Question about Ford Vehicle Parts & Accessories
Phasors shot f-150 5.4 motor - Ford Vehicle Parts & Accessories
    Problem Solver:
  • 14 Answers
Check out this video on Youtube.
Posted on Aug 18, 2014
I need to find how to insert polar phasor to convert to rectangular complex...
See captured image below. These examples are computed for angles measurement in radians and degrees in two dimensions
Jan 29, 2016 | Texas Instruments TI-Nspire CX CAS...
Phasor addition on classpad 330
Open up keyboard, go to 'cat' tab and scroll down to get ' <( ' symbol.
Input the magnitude followed by angle separated by a comma (E.g. <(15,10) ). The first element in the bracket is the magnitude of the phasor while the second element is the angle.
To do phasor addition simply add more of the '<(' symbol. (E.g. <(15,10) + <(12,5) is the addition of phasor_1 with magnitude 15 and angle 10 and phasor_2 with magnitude 12 and angle 5 ).
Note: the symbol ' <( ' appears at the very bottom of the list and the '<' symbol is actually more flat in appearance like how a normal phasor is usually represented.
Apr 09, 2014 | Casio ClassPad 330 Graphing Calculator
Converting between Forms When working with phasors it is often necessary to convert between rectangular and polar form. To convert from rectangular form to polar form: M = sqrt{A^2 + B^2} f =...
You can switch the display mode for complex numbers by pressing SHIFT MODE down 3 and picking one. This will display the current result in the selected mode.
You can also override the current display mode and specify the format. Add these keystrokes at the end of a calculation: SHIFT 2 then 3 for polar or 4 for rectangular.
Nov 24, 2010 | Casio FX-115ES Scientific Calculator
Xerox phasor 8400 - fault 37,004,40:157517"
Hi I can gave you some error codes but this all I can do hope it be of help to you.
8,009.4x:CAP_FAULT_MP_NO_ CLUTCH_STALL:
  • The media path motor has stalled while moving without the clutch engaged.
33,001.4x - TM_DEV_FAULT_MPT_WIDTH_VALUE_TOO_LOW
  • Tray 1 status:
1. Check the wiring and connectors from the front door to the I/O board.
2. Run the Test Tray 1 Width Sensors.
3. If the test fails replace the front door.
4. Replace the I/O board.
08.055.44:
  • The media path drive module has stalled while engaging the head tilt.
37,008.44:
  • The Preheat preheater is not drawing the expected power from the supply.
Run the Preheat Heater test, check the wiring. If test fails and no apparently problem is evident, replace the preheater.
05,002.42:
  • Problems with the Y-axis. It could be the belt,motor or the drum.
7,008.4x: PM_FAULT_HEADTILT_NOT_ ENGAGED
  • The printhead tilt is not engaged, so it didn't tilt back properly or the printhead is stuck in the tilted position by the tilt lock arms. The process motor gear train getting out of sync can also cause this error.
1. Try rebooting the printer.
2. Check for an obstruction or damage in the process gearbox.
3. Ensure the gears are correctly aligned and homed. If faulty replace the process gearbox
assembly.
4. Run the Tilt Axis Drive test to test the headtilt.
5. Run the Head Maintenance Wiper Clutch test. If the test fails, replace the wiper drive clutch.
6. Run the Wiper Axis Drive test.
7. Replace the exit assembly.
7,010.4x: PM_FAULT_HEADTILT_HOME_ERROR
  • The printhead is stuck in the tilt position by the tilt arms. The process motor gearbox being out of sync can also cause this error.
1. Reboot the printer.
2. Verify the lock arms rotate correctly.
3. Check for spilled ink around the printhead.
4. Check the process motor gears for damage. Ensure the process gears are correctly aligned and homed.
5. Verify the process gear box, process shaft, and drive module shaft are at home position.
6. Verify the headtilt gear will engage, see the home positioning procedure on page. You can manually engage the headtilt gear.
7. Run the Tilt Axis Drive test.
8. Run the Process Motor test.
9. Run the Head Maintenance Clutch test, if the test fails replace the clutch.
10.Run Wiper Drive test. If this fails inspect the wiper drive system.
All The Best: Pineworks
Jan 05, 2010 | Xerox Phaser 8400 Laser Printer
Hi my 2004 5.4 three valve developes a knock after driving for a while , at start up it purs nicely after the knocking happens if you shut the truck off and let sit for a few minutes it is back to normal...
The 2004-2005 had a TSB for noise in the Cam phasers.
Mixed results after having the work done is what I have seen reported.
Some say it is quite as can be, others say it is no better.
Don't know if you had a dealer look at the Cam Phasers yet or not.
Nov 26, 2009 | 2001 Ford F150 Styleside SuperCrew
How to change from phasor/polar form to rectangular form?
Hit [Mode] then arrow down until you can choose Rect, then hit [Enter] then [2nd][Quit].
Aug 30, 2009 | Texas Instruments TI-84 Plus Calculator
Plz Help.....
Either the window switch is bad or the window motor is shot.
Jul 25, 2009 | 2005 Ford F-150
Shutter wont fire, or auto focus
This sounds like mirror box motor problem ( see enclosed shot from our workshop ) : this cocks the shutter and controls mirror mechanism and when the drive dosnt work properly ( small nylon gear on the motor goes ) camera will develop the the sort of problems you describe.
Can be repaired but will cost $ 150-200 so it is relatively expensive repair.
Jun 01, 2007 | Pentax MZ-50 35mm SLR Camera
Vehicle Parts & Accessories Logo
18 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
