Question about Clevo MOBINOTE M548R LAPTOP LCD SCREEN 140 WXGA GLOSSY CCFL (SUBSTITUTE PART NO) (22099281696)
Clevo CMOS battery replacment - Clevo MOBINOTE M548R LAPTOP LCD SCREEN 140 WXGA GLOSSY CCFL (SUBSTITUTE PART NO) (22099281696)
Replace bios battery
I do this all the time; computers have a small round battery within usually on the motherboard area. You can reset your BIOS by taking it out, waiting a few minutes and reinstalling. I have reinstalled maybe 3 as they do last a long time.
Apr 30, 2016 | BattDepot.com Clevo D470W 4400 mAh...
Clevo d9f keyboard replacement needed
If anyone is still interested, there are usually plenty available for a modest price on Ebay, and for reference, the following Clevo laptops use the same keyboard.
Clevo D9 D90 D900 D900C D9T D900T D9K D900K D47 M59 D590.
An OEM replacement can also be found by searching on Ebay for the manufacturer's part number which can be found on the undrneath of the keybord.
Mar 19, 2014 | Clevo D9F Laptop Screen
How do I find and replace cmos battery on Clevo M762T/Sager NP7660 laptop notebook?
Your laptop CMOS battery is CR2032 and instead of writing the instructions on how to replace the CMOS battery I am posting the link where it has been illustrated with images/pictures.
http://www.paulstravelpictures.com/Laptop-CMOS-Battery-Replacement/
I hope this helps, please let me know if you have any further questions.
Best regards,
Amar Sondhi
Nov 20, 2013 | ASUS D1 500 (ap d1500) Barebone
Boot password protected
Try this...may or may not work...laptops are hard to break into, but there may be a way......
If you have forgotten your BIOS or system password, there are no software tricks or magical gimmicks that will get the password cleared. Laptops are different in that they are designed to not work with “backdoors” etc. for security reasons. There is one true way that works most of the time and that is hardware.
The Cmos (RTC) battery that is mounted on the motherboard in most cases holds the key, if your motherboard has the battery that is connected to the motherboard by using a two wire socket that plugs into the MOBO, then here is the procedure.
On the motherboard where the battery plugs into, you will see two pins sticking straight up, these engage the plug on the battery side. These two pins have to be “shorted” and then the motherboard powered up for approx. 30 seconds, then power down the system and replace the Cmos battery and reboot. Only reboot with the AC adapter plugged in, not the main laptop battery. Your password problem should be cleared up. The best way to “short” the pins is get another cmos battery and cut the wires from the battery part, bare the ends and twist together, this will short the pins. Make sure you tape the connection good on the jumper you just made….don’t want to touch anything else with powered up bare wires. Good luck.
If the battery is the disc type and sits in a horizontal socket on the motherboard, then it is a little more difficult to perform but the theory is still good, the positive and negative have to be shorted and the same procedure done. In most cases, just removing the cmos battery does not work in laptops, this is because there is extra security needed because of their portability.
Jan 17, 2010 | Computers & Internet
I need a battery. model# m22bat-8. this is for a p3 direct laptop
google for it you wil see severall sellers also buy online
it works i have also sell a battery
14.8V, 4400MAH, blue,Li-ion Clevo new m22bat-8 2800 d220s d270s m220s laptop battery $ 67,65 one of them http://www.batterylaptoppower.com/clevo/6411.php
Oct 06, 2009 | Computers & Internet
No display on Clevo D41ES laptop
Try connecting to an external display such as a monitor, if it works from a monitor then there must be a problem with your sceen in which case it would need an expert to look at purhapse even the screen replaced.
Jul 02, 2009 | Clevo Computers & Internet
Clevo D47EV inbuilt PC Camera Driver needed
ftp://ftp.clevo.com.tw/D4x0E/Optional/PC_Camera.zip
Jun 05, 2009 | Systemax Neotach 3300 Notebook
I nedd bios upgrade for my laptop clevo m220s
It seems it is a product of SiS. Visit http://www.sis.com.tw and search the BIOS upgrade in the download or support section. If SIS has launched any upgrade for your product, it will be available there. (ehteshamhusain@gmail.com)
Apr 04, 2009 | Computers & Internet
CLEAR CMOS
First switch off at wall and remove power leads. The push on button to discharge capacitors on board.
 The jumper will be located near the bios battery and chip usually at the bottom right of motherboard. Move the jumper to the clear position and leave for a few mins. Then put back into normal postition and start pc up.
If that fails to clear it then repeat but remove the battery from the motherboard too and wait longer.
Hope that sorts it for you?
Jan 06, 2008 | Computers & Internet
Clevo MOBINOTE M548R LAPTOP LCD SCREEN 140 WXGA GLOSSY CCFL (SUBSTITUTE PART NO) (22099281696) Logo
51 people viewed this question
Top Clevo Computers & Internet Experts
David Payne
David Payne
Are you a Clevo Computer and Internet Expert? Answer questions, earn points and help others
