Question about Power Color 256MB PowerColor ATI RADEON X1650Pro Dual DVI/HDTV PCI-Express X1650PRO 256M Graphic Card
Powercolor x1650 512mb AGP problem
Hi
I just bought a new graphic card which is powercolor x1650Pro 512mb AGP and followed the manual but after I installed the graphic card into my motherboard it just wont startup when I turn the pc on and my monitor is still turned off. I tried my old graphic card again and it worked fine. By the way my mobo supports AGP 8x interface so i really don't know what is the problem.
Anyone can help me please.
Have you wired it up to the power supply ?
Posted on Jul 31, 2009
  • 3,267 Answers
The one you bought is 16x but your MB supports only 8x..................sodeep
Posted on Jun 19, 2009
ATI9550 driver for win 7
go to ati.com driver download make sure u inter agp and the right operating system type x86 or x64
Apr 29, 2014 | ATI PowerColor R96-LD3 RADEON 9550 256MB...
Graphic card and mother board
Hi mate it should be fine .the only thing might be you psu power supply unit might not handle it but i am pretty sure you will be fine just make sure you unistall drivers then insert new card then reinstall drives from amd web site .
Jan 19, 2013 | Computers & Internet
Free download ATI RADEON X1650PRO 512MB AGP GRAPHICS VIDEO CARD
Click here to get the latest available drivers for your ATI Radeon X1650Pro.
On the right hand side of the page their is a quick driver download section. With a heading Download drivers.
Select the following:
First field: Desktop Graphics.
Second Field: Radeon X Series.
Third Field: Radeon X1xxx Series.
Fourth Field: Select the operating system that are running this graphics card on.
Now click View results.
Then it may say that you should use the ATI Catalyst 9.3 Driver, however the 10.2 version is available for download. I would try it first just in case it works.
If not you will have to download and install the Catalyst 9.3 Driver.
Take care!
damnor01
Sep 18, 2011 | ATI RADEON X1650 Graphic Card
I bought a 512MB PowerColor ATI Radeon HD3650 DDR2 AGP video card
hey your monitor is not support the resolution , try lower resolution
Jun 13, 2009 | ATI RADEON X1650 Graphic Card
Display issue can card's cmos (if any), be reset?
There is no bios on the AGP card. Uninstall the PowerColor driver software including any other software the CD may have installed. Than open this link;
http://www.pctuneuptips.com/recommends/clean/?gclid=CL2RiIrTmpICFSFMGgodODIPzg
Download RegCure & install. Let RegCure clean your system.
Shut down the system & install your AGP x1550 card. Re-install the driver software. Try playing the game with default settings. Your system & AGP card has more than enough power to play the game. If the game messes up or your system freezes send it back to PowerColor. Its not your system it has to be the card.
Cheers
May 07, 2009 | Power Color POWERCOLOR ATI RADEON VC X1550...
AGP x1650 pro 256mb just stops working
you wont damage anything but get at least a 450-500w power supply. Nothing should be damaged
hope this helps
Jan 03, 2009 | Power Color 256MB PowerColor ATI RADEON...
Cant install powercolor 9600 pro on EliteGroup 845GV-M3 mobo... Fan will run in agp express slot but hardware not found on boot up (win XP)
HI findads,
You need to make a change in your bios. Still have your manual for the 845GV-M3 motherboard?
If not you can download it at this link: http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=465&DetailName=Manual&DetailDesc=845GV-M3%20%20(V1.0)&CategoryID=1&MenuID=82&LanID=0
You will also need Adobe reader to view the pdf file. Get Adobe for free at: http://www.adobe.com/products/reader/
If you have already installed the 9600 AGP card, please shut down your system. Unplug the power cord from the power supply. Open your case & remove the 9600 AGP card. One must follow an order of sequences’ when changing graphics cards. Once removed, reconnect the power cord to the power supply & boot the system. (It’s ok not to close your case). As the system starts to boot, press the Delete key on your keyboard every two seconds. The main bios menu will load. Read the instruction at the bottom of the menu which will show you how to move about in the bios.
(The mouse does not function while in the bios).
Using the manual to help change a settings.
Go to Advanced Chipset Features page 35, than into Integrated Peripherals, page 37.
Set Init Display First to [AGP]. Save the bios & exit. The system will auto restart. Once your screen goes to black, press & hold the power on / off button on your case until the system shuts off.
Unplug the power cord from the power supply. Install the AGP video card. Make sure it is completely seated & even in the AGP slot. Screw it down. Before closing the case, re-check all internal power connections to every device & all data connections. (Snug fit). Close your case & reconnect the power cord to the PC. Boot your system. You should have display & windows should load.
Install the CD software for the 9600 Pro video card. Restart the PC. Go to power color & check for any driver updates for the 9600 Pro card. http://www.powercolor.com/
Before installing any update from PowerColor check windows for updates.
Everything should work out ok.
Good luck findads!
Questions? Post here.
Mike
Oct 16, 2008 | EliteGroup 845GV-M3 Motherboard
Re-installing video drivers after Windows crash
You will be fine if you simply insert the disk and follow the instructions. If you're still uncomfortable you may be able to find step-by-step instructions if you go to the ATI website and look around in their support section.
Nov 28, 2007 | ATI RADEON 9550 Graphic Card
Power Color 256MB PowerColor ATI RADEON X1650Pro Dual DVI/HDTV PCI-Express X1650PRO 256M Graphic Card Logo
359 people viewed this question
Top Power Color Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Power Color Computer and Internet Expert? Answer questions, earn points and help others
