Question about Harmon Kardon Harman Kardon Avr 146 5.1 Channel 40 Watt Receiver
Reset a harmon kamon avr 700 - Harmon Kardon Harman Kardon Avr 146 5.1 Channel 40 Watt Receiver
It says on front screen PHONESIN but there is no one connected
Might be a stuck contact in the headphone jack. Try inserting a headphone plug in there a couple times to see if it clears the fault. If that doesn't work, you probably need to have the headphone jack replaced.
Jun 11, 2014 | Harmon Kardon AVR 700 A 5.1-channel...
Please Help --- We have a Harmon Kardon AVR 700. I just got a new receiver from Dish Network. We had to pull out the Harmon Kardon. Something seems to be unplugged from behind. Now I don't get a...
Hi my nameis Mike Houston of DISH Network and I see where you're not getting a picture buthave sound. There are some things you can check, first you will want to makesure all connections are tight and then make sure you're on the right input toreceive the DISH channels. I will leave a link to help with these steps, http://www.dishnetwork.com/SupportSection/setup-receiver.If you have any questions or concerns please e-mail me, michael.houston@dishnetwork.com.
May 10, 2011 | Harman Kardon AVR 7000
I have a AVR 3600 Harmon Kardon reciever and once and a while the sound will just cut out then come back on. In the display it will change from dolby digital to another format then just come back on. Any...
Looks like the Power relay is switching off and on by itself. Chances are that a power capacitor might be going weak. Get in touch with a Harmon technician to fix this.
Mar 05, 2011 | Harman Kardon AVR 3600
My Harmon Kardon AVR 500 sound doesn't work, I disconnected speakers, re connected & reset protection. Nos ound not even on test mode
Hi it is seem there is no output from your device. Please check the circuit components and wires for malfunction in your Kardon then. Regards
Feb 09, 2011 | Harman Kardon AVR 500 Receiver
Just bought a Sharp LED TV and there is a slight delay between hearing sound and seeing lips move. Have cable box hooked up to tv by HDMI and have cable box hooked to AVR (Harmon Kardon AVR125) by optical...
Hi if there is an optical out on the television i would use that direct to your Harmon Kardon AVR 125, the sound would be in sync with picture, as the source is the same.
Jan 31, 2011 | Harman Kardon AVR 125 Receiver
Problems with setting up Harmon Kardon AVR 146????
in what display i need to put reciver when i use the optical digetal
Oct 19, 2009 | Audio Players & Recorders
Harmon kardon 745 displays "unlock" no sound for tv or movies
I also had this UNLOCK message on my Harman Cardon AVR 130.
The reason for this error was - in a hurry I've plugged the optical input into optical OUT! Double check that your connections in the back are correct and hopefully it fixes your problem.
Cheers,
Sergey
Jan 11, 2009 | Harman Kardon AVR 130 Receiver
Harmon Kardon AVR 630
I ever had this problem, so I contact the service center and they re-program all setting. So,would you like to ask the nearest service center.
May 12, 2007 | Harman Kardon AVR 630 Receiver
Harmon Kardon Harman Kardon Avr 146 5.1 Channel 40 Watt Receiver Logo
69 people viewed this question
Top Harmon Kardon Audio Players & Recorders Experts
Lawrence Oravetz
 Grubhead
Grubhead
Ngoro
Ngoro
Are you a Harmon Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
