Posted on Jun 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Rx690 I need adjustment program epson RX690... Please
Robert Allocca
Level 2:
Sergeant:
Champion:
  • Epson Expert 387 Answers
  • Posted on Jun 23, 2009
 Robert Allocca
Epson Expert
Level 2:
Sergeant:
Champion:
Answers
387
Questions
Helped
83599
Points
609
Adjustment for what?????? Any maintenance programs are already built in.
1helpful
Replacing waste ink pads on epson rx685
Actually it will very hard for you to access the ink pads for it was designed to be only touched by their service center. I would pressume your printer is giving you errors on waste ink pads full? Try this to reset the counter and be able to use your printer again..
http://fix-your-printer.blogspot.com/2010/04/how-to-reset-epson-stylus-photo-rx690.html
5helpful
PF motor drive error for epson rx690
hi
check if there is any thing that jamed the motor remove that
2- need 2 replace by an expert
How do I change my default print settings
To change your default printer, simply go to start, then settings, then to printer and faxes from there you will find the printer and double click the printer that you want to become your default printer. It will show the check mark to that printer that you choose. Good luck!
Hello my printer is Epson Stylus RX690. the Cyan and black colors is not printing in the paper.what should i do?
The following may work: remove all the ink supplies. Remove the printhead and soak it for about 5 minutes in 0.5" of very hot water. Gently blot the printhead on a soft damp paper towel to remove the excess water, then replace in the printer and then reinstall the ink supplies.
My RX690 will not print red, what is supposed to be red comes out yellow. I have swapped in new cartridges and they are all in the correct locations.
Most likely the Print Head is clogged for that color. You can either do a head cleaning. If that doesn't work.
Take the cartridges out and put a few drops of isopropyl alcohol in the bottom of each head where the ink goes thru. Let that sit for a few hours, then reinstall the cartridges and run the head cleaning cycle a few more times.
2helpful
Printer will only print if i turn off the computer then turn it back on
Sometimes the computer will not detect the presence of the printer, if it was not on. when you turn the PC on. Do the steps in this order
Turn the printer ON first,
Then turn the computer ON.
Hope this will work for you.
If it is helpful, please give a rating.
luciana44
My epson printer rx690 having trouble with waste pad ink. when start printer , it's stuck there and just ask me to turn off printer. any one can help??
hi.think there is software on net to reset ink counter.try ssc software utility in search.varoius options in menu.select your printer in menu.should have option ink counter reset
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
