Question about Kenmore 24 in. 16352 / 16354 / 16359 Built-in Dishwasher
Kemore dishwasher will not start. all lights stay off
Kenmore mod. 665.13743k601
1 1/2 years old
power is getting to the machine
  • 249 Answers
SOURCE: Kenmore 665 dishwasher washing light stays blinking
could be faulty outlet pump
Posted on Nov 28, 2007
jsrock516
  • 5911 Answers
SOURCE: Kenmore Elite Dishwasher Problem
The dishwasher should have a thermal fuse mounted to the control board behind the operator console4.gif. It is a small silver colored device4.gif attached to a white plactic bracket. In some model dishwashers the wrong gage wiring was used causing the wires to heat up and trip the thermal fuse. There was no apparent risk of fire or anything like that, but the thermal fuses didn't tolerate the heat differential too well. A fix for the problem was to purchase a thermal fuse replacement kit (found at most appliance repair stores) that had thicker wires. The part number for the thermal fuse kit is 959376 and the price is $16.85. You can find it at repairclinic.com. Order on line and have the part shipped directly to you. Now...to access the control board perform the following:
1. Turn off the main breaker to the dishwasher. This is important. Even though the dishwasher is not running, the control board still has live voltages present.
2. Open dishwasher door and remove the top screws that hold the console in place. You shouldn't have to remove the lower screws unless you plan on removing the entire door panel.
3. The control panel should pull off from the front enough to where you can access the control board. There is a thermal fuse mounted on the board with two wire leads going to it. The fuse is silver in color and mounted to a plastic bracket which is mounted to the control board.
4. Cut the wires on the old fuse and splice the new fuse kit to it. Leave plenty of wire to accommodate. There will be instructions included with your replacement kit. Ensure you follow the direction thoroughly and tighten the wire lug screws securely.
NOTE: Do not attempt to reuse the existing wires by simply unplugging the old fuse and replacing it with the new one (been there). The fuse will eventually blow again. Follow the instructions provided and you can't go wrong.
If you have any further quesitons, or if you run into trouble during your repairs, let me know. Good luck to you.
PS If you do not wish to order on line, take the part number I provided you to any major appliance repair shop4.gif and they SHOULD have the part available. This is a known problem and a common fail item.
Posted on Dec 15, 2007
melnavz
  • 1226 Answers
SOURCE: Kenmore Elite Dishwasher will not start
Consider examine inside there is maybe fuse busted on the panel or in the circuit through the control panel of the machine.
Posted on Feb 06, 2008
  • 4 Answers
SOURCE: Kenmore ultra wash quiet guard 3 dishwasher problem
call sears, 1-800-4MY-HOME. They have a trouble-shooting department that will get rid of this problem. It is caused by water temperature being wrong at the start of the cycle.... blah, blah, blah. The representative will tell you to push a certain set of buttons in a certain order and that unlocks the dishwasher.
Sorry I don't know the sequence
Posted on Jul 01, 2008
  • 530 Answers
SOURCE: Kenmore Dishwasher - Flashing Lights - wont start
Is the clean light blinking 7 times? If so this means you have a problem with your heating element
Posted on Jan 06, 2009
Starting the dishwashing cycle, extreme loud noise when dishwasher starts pumping water. Loud noise stays during pumping cycle. Dishes are clean and dry and no water in tub when cycle finishes.
If your unit is a Kenmore or Whirlpool (there are several other brands that use many of the same parts) and is less than 6 years old then it may pay to first check and clean out the chopper assembly for hard debris. If that doesn't do it then you may want to consider replacing the motor and circulation pump as a complete unit for between $160 and $200. Not too difficult a task for a moderately handy guy with some tools. Maybe 2 hrs. The bearing itself is not serviceable I understand, and would be considerably more difficult. Over six years old then you can buy a great quality machine for about $500.
I’m happy to assist further over the phone at https://www.6ya.com/expert/howard_977676954994c5b2
Oct 23, 2013 | Kenmore Dishwashers
My Kenmore dishwasher starts to fill and then stops
I've got the same dishwasher....mine is 2 years old and used only 3 times a week and now the motor is burnt out. I understand that this unit is a Frigidaire and is one of the worst ..quality speaking. I guess that why they only provide an one year warranty. Unfortunately, we got a LEMON
Oct 04, 2009 | Kenmore Dishwashers
Kemore Elite Dishwasher Spews Water When Wash Cycle Begins
After further inspection of my dishwasher I found a bad gasket under the lower wash arm. Over the years it finally gave up and was shooting a torrent of water through the water in the bottom of the wash tub. When all that water hit the door liner it went up into the lower door vents, into to wire harness, and onto the floor.
Sep 06, 2009 | Kenmore 24 in. 16352 / 16354 / 16359...
Kemore dryer (Mod#110.66512694) stops running
Reach inside and turn the drum. If it is hard to turn then something may be causing the motor to get hot and quit on overload. An overload is wired into each motor to prevent the copper from melting. If the drum is hard to turn you might want to inspect the rollers and idler. ACCESSING YOUR MACHINE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 16, 2009 | Dryers
Problems
kenmore dishwaher mod. 363.14482100 lower spray arm
wont operate on its cycle and dishes are staying soapy
after dishes done.
Aug 04, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore 665.17012402 Normal Wash Blinking
Replacing push button panel also worked for me! Thanks for the solution.
Dec 01, 2007 | Kenmore 24 in. 17032 Built-in Dishwasher
Kenmore Dishwasher (Sears Canada) 665-16532200
4 years old is not new! you took a risk by not taking out extended warranty and it didnt come off. sorry to be unsympathetic but a fault after 4 years is not unreasonable
Mar 27, 2007 | Kenmore 24 in. 16182 / 16189 Built-in...
Kenmore 24 in. 16352 / 16354 / 16359 Built-in Dishwasher Logo
93 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
