Question about Casio 2.3 Color Handheld Television Television
Radio shack 12-262 external antenna - Casio 2.3 Color Handheld Television Television
How do I switch from cable to external anten ae
Is it a satellite antenna or regular outside antenna ? What kind of cable do you have? Is it dish network or cox, cableview, radio shack?
Aug 15, 2013 | Toshiba Ct885 Remote Control
Need an replacement antenna for my radio shack pro-508 scanner. Radio shack does not carry them anymore
Hi.
Check on eBay. You need a standard BNC connector antenna for this scanner. Radio Shack scanners are made by Uniden so a Uniden BNC antenna will fit your unit.
Here's a link for an antenna on eBay:
http://cgi.ebay.com/UNIDEN-DESKTOP-SCANNER-ANTENNA-BNC-SCAN-3-/220734104369?pt=LH_DefaultDomain_0&hash=item3364c72331
Feb 08, 2011 | Radio Shack Pro-2018 Scanner
Can't seem to tune many stations at all. Also once a station is tunned it "slips".
The antenna works with the power cord. Try extending the length of its power cord with an extension cord.
Position of the radio in the room, the furniture in the room and your position in relation to the radio all affect its reception.
If there is a place to connect an external antenna, this will be helpful. Check with Radio shack and best buy for a FM loop antenna. Usually the wire is flat.
An inexpensive antenna for FM only is also a cheap alternative
Jan 03, 2011 | Tivoli Model Three Clock Radio
Am fm reception bad
FM reception is weak
What to do
• Extend the power cord as much as possible. The FM antenna is in the power cord.
• Move the power cord to adjust the FM antenna
• If you still have problems with FM reception, you may need an external antenna.
* Call Bose®Customer Service to request one.
The external antenna on your radio is a coax (round) design It needs an adaptor and an antenna which are cheap.
Easy to make, radio shack "F" connector 90 degrees or straight, to 300 ohm wire connections. Attatch a 300 ohm flat ribbon antenna cable to those two screws and plug into radio and see how your reception is. You will need to position the antenna wires to get best reception. I have hid them in back of paintings and so on.
Cheapest solution next to putting an extension cord on radio power cord.
Jan 03, 2011 | Bose Wave Radio
HOW CAN I INTALL ANTENNA TO WATCH MY TV
if this is a portable tv; your state might have gone digital programming which you can only receive canada stations only. but see if you have an external antenna jack then you need the adapter to use with an antenna you can find it at radio shack.
Feb 25, 2010 | Citizen ST-555 2.2 in. Television
How do I connect an external radio shack AM enhancer
I presume that you wish to connect an external antenna/aerial to a portable radio with no antenna connection. Wind several turns of your antenna wire around the telescopic antenna - should work ok!
Mar 30, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Antenna for radio shack pro 2018
Hello, Radio Shack would be the first place i'd try for a replacement. Mechanic
Oct 09, 2008 | Radio Shack Pro-2018 Scanner
External antenna
You can get good assistance at the DX 398 Group at Yahoo! The DX 398 is the same radio as the ATS-909. It was the name used by Radio Shack when they marketed it. Here's the URL for the DX398 group: http://groups.yahoo.com/group/DX398/ They will definately welcome your questions and will likely provide some valuable answers.
Nov 15, 2007 | Sangean ATS 909 AM/FM/SW Radio
Casio 2.3 Color Handheld Television Television Logo
47 people viewed this question
Top Casio Televison & Video Experts
Henry  Thomas
Henry Thomas
mikeuk
Lawrence Oravetz
Are you a Casio Televison and Video Expert? Answer questions, earn points and help others
