing..the switch thing..cant get to reset
When the air bag system has a problem it uses the air bag light tell you what the codes are. Three flashes then 1 or 2 second pause then 2 flashes would be a code 32. Then Google it and find out what the code is for. Hope this helps
Sep 26, 2013 | 2004 Mercury Sable
B2293 code on
it is your air bag control module .it is located inside just under the center console
Nov 29, 2012 | 2007 Ford Expedition Eddie Bauer EL
B2293 air bag
That might be a bad Drivers Side air bag Module you need to take into a Ford Approved Dealer , might be still under warranty
Sep 09, 2010 | 2006 Ford Escape
How to remove rear lower seat on a 04 x-tpye jag
Oct 04, 2009 | 2004 Jaguar X-Type
2007 FORD RANGER TROUBLE CODES #B2292, B2293
These 3 codes have to do with restraint system.
B2292 Seatbelt pretensioner fault.
B2293 Passenger front airbag fault.
B2691 Seatbelt buckle switch circuit fault Ft.driver side.
Sep 18, 2009 | 2007 Ford Ranger FX4 Off-Road
Jaguar 2002-2008 Xtype X Type Ac A/c Freon Cooling Line Tube Evaporator Inlet Logo
44 people viewed this question
Top Jaguar Heating & Cooling Experts
rdjagger
 Mikey
Mikey
ray gallant
Are you a Jaguar Heating and Cooling Expert? Answer questions, earn points and help others
