Question about Whirlpool Duet Sport HT WFW8400TE Washer
F28 error and door locked button is lit on whirlpool duet steam 4.5 washer machine
  • 51 Answers
SOURCE: door lock error whirlpool duet front loader
DO NOT BYPASS A SWITCH UR HOUSE WILL BE FLOODED INS WILL NOT COVER IT. YOU NEED A DOOR LATCH, AN MMC AN PROB A BELLOWS CAUSE YOU WILL RUIN IT PUTTING THE SPRING CLAMP BACK ON. DO URSELF A FAVOR AN CALL A SERVICE TECH
Posted on May 16, 2009
  • 220 Answers
SOURCE: What id a F28 code on a whirlpool duet washer
Can be the machine control or the motor control here is a link to the Repair manual....
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6545d78b3f479480852571650061b1ba/$FILE/8178558.pdf
Posted on Sep 13, 2009
  • 662 Answers
SOURCE: Duet GHW9150P Front Load Washer: Whirlpool Duet Washer - Error F21 (What is this) ...
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out. Door locked? Press "end of cycle" for 3 seconds, wait for 2 minutes & try the door. F-21 filter blocked.
How abt a nice rating for the free help? Thnks
Posted on May 22, 2010
blueextc3221
  • 15935 Answers
SOURCE: whirlpool duet washer, error code f28
F28 is a serial bus error from the CCU (Central Control Unit) to the MCU (Motor Control Unit).
All you need is some Electronics contact cleaner spray and a 1/4 inch socket to remove the top of the machine and the back of the machine.
The CCU is the computer looking box at the top front right hand corner.
Find connector M13, (has red marking on it and only 3 wires) disconnect it by pushing the retainer tab back and pulling gently on the connector.
Spray the contacts of the connector and computer with connector cleaner.
Then re-assemble connector.
The MCU is in the back lower left corner.
Find the connector with 3 wires and red mark, and remove this connector in the same way you did the other, spray it and re-install.
Put the back and top back on.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
rickead1
  • 1998 Answers
SOURCE: My Whirlpool Duet Front Load Washing Machine is
F28 is a communication error which usually means there is a connection that has come loose. Removing the top and unpplugging and replugging the connectors in will fix 75% of these codes. If the bottom toe panel is not on it will also give you an F28
  • Unplug or turn the circuit breaker off for 30 seconds.
  • Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
  • Press the Pause/Cancel/Stop button twice to clear the display.
  • Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts if you have any further questions message me back and please remember to rank how this opinion has helped in your appliance situation when our chat has concluded Thanks again Rick
  • Posted on Jan 16, 2011
    It starts and then stops and then F28 flashes
    http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3708-whirlpool-washing-machine-fault-codes.html
    Not good! Probably motor control board or motor or wiring harness from control board to motor.
    This leads to a Kenmore Video
    Whirlpool, Maytag, Kenmore. Same machine different name different trim.
    Whirlpool Duet f28 YouTube
    Sep 21, 2014 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool duet steam front loading
    go to this link ........... it will show you step by step solution
    http://www.ehow.com/how_8052747_fix-f28-code-whirlpool-duet.html
    May 06, 2013 | Washing Machines
    The door is locked and cant get clothes out or washer to run. says f28
    you will have to call a tech f28 is a control board failure, or if you are lucky and you have the anti flood hose, to your machine..i would remove them and put standard hose on the unit
    Dec 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool wfw8500sr01 door locks and does not start F24 f26 f28 error codes
    DOOR SWITCH ERROR
    If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds.
    Possible Causes/Procedure
    -Door not opened during 3 consecutive cycles.
    1. Open and close the door.
    2. Verify CCU operation by running a Diagnostic Test or any cycle.
    -Door switch open while door is locked.
    1. Push the door and check if it is completely closed.
    Thanks for using FixYa&^%
    Dec 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Hello Support, I have a Whirlpool Duet Sport Washer and am getting an F-28 error and the door is locked so I cannot get the model number. I've tried unplugging the washer, disabling the connectors...
    Aug 17, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
    F28 code on whirlpool duet washer. The door locks
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^^^^
    Jul 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    I washed a large load in our Whirlpood Duet Washing Machine and it stopped with a flashing F28 code. I unplugged it for 5 minutes and it still will not run a cycle without stopping with a flashing F28...
    The error code F28 means one or both of these parts are bad.
    Motor Control Unit (8540135)
    Microcomputer Machine Control Unit (8540788)
    It would be a good idea to order both, as both components have been problematic for error code F28
    If you find either the MCU or the CCU(Microcomputer Machine Control Unit) fixed it.
    You can download the online repair manual in the below link
    On page# 4-20 it shows how to access your MCU.
    Jun 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool WFW9600T Washer - How do I run diagnostic mode?
    Actually, on my particular whirlpool steam duet model, I had to press the deep clean button four times to make it go into diagnostic mode.
    Apr 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpoo; wfw9200 F22, F28, A17 A27 error codes
    f22 is a door lock error and f28 is a commication error you still have warranty thorugh whirpool. you're going to need pro. help
    Dec 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    F28 ERROR
    I have a Kenmore Elite that has done the same thing, I had to press power and then start (to start a new cycle) then the stop/cancel button and this unlocked my door. Power and then cancel/stop just turned off the power again and did not unlock the door. I hope this works for you.
    Jul 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet Sport HT WFW8400TE Washer Logo
    20 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
