Question about Frigidaire Microwave Ovens
Microwave continues to run after timer reaches zero
3 Suggested Answers
  • 6771 Answers
SOURCE: timer counts down. Microwave keeps going
It is a bad door switch, or the keypad control board is the issue.
Posted on Apr 12, 2012
Timer stops after 60sec when preheating. Eventually after pressing several individual minutes it reaches preheat temp then will cook for whatever time I want
follow this steps and fix it. God bless you
  1. Main control boardIf your microwave runs for a few seconds and stops, the first thing to check is the main control board to ensure that a shortage has not occurred. If the part is defective then it will need to be replaced to prevent continual shut offs. If this is not the issue, the next step would be to check for a faulty touchpad.
  2. Touchpad/Control panelIf the control board is not the issue and your microwave continues to shut off after running for only a few seconds, the next thing to check is your touchpad, which is also known as a control panel. Although uncommon for this issue, symptoms are usually that the display and some buttons are working properly; however, when selected some buttons are not functioning. If this is the case the touchpad will need to be replaced.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#7#ixzz2Zb4tZMmz
Jul 20, 2013 | Microwave Ovens
Microwave timer doesnt ping off
this is probaly a clockwork timer you are talking about sounds like the contackts are stuck together in the timer pull knob off take screws out probally 2 disconnect wires from timer and replace they are not so expensive
Mar 28, 2013 | Microwave Ovens
Micowave continues running after time is up
This can be two things that I know of 1 is a timer defect and the other is someone has placed some type of metal ie utensil, foil, can whatever into the microwave - either way you should replace the microwave and its a fire hazard to your home and others around you and the cost of a new unit is not worth the losses a fire can bring.
Jan 14, 2013 | Maytag Appliances Over-the-Range Microwave...
Timer counts down. Microwave keeps going
Apr 11, 2012 | KitchenAid KCMS145J Microwave Oven
Round soft key OXO Timer I need to change the clock time their model # is 1061978
Operating functions:
To set the clock, press and hold the clock/timer button for three seconds. A clock icon will appear on the left side of the screen. Input the time using the numerical buttons and then click the clock/timer button to save the time.
To set the timer, press and release the clock/timer button so that the display shows all zeroes. Enter the desired time using the keypad. Press start/stop to start the countdown. The countdown may be paused by pressing the stop/start button and resumed by pressing the same button again.
When countdown is complete, timer will beep continuously for thirty seconds and display will flash. Timer will then beep every ten seconds for ten minutes until the stop/start button is pressed.
This timer will also time up to time activities. To start count up, press clear/memory so timer reads all zeroes. Press stop/start and a plus sign will appear on the right side of the screen as the timer begins counting up.
Sep 18, 2010 | Microwave Ovens
Occassionally (about 5% of the time) the microwave continues to cook and buzz after the timer has run out and the fan stops running.
sounds like the program bord is faulty,, when your finished cooking leave the door open a little that will save the microwave from trying to cook nothing?
Aug 28, 2010 | Whirlpool GT4175S Microwave Oven
Won't power on only timer comes on
I HAVE A SHARP R244 MICROWAVE THE TIMER IS FROOZE AT 1.00 I CAN'T ZERO THE TIMER IT WILL NOT DO ANYTHING
Oct 05, 2009 | Emerson Microwave Ovens
Timer problem
Sounds like your timer board is fried. Replace it.
Dec 19, 2007 | Panasonic NN-T774SF Microwave Oven
Neff oven timer
Normally you enter the time digits, then hit power level then zero or hit the timer button (if so equipped) then enter the time digits and hit start.
Nov 12, 2007 | Neff H7871N2GB Convection / Microwave Oven
Microwave Ovens Logo
12 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
