Question about Goodman CKL60AR60 Air Conditioner
How much r-22 will a goodman 5 tons ac hold - Goodman CKL60AR60 Air Conditioner
    Genius:
  • Goodman Master
  • 1,363 Answers
The data plate on unit will give amount.
Posted on Aug 09, 2015
chillmaster
  • 104 Answers
SOURCE: 5 ton goodman ac unit
You MUST WEIGH IN THE NEW CHARGE OF R-22. There should be a label on the side of the a/c unit that states what the factory charge was. This is only a starting point. Once you have the factory charge in the system, then turn on the unit and allow it to stabilize (5 min) . Check pressure on low side and check teperature on low side pipe. Temperature of pipe should be 8 to 15 degrees above what the boiling point of the refrigerant is for the current pressure you are reading. If the temperature is more than 15 degrees, add R-22 in 4oz increments allowing 5min in between each time you add until you are in the "zone". When you do this, your head pressure needs to be 225-250. if you need to cover the coil or block the outdoor fan to do this then do it. Hook up the vacuum pump and start over
Posted on Jun 18, 2008
  • 3 Answers
SOURCE: I have a goodman 2 ton condeser model number
Yes. The condenser is 1.5 ton and the larger coil will allow for better dehumidification but do not go any larger. Make sure when installed that bioth super heat and subcool are measured to insure proper charge and that system is working at peak performance.
Posted on Aug 14, 2009
  • 2468 Answers
SOURCE: where is the capacitor located on a goodman 5 ton
right next to the contactor in the side panel where the input 240 volt line enters the outdoor unit
Posted on May 24, 2010
  • 674 Answers
SOURCE: WHERE THE CAPACITOR ON A GOODMAN 5 TON AC UNIT
Remove the cover where the power goes into the outside unit. In there should be the capacitor, circuit board, and contactor. There may be 2 capacitors or just one that works for the fan and compressor. If there is just 1 it will have 3 terminals and it is important to hook the wires back right so label them and write it down if you need to.
blueextc3221
  • 15935 Answers
SOURCE: I have a 2.5 ton ac by goodman gsx130301ba and it
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 04, 2010
I have a 2.5 ton ac outside. the indoor unit downstairs in the basement is a goodman. a new a coil was put in about a month ago. which is a goodman product. ive heard goodman is not a good product. a
the inside coil and outside unit should be matching in tonages another word if you have 2.5 ton outside the inside sould be the same. it don't matter what brand name or who made it.
Aug 04, 2012 | Goodman CKL36AR36 Air Conditioner
What should the psi be on 1 1/2 ton ac unit?
on r-22 should be 68-74psig on high side 230 to 260psig depending on heat load and ambient temperture
Jul 27, 2012 | Goodman Heating & Cooling
Charging chart missing. Goodman 4-ton AC (model CK 49-18) R-22 fixed orifice
Hello, in order to find if the sytem is operating correvtly you should measure the outdoor dry bulb temp and indoor wet bulb temps, this will givenyou a target superheat. Pressures will vary always use superheat. If superheat is higher than target add refrigerant if it is lower remove refrigerant.
Jun 08, 2011 | Heating & Cooling
Where is the capacitor located on a goodman 5 ton outside ac unit
May 24, 2010 | Goodman CKL60AR60 Air Conditioner
I have a goodman 2 ton condeser model number CK24-18 and I was wondering if it would be could use a 10 SEER ADP UNCASED COIL R-22 2 TON?
Aug 14, 2009 | Goodman Heating & Cooling
Need to know unit size
ckl60 5 ton about a 2003 model on most ac heat pumps the model number reflects the ton sized by 12000 btus per ton also as for the indoor unit cfm rating 400 cfm per ton
May 14, 2009 | Goodman CKL60AR60 Air Conditioner
Jun 17, 2008 | Goodman Heating & Cooling
Goodman CKL60AR60 Air Conditioner Logo
55 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
