Question about Water Heaters
Where is the ignition plug on a noritz 0751m?
3 Suggested Answers
  • 65 Answers
SOURCE: after freezing weather the Noritz N-0751M-OD
I believe you killed it,I've installed two units direct vented through side wall in Minnesota and the cold wind blew in flu and froze up units,water stopped running in houses so we were able to save
Posted on Jan 28, 2011
senor8
  • 73 Answers
SOURCE: Can we change the orfice
There's a field conversion kit available. Contact Noritz to get more information.
Posted on Apr 29, 2011
How to clean igniter on Mode N-0751M-DV
This is a Noritz Tankless.
That whoosh is excess gas being ignited behind the normal lead/lag time for G-Valve opening and igniter on. Might be the Igniter but you'll need a new igniter gasket as if you pull the igniter assembly and clean ONLY WITH A GREEN SCOTCHGUARD PAD, you'll shred the gasket and need a new one. NEVER sandpaper an igniter it is coated and sanding destroys it.
Also may be a flowmeter signal problem where flow is sensed but ignition signal is slow to igniter but on-time to gas valve opening resulting in excessive gas pocketing in HE before a clean ignition.
I'd say Tech Service Issue as this gas can pocket in the extreme enough to blow the unit off the wall with a late or slow ignition spark.
Sep 07, 2014 | Noritz Water Heaters
Where is the filter on the NR98?
Water filter in tankless is usually located when cold water enters unit... and should be removeable for cleaning once a month
Sep 02, 2014 | Noritz NR98-DVC-NG Natural Gas Indoor...
Does the water heater produce radiant heat to the exterior of the unit
1) No.
NO.
Do NOT store combustibles close to a water heater, fireplace, or any source of ignition, including HVAC, space heater, microwave, appliance, etc.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#bang
2) Tankless water heaters do not have FVIR safety features found in tank-type gas water heaters rated less than 60,000 BTU.
3) Tankless water heaters draw large amounts of air into combustion chamber from surrounding room, and this air feeds directly into the burner flame with no barrier.
4) If flammable vapors enter tankless, then it can cause fire, explosion, conflagration.
5) Read product manual and safe a life.
Feb 07, 2013 | Noritz N-0751M Residential Gas Tankless...
My Noritz N-0751 M-DV makes a loud vibrating noise when I first turn on the hot water. I was advised to flush the system and did but the noise is still there
This sounds like "water hammer"
You can fix this by adding an arrester to the water line. here is a link to what they look like and how they work http://www.plumbingsupply.com/waterhammerarresters.html
You may want to check you water pressure and see if its over 80 psi.
If so then your regulator needs to be adjusted or replaced. If you home does not have a regulator and the city has upped the pressure then you will need to install one. water hammer will break pipes over time and can damage that nice water heater you have.
Jan 10, 2013 | Noritz Residential Heaters Tankless Water...
Have been running extremely hard water thru our Noritz NR98-DVC for a couple of years. Unit is not functioning properly. What, if any, damage could result from using this hard water? Could there be
Replace single-handled faucet cartridge, and see if hot flows to that faucet again.
http://waterheatertimer.org/Crossover.html
Exposing tankless to hard water causes reduced efficiency within a few months, and can cause Total failure of parts within two years.
Do not expose tankless to more than 11 grains hard water.
Here is research pdf conducted by water softener industry comparing tankless andf tank-type:
http://waterheatertimer.org/pdf/Battelle_Final_Report.pdf
To possibly solve problem temporarily, install softening system, delime tankless unit using white vinegar. Delime yearly. It is fun for whole family. And who doesn't like a project schedule.
http://waterheatertimer.org/pdf/Rheem-De-lime-tankless.pdf
To solve problem long-long term, install tank-type gas water heater from local box store for $350.
Oct 12, 2012 | Noritz NR98-DVC-NG Natural Gas Indoor...
What does an error code 66 mean on a noritz Model N-0751M
http://www.noritz.com/u/pages_from_field_manual_2010_12_09_pdf__adobe_acrobat_professional.pdf
The Noritz field manual says that error code 66 is Bypass Water Control Valve failure. Call support at 866-766-7489 with your model #, serial # (both on the unit face plate), date of purchase, to see if the valve can be replaced under warranty.
Jul 14, 2012 | Water Heaters
Dirty hot water
Hi there, maybe the water pipe feeding the tank has a break, allowing dirt to get into the water system - possibly pipe under ground, perhaps you should get a plumber out and have them check all pipes for breaks, if memory serves me right they actually have a tool that performs this task for them.
Jun 29, 2012 | Noritz Tankless Water Heater Natural Gas...
Can we change the orfice on our Noritz N-0751M natural gas to liguid propane?
Mar 30, 2011 | Noritz Residential Heaters Tankless Water...
After freezing weather the Noritz N-0751M-OD started leeking water and now there is no power to the unit or panel..is the unit toast?
Jan 28, 2011 | Noritz NORTIZ Outdoor Propane Tankless...
We hada power outage. The light on the power button from the noritz tankless water heater remote control does not come on.
I'd first try cutting electricity to the unit and then powering it back up; however, there's a good chance you unit was damaged from a voltage surge following the power return. If you have a volt meter, here are a few things to check:
-voltage across the gfi - the gfi is located on the bottom of the unit; it is a black box with a blue, white, green, black, and white wires coming into it. There should be about 100VAC across the blue/white and black/white pairs.
-If there's no voltage across either pair, your transformer is fried and needs to be replaced.
-If there is voltage across the blue/white but not the black/white, look for moisture in the bottom of the unit. If there's no visible moisture (indicating a leak), you may need to replace the gfi.
-If there's voltage on both sides of the gfi, measure voltage at the remote terminals (location depends on model). You should have 15VDC across the terminals. If there's no voltage, your circuit board is dead.
Good Luck!
Aug 04, 2010 | Noritz Tankless Water Heater Natural Gas...
Water Heaters Logo
234 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
