Question about Weiser Lock Powerbolt 1000 Lock
Http://www.weiserlock.com/Support/Faq://www. how to change batteries
Keyboard is dead - put in new batteries. It beeps when you put the last new battery in, but the keyboard remains dead
This link takes you to the troubleshooting page for the Powerbolt 1000:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
About midway down on this page it addresses beeping. It sounds like you may need to replace the keypad. part numbers are listed here, depending on the finish of your lock.
This page:
http://www.weiserlock.com/Support/Faq/50160000000HhY3AAK.aspx
takes you to Customer Service contacts, where you can get further assistance and order parts.
Jun 03, 2011 | Weiser Lock Powerbolt 1000 Lock
Keeps beeping after installing new batteries. what's up?
Here's the link to the troubleshooting procedure for the Powerbolt, wherein beeping is discussed:
If this doesn't help, I recommend contacting their Customer Support for further advice and parts:
http://www.weiserlock.com/en/CustomerService/ProductSupport/SupportContact.aspx
Apr 30, 2011 | Weiser Lock GED1460X GED1460X3BR Lifetime...
We purchased our keyless weiser dead bolt 11 years ago,has worked perfectly till today,red lite off,changed batteries,still nothing,no beeping ,no movement of any kind..Ellie
This is the link to the troubleshooting procedure for the Powerbolt:
Here is the contact information for ordering parts:
Customer Service:
Your lock is well out of warranty and may be simply dead of old age. However, I'd still contact their Customer Service for further troubleshooting, and you may be able to get them to stand behind their product and help you with the replacement if necessary. Good luck!
Apr 27, 2011 | Weiser Lock Powerbolt 1000 Lock
We,ve never been able to get it to work and my husband in his infinite wisdom never keeps instructions etc. How do I program it to work I hope this is the right product. the picture looks correct.
Let me assume that you've already installed the Powerbolt 1000 (the one that matches the picture!), so let me link you to the Troubleshooting instructions, which illustrates how to open and reprogram the lock:
Please install fresh batteries at this time.
Also please take a look at this link,
http://www.weiserlock.com/Support/Faq/50160000000HhmZAAS.aspx
which tells you how to locate and change the jumper to set the lock up for a door which is "right-handed" or "left handed"-in other words, what side the door hinges are on as you face it from the exterior. If the jumper is set wrong, the lock will not function properly.
Lastly, here's a link to the Weiser cutomer Support contact page:
Apr 23, 2011 | Weiser Lock GED1460X GED1460X3BR Lifetime...
I am looking for a manuals for a weiser lock powerbolt 1000 can i down lord
powerbolt 1000
Here's a link to the Frequently Asked Questions page for the Powerbolt 1000:
The instructions for reprogramming the code can be found there. Good luck!!
Apr 07, 2011 | Weiser Lock ED1460X3VKD Powerbolt 1000...
.caMy lock is beeping at
This link to the troubleshooting page addresses possible problems if your lock is beeping:
There is also a link to the Customer Service page for further assistance directly from Weiserlock.
Mar 23, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
How do you change the battery?
The instructions for accessing the batteries and reprogramming the code can be found there. Good luck!!
Oct 14, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
I was changing the batteries. Now the bolt retracts when you push "lock" and Locks when you put the the code. How do I fix this reversal function problem?
Here is a link to the Frequently asked question page for your lock:
I have installed your Powerbolt, but when I push the Lock Button, it unlocks? What should I do?
First remove the cover on the inside of the Powerbolt unit. On the right hand side under the batteries, you will notice that is says "Door Direction Jumper". If the cap is mounted on Prongs 1 & 2, carefully remove it and move it over so that it mounts Prongs 2 & 3. A is right handed, B is left handed.
Here's a link which tells you how to remove the cover, and reprogram the lock codes:
Sep 03, 2010 | Weiser Lock Powerbolt 1000 Lock
How to change batteries
The instructions for changing the batteries and reprogramming the code can be found there. Good luck!!
Mar 19, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
How do you take the panel off to change the batteries
Jan 21, 2010 | Weiser Lock Powerbolt 1000 Lock
Weiser Lock Powerbolt 1000 Lock Logo
145 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
Jim Goldsmith
Jim Goldsmith
john h
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
