Question about Dell XPS Computers & Internet
Slow right click - XPS Dell Computers & Internet
My yahoo is so slow how do i speed it up
For running slow there are many causes:
Microsoft Registry Problems = Slow Computer!
Spyware/Adware
RAM
De-Fragmenting
Etc.
Below can help you speed up your pc:
For IE, click Tools, Internet Options delete files (offline files) clear history (set days to save to 0 if you want) click o.k., and Restart
For Firfox, press ctrl+shift+del, and click clean private data.
Manage your startup:
Open your Start menu -> Click Run -> In the command screen type "msconfig.exe" -> In the "system configuration utility", click either "service" or "startup" tab -> Uncheck all programs that your are no longer using.
De-Fragmenting
1. Right click of C Disk.
2. Click properties.
3. Click tools tab.
4. Click "Defragment now".
5. Click Defragment.
You can search which process full use you cpu, and end the process.
Under steps:
1. right click on the TaskBar.
2. click the Task Manager.
3. click the processes tab.
4. double click the CPU.
5. find if the "System Idle Process" is max.
6. if not right click and click end process.
Learn "Why Is My Computer Running so Slow?" and "How to Speed it UP":
http://downloadlk.net/WhyIsMyComputerSlo...
Use the tool: http://downloadlk.net/themosteffectivere...
May 14, 2014 | Computers & Internet
Program start to slow
Open my computer, right click on C drive, to bottom of box that opens, click on properties, in the box that opens, to lower right, click on disk cleanup, follow that to clean up, try that, if that does not do it, repost but give the program operating system etc
Mar 12, 2013 | Computers & Internet
Pen drive is slow
Slow Transfer on a USB Flash Drive b> Using a USB flash drive is a convenient way of transferring data and files from one device to another. However, sometimes you may find that your USB drive is slow to transfer files onto your laptop or PC. This lag may also cause your desktop or laptop to slow down while you use other programs. You do not need to replace your flash drive and buy a new one. You can fix a slow file transfer problem in just a few steps.
b>Plug your USB flash drive into your computer. Click the "Start" button and select "My Computer." Right-click the USB icon from the My Computer window and click "Properties" from the menu that comes up. Go to the "Hardware" tab and select your flash drive once you find it in the list of items. Then click the "Properties" option in this menu. Choose "Policies" tab within the Properties menu. Turn on the performance optimization option and click "OK." Click "OK" again to exit out of the Properties dialog box. Go back to the My Computer window and right-click on the USB icon. Select the "Format" option from the list of choices. Select the "NTFS" file system and choose "Quick Format." Press "OK" to confirm the choices and to initiate the formatting. Wait for the drive to finish formatting before ejecting it and removing it from the computer.
USB Flash That Is Slow and Damaged
b> USB flash drives are used to transport data between computer systems. Because it is essentially just a small hard drive, the USB device can become damaged and slow down in performance due to viruses or damaged files. To correct these problems and fix the USB flash drive, you must reformat the drive. This removes all data from the drive, returning it to its factory settings.
Plug the USB flash drive into a USB port on the computer system. Close any AutoPlay window that may load onto the screen. Click "Start" then "(My) Computer." Right-click the removable device icon that appears on the screen. Select "Format" from the pull-down menu. This loads a format options screen. Click "Yes" and the computer formats the USB flash drive, removing the damaged content and returning it to the factory settings.
ReadyBoost With a Slow Flash Drive
b>The ReadyBoost feature in Windows has the ability to increase the speed of low-RAM computers by caching program data on a flash memory device. However, the device must meet minimum performance characteristics in order for Windows to enable ReadyBoost, because ReadyBoost may not meet expectations when used on a slower device. If you still want to use ReadyBoost with your flash drive or memory card, you can make a change in the system registry to force Windows to use the device.
