Question about Lands Phones
Cannot pair bt elements phone with base - Lands Phones
SOURCE: Motorola H700C Pairing with LG VX8700
im having a problem with my h700c and my lg too it was paired with a samsung and i got the lg now the phone phone the BT fine it just wont pair,wat can it be?
Posted on Feb 09, 2008
SOURCE: CANNOT PAIR AOEM BLUETOOTH HEADSET TO LG SHINE KE970 MOBILE PHONE
The mamual says to hold the - and + volume keys at the same time for approx. 2 seconds till the light starts to flash green and red. The pairing code is 1234
Posted on Aug 26, 2008
MobilityMan
  • 129 Answers
SOURCE: Problems pairing my Just Wireless Blue BT-35K2
If you can get the headset into pairing mode, and your phone into detection mode and it's still not pairing, try removing the battery while powered on. Replace the battery and retry, and it should work.
Posted on Jun 27, 2009
stuartgadget
  • 20 Answers
SOURCE: I HAVE HAD MY BT 02A2 PAIRED WITH A NOKIA PHONE, A...
HOLD down the mode, power on and "+" button simultaneously for 3 seconds. This puts the device in pairing mode. Your phone should find it and ask for a pass code. The code is 0000
Posted on Jun 18, 2010
SOURCE: My BT-10K pairs and operates in phone mode with a
CANT CONNECT TO PS3
Posted on Aug 06, 2010
I have a bt 86000 twin handset telephone and only one handset can be used to make calls.
if it is on a landline then that will be right as there is only one landline in
if it will not make a call on the other phone when the base phone is on the base then read the instructions a to how to pair that hand piece to the base
Jul 04, 2016 | BT Lands Phones
I am looking to buy a A495H base Gigaset unit to work with my 3 unit A49H phone set
Most modern Gigaset units work together.
I have a pair of gigaset 300 phones and three newer models, and a BT Diverse 2000 phone, all talking to the same DECT base station (a VOIP N300IP).
Feb 12, 2015 | Siemens Gigaset A495-4 4 handset cordless...
Pair iPhone 4s with 2006 BMW x5
Key-in, Ignition On (but don't need to start the engine)Press the R/T button on the steering wheel. "Activate Phone" should display on the radio. On the iPhone search the BT device. Select your car and enter the passkey when prompt on the iphone. Make sure there is no other BT phone near-by or the old one that has paired with the car previously. There is also the maximum number of devices you can have in the BMW BT sharing. If you reach the max, you may have to clear the car BT pairing memory by removing the power to the BT unit (by removing a fuse in the rear fuse box). The info is in the manual and inside the fuse box (which tell you which fuse is for the BT.)
Feb 06, 2013 | BMW X Series & X5 1997 >2006
How you play music on jabara bt 2050 0n phone
first you have to pair your blue tooth device to your phone,first you turn the bt power to on on your phone menu,next you have to put your blue tooth device headphones into discovery mode,now most bt manufactures use the power button for this feature,by holding the power button down for 6 to 10 seconds when you turn the bt device on it usually puts the bt intodiscovery mode.a solid light usually remains on on your blue tooth device,then you can search or add new device from your phone menu.once they have paired or recognized you will need a pin pairing code.Most manufactures of blue tooth devices use a factory 4 digit pin pairing code ,they are as follows0000,1234,9999,or1111 i hope this helps
Feb 25, 2011 | Samsung Radio Communications
How do i tranfer music on the phone via blue toothe ?
Hamilton,
It will take you ages to download music via BT. It is very slow. You can but by this time next year. (Joke).
You have to habe BT on and searching for other BT devices on both, your phone and computer or other BT enabled phone. Connect to each other and PAIR them. Once paired select all the music that you want on donor and from Options select Send. It will ask you how to send, Email, USB or BT. You select BT. Then it will ask you who to. Since you are already paired with your phone, the receiver, select it. Your phone will ask you, So and So want to send data, Receive it??? Say yes. And see a red light on both the phones. The transfer has begun. Easy, is it not?
Jan 19, 2011 | Orange SPV M600 Smartphone
May 21, 2010 | Cell Phones
H700 wont connect to lg rumor
after pair successful highlight the headset and hit connect
Jan 07, 2009 | Motorola Mobility H700 Wireless Headset
Jan 11, 2008 | Motorola Mobility Bluetooth...
Lands Phones Logo
32 people viewed this question
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
