Question about Retail Supplies
Prs-9 coin change coin slot
We have a maytag dryer that is coin operated in our home. We want to shut the coin operated part off. how do we do that?
remove change acceptor usually 5/16 stud bolt in timer mechanism, theb remove change slot stops and reinstalll mechanism and bolt then just push in and pull out just like if you would of used change but dont need two
Jan 31, 2011 | Maytag Coin Operated Stacked...
We want 10 rupees change in 10 coins but don't include 1 rupees coin and 50 pais coin fined out the answer
What coins are available? 5 rupee? 4 rupee? 2 rupee? 1/3 rupee? 1/4 rupee? 1/10 rupee?
10 times 1/10 rupee leaves you 9 rupees short.
8 times 1/4 rupee plus 2 times 4 rupees gives 10 coins and 10 rupees.
6 times 1/3 rupee plus 4 times 2 rupees gives 10 coins and 10 rupees.
Dec 14, 2010 | Computers & Internet
Change the number of coins to operate
you need to take the coin slot apart take pictures as you go to put back together the parts to change amount are hidden inside it in hidden compartment if they wheren't removed by some one. your machine didn't come with the coin mech so if you don't have the parts you will need to take it with you to the parts house to get right parts. open the top of the coin mech box there are 2 long rod screws holding it in place usually 5/16 inch wrench fits may need to wiggle the heck out of it to get it out
Dec 31, 2009 | Maytag Neptune MAH5500B Front Load Washer
How do I remove as coins stuck in cd slot
hi....
there is only one way to remove the coins from the cd slot.....you needed to go for the service center....there they will disassemble it in few seconds and take out the coins and reassemble it very carefully.....so that your cd player also doesn't get any damages in it....it will cost only very little....
if you are satisfied with my solution then rate for me.....
thank you for using fixya.....
Jul 20, 2009 | Sony CDX-A250 CD Player
Bally coin slot machine wont let the handle pull
THIS IS DOCTOR FIX. MY BUSINESS IS GAMING REPAIR. (JUKE BOX=PINBALL= SLOT MACHINES
BOWLING =POKER, FOR 68 YEARS.) IF YOU HAVE NOT SOLVED YOU PROBLEM, I ASSUME IT IS ELECTRONIC, NOT MECHANICAL. IF MECHANICAL , LET ME KNOW, I WILL TELL YOU WHAT TO DO.
ON THE ELECTRONIC, OR ELECTRIC (NO COMPUTER)
THERE IS A BAR MOVES ON TO THE CAM ON TOP OF THE CATCH, ABOUT 3 INCHES ABOVE THE BOLT THAT HOLDS THE ARM IN PLACE, WHEN A COIN IS INSERTED INTO THE COIN SHOOT, THAT METAL BAR ENGAGES THE RATCHET , TO SPIN THE WHEELS. DOES THAT HAPPEN ON YOUR SLOT.? OPEN THE DOOR PULL THE WHITE SWITCH THAT CLOSE WHEN DOOR IS CLOSED (OUT) THESE ARE A THREE POSITION SWITCH.
IN-HOME JUKE BOX REPAIR
SEYLEVITT@JUNO.COM
HOPE IT HELPS.
May 03, 2009 | Bally Walk In 9 8"" X 19 3"" X 7 6"" high...
Coin operated washer and dryer
remove the coin slot out remove the slug used to plug the coin slot
Feb 24, 2008 | Washing Machines
Whirlpool coin operated washer and dryer
you need to take the coin slot out by using a socket wrench. then you need to flip the slot over and take the screws off. there is going to be two more screws to unscrew. take off that piece and also the claw like coin catcher. form here on out you should be able to remove as many slots as you need to.
Sep 06, 2007 | Washing Machines
Retail Supplies Logo
18 people viewed this question
Top Retail Supplies Experts
Electroboy
Electroboy
Are you a Retail Supply Expert? Answer questions, earn points and help others
