Question about Ritek Ridata Media
Ridata usb formatter - Ritek Ridata Media
Write protected
how to removed write protect in usb flash drive ridata
Apr 07, 2014 | Computers & Internet
Ridata usb drive gb not recognized
All apparatus attached to a computer are equipped with device driver applications whereby the computer hold the communication codes and as such talk to the instrument attached. Either the Computer drivers are not installed or active, or the attached device has a defect.
Jan 24, 2014 | Computers & Internet
What's the Pin code
How to remove write protection on ridata flash drive
Sep 22, 2013 | Plantronics Bluetooth Headset for PS3...
I have hp laser printer model no m1522nf that the device is start but it could not be printed the documents
Question is not clear.. >check copy. is it printing..> check the usb cable is it OK?>Un plug the usb cable,un install the drivers from the system,then connect the usb cable & check whether system recognized the printer? if no replace the Formatter assm, if yes re install the drivers with original CD.. check..
Oct 04, 2011 | HP LaserJet M1522nf Multifunction Printer...
I have used my USB... when im already going to unplug it using the "safely remove USB", a notice pops out that says: <the device Generic Volume cannot be stopped right now. Try stopping the...
Hello marieborja10,
This happens some times when a program is accessing something on the drive. Make sure all files that were opened are closed. Also, make sure any open folders are closed.
If it still fails to eject, it is perfectly safe to pull the USB connector out as long as all programs/files/folders are closed.
Hope this helps!
Jun 29, 2011 | Ritek RiDATA Ultra-M N-S25-256-M 2.5 256GB...
Hi i am using vista, and am using dvd shrink 3.2 version to burn dvd discs i open my disc in dvd shrink then back up in dvd shrink to file created in documents, then dvd drive ejects disk and asks for...
you must remove the region lock off the DVD image you're trying to burn make it region free. your DVD player might have locks on which DVD regions you can play, your DVD writer doesn't come with a region lock that's why you're able to play the disc
Sep 21, 2009 | Ritek /RIDATA DRD+4716-RDSM50 16X DVD+R...
Usb problem
no fear. sorry to say that your usb flash is done for. extracting the information can be done, but it is a specialized job and thus will cost a small fortune. getting it repaired is fairly simple but the information inside might not be attainable due memory chip damage. does your fash disk power up (as in does the light on it flash when plugged unto the USB port)?
babyvalkyrie. your problem is slightly different. what you need to do is log onto the bios menu during startup if the bios recognises the the HDD then you can try to re-install windows on it, but during setup you will have to formatt your harddrive fully (formatt using the long formatt not the quick formatt. also use the ntfs formatt. If your bios does not recognise your HDD then you will just have to replace it.
May 17, 2008 | Samsung 1TB SATA2 7200RPM 32MB HD103UJ 334...
Ritek Ridata Media Logo
Top Ritek Electronics - Others Experts
Are you a Ritek Electronics - Other Expert? Answer questions, earn points and help others