Insert the flash device that you would like to use for ReadyBoost. Open the Start menu, and click "Computer" to see the icon for the device. Right-click the icon for the flash device, and then click "Properties." Click the "ReadyBoost" tab at the top of the window. Clear the check from the "Stop retesting this device when I plug it in" box, and then click "OK." Remove the flash device. Open the Start menu again. Type "regedit" in the "Search programs and files" box at the bottom, and then press "Enter" to run the Registry Editor. Double-click the folders "HKEY_LOCAL_MACHINE," "SOFTWARE," "Microsoft," "Windows NT," "CurrentVersion." and "EMDMgmt." Locate and click the folder for your flash memory device under "EMDMgmt." In most cases, you can determine the correct folder because it contains the name of the device's manufacturer. Double-click the registry entry "DeviceStatus" on the right side of the window. Change the number under "Value Data" to "2" and click "OK." Double-click "ReadSpeedKBs" on the right side of the window. Change the value to "10000000" and click "OK." Repeat this process with the "WriteSpeedKBs" registry entry and close the Registry Editor. Reinsert the flash memory device, and return to the "Computer" window. Right-click the icon for the flash memory device, and then click "Properties." Click the "ReadyBoost" tab. Windows now displays an option to enable ReadyBoost on the device. You might install a usb 3 card the speeds are much faster cheap and easy to install. Hope this helps.
Jan 08, 2013 | Electronics - Others
RqmailWhen I try to type something , it is like delayed typing. It prints very slow. Also it takes forever to scroll down the page.
Is it this one website that is going slow or are all websites going slow? If just this website is going slow and all the other websites are going at normal speed then its just the website malfunctioning.If all websites are going slow then i will consider a disk cleanup. You do a disk cleanup by clicking on start, clicking on my computer, right clicking on the c drive, clicking on properties and clicking on disk cleanup make sure temporary internet files is click then do the disk cleanup.
May 08, 2011 | Computers & Internet
MY NOTEBOOK IS STARTING UP VERY SLOW PLUS ITS RUNNING VERY SLOW
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f this should schedule to happen on reboot which will scan for and attempt to recover bad sectors and automatically fix any corrupt files on your hard drive or
control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
defragment your hard drive will speed up your computer
scroll to the bottom toolbar (bottom of screen) right click you can select task manager applications also processes you will see whats running on your computer you might have virus slowing your computer also select users you will see who is using your computer
hope this helps
Jan 13, 2011 | HP Pavilion ze5170 Notebook
My computer is slow and freezes often, its a
System defragmentation will rectify your problem. For Defrag mentation, You should do
1.Right click on My Computer
2.Click on Manage
3.Navigate ComputerManagement\Storage\Disk Defragmenter
4.Select a drive(eg-C:), Right click on it,and click Degragmenter
It will take many hours.similarly do it for all drives.
Jul 13, 2010 | Microsoft Windows 2000 Professional for PC
I m having Intel D845 Chipset GVFN but Speed is slow.
upgrade the ram to at least 512MB - 1GB that will sort the slow speed issue
kind regards
Dec 22, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
Slow performance - Frequent Hanging of system
Do you run the Aero them with the glass windows effects etc. and have the windows sidebar running? I have found that this tends to slow down my computer a lot.
To turn off Aero:
  1. Right click on an empty area of the desktop
  2. click personalize
  3. click window colour and appearance
  4. select colour scheme:"windows vista basic"
  5. click ok
To turn off sidebar:
  1. go to start-> control panel
  2. Click windows sidebar
  3. deselect "start sidebar when windows starts"
  4. click ok
  5. on the task bar right click the windows sidebar icon
  6. click close
Mar 08, 2008 | Microsoft Windows Vista Ultimate Edition
Extremely slow copying
Cartridges may give a very slow printing if internally damaged, or :
When using colored paper in the all-in-one, printing or copying is slow.This issue is a result of the automatic paper type sensor misreading the colored paper as photo paper. The print out takes longer because the unit is printing in Best mode instead of Normal mode.
  1. Click Start , point to Settings , and then click Control Panel .
  2. Double-click Printers and Faxes .
  3. Right-click the appropriate all-in-one, and then click Printing Preferences .
  4. Click the Paper/Quality tab and under Type is: select Plain Paper . This sets the default paper type setting to Plain Paper.
Hope this helps.
Jan 05, 2008 | HP Photosmart 2610 All-In-One InkJet...
Slow/frozen
2.Click on Manage
Dec 06, 2007 | Computers & Internet
Computers & Internet Logo
14 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
