Question about Acu-Rite Acurite Wireless Weather Thermometer 604
Acurite 00605rx wa
How to deactivate the alarm clock
Deactivating the alarm on gigaset A400
Activating/deactivating the alarm clock
Menu
Alarm Clock
OK
Activation
OK
= activated)
This is a toggle. Change activation. Other options are in the PDF.
Nov 26, 2017 | Lands Phones
How do i turn off the alarm on the clock would really like some instructions sent to me
Here are some alarm clock instructions for you.
http://www.acurite.com/media/manuals/13027-instructions.pdf
Jan 05, 2016 | Audio Players & Recorders
Deactivate the hourly chimes in my TAKSUN TS-613A clock?
I am happy to tell you that THERE IS ANSWER:
In normal time mode press S, hold it, then then press D to activate (or press D again to deactivate) the alarm. You will see the symbol of Bell (above the seconds) appear (when alarm is activated) and the bell symbol will disappear (when the alarm is deactivated). Now if you FIRST press and hold D and then press S it will do the same thing (activate or deactivate the alarm). So D then S, or S then D will do the same thing for activation or deactivation of the alarm. BUT, IF YOU HEAR A BEEP (chime) SOUND when you activate or deactivate the alarm, then you actually ALSO ACTIVATED THE HOURLY CHIME!
BUT if you DO NOT HEAR THE BEEP (chime) when you activate or deactivate the alarm, then the Hourly Chime is OFF!
So (in normal time mode) try it both ways: first holding D and then pressing S, or first holding S and then pressing D (one of these will activate or deactivate the alarm WITHOUT MAKING A BEEP (chime) sound - USE THAT SEQUENCE TO DEACTIVATE THE HOURLY CHIME.
I hope this is helpful!
Mar 18, 2014 | Health & Beauty
Could you please send me instructions on how to change the time on my ACU RITE model 00605RX Thank you
http://theguidedb.com/search/the-acurite-weather-stations-00605rx-wa-guide.html
THE ABOVE LINK WILL GIVE YOU THE USER MANUAL. ITS IN PDF FORMAT AVAILABLE FOR DOWNLOAD. THIS WILL SURELY HELP YOU TO CHANGE TIME AND MUCH MORE.
REGARDS.
PLZ. RATE THIS
Jul 04, 2011 | Vacuums
Instructions to 'science museum' radio controlled alarm clock
press the alarm button (so the alarm time is on the screen) then the + button. do the same to deactivate the alarm.
it took me forever to work this out after losing my instructions, feel a bit of an idiot now it seems so simple
Jan 05, 2010 | La Crosse Radio Controlled Atomic Clock
Acu-Rite indoor outdoor thermometer (model 00754) with wireless sensor beeps every couple of hours. Batteries are all new, reset repeatedly, alarm is off.
There is no way to turn off beeping. From this site: http://www.chaneyinstruments.com/FAQ.aspx
found solution - Q: My wireless weather station periodically beeps, why?
A: Make sure that any alert and/or alarm features are deactivated first. Constant, sporadic beeping is generally due to the unit's ability to detect a foreign radio frequency of another wireless unit when that unit transmits a signal. Wireless devices that may cause beeping but are not limited to these devices are; scanners; computers w/wireless keyboard/mouse; or other wireless weather instruments. Essentially, any wireless devices transmitting on a radio frequency have the potential to interfere with each other. Limit the amount of wireless devices to lesson the chance of interference. When beeping occurs, one device will need to be deactivated.
Another external temp gauge showed up on the other channel, so my neighbor or someone is using the similar unit. MY SOLUTION: opened back of case and cut black wire to piezo speaker (at base if rear cover opposite side of stand-up prop) that creates beep. ALL good now.
Nov 24, 2009 | Acu-Rite Audio Players & Recorders
Canceling the alarm
Disable the alarm permanently 1. Press CANCEL button. 2. The corresponding WAKE indicator will be flashing. 3. Press WAKE 1 or WAKE 2 button within 3 seconds to deactivate the corresponding alarm function permanently.
Jun 22, 2008 | GE 7-4809 Clock Radio
Deactivate 2nd alarm
press the button on the top with the clock icon that says (2). the indicator that says "sounds" should disappear.
Oct 29, 2007 | Timex (T307S) Clock Radio
Timex T307S alarms
quickly press alarm 1 button to deactivate it when the radio and everyday or mon-fri icons are gone the alarm is deactivated. do the same for alarm 2 button and the sd1-4 or buz icons disappear.
Aug 09, 2007 | Timex (T307S) Clock Radio
Acu-Rite Acurite Wireless Weather Thermometer 604 Logo
50 people viewed this question
Top Acu-Rite Measuring Tools & Sensors Experts
windryder
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you an Acu-Rite Measuring Tool and Sensor Expert? Answer questions, earn points and help others
