Question about Konica Minolta Office Equipment & Supplies
PRINT MIRROR IMAGE
When you print you get a second lighter print half way down the page
  • Konica Minolta Master
  • 6,161 Answers
Replace the fuser unit
Posted on Jan 10, 2016
pagebor
  • 2785 Answers
SOURCE: Paper feed accepts paper but
your printer needs servicing
Posted on Apr 23, 2008
SOURCE: Mirror images only
hopefully you have fixed this problem by now----if not, go to control panel bt clicking start then settings or could be start then control panel. WHAT YOU ARE LOOKING FOR IS THE PRINTERS AND FAXES FOLDER. once you have found that, right click on the HP Officejet Pro L7500 Series (or whatever your printer name is) and choose printing preferences. go to the advance tab. look for mirror image and click on it you will be given a small drop down to toggle it from on to off----choose off and the click on apply and then OK.
Posted on Aug 20, 2008
SOURCE: Printing a mirror image
Click on the image and copy and paste it. Take the pasted image and select Format and Flip image. You can then delete the first image and keep the new mirrored image.
I hope this works for you.
Posted on Dec 02, 2008
  • 214 Answers
SOURCE: Printer is printing job as a mirror image
I would have said Gotta be setting in your print dialogue box, but if the test page comes out as mirror image, must be
a setting on printer control somewhere
Posted on Apr 25, 2009
  • 3 Answers
SOURCE: the black print jobs have a shadow about 3 inches down the page
I had replaced the fuser - no improvement. I removed the fuser, imaging unit & transfer roller. CAREFULLY using a vacuum cleaner I cleaned all units and the internals of the printer, rotating the roller on the imaging unit to clean all parts. (Warning Place Imaging unit on paper as toner escapes) After a few test prints the page cleared and duplicate ghosting cleared.
Posted on May 08, 2010
Samsung CLP-310 printer shadow printing on second half of page
I would check that the tension between your fusing rollers is ok as the toner will come off the paper and than return back to paper on its next revolution causing a faint image further down the page
May 19, 2012 | Samsung CLP 310 Laser Printer
My hp 1010 prints only the first page. but from the second page it gives blank print. please help
shake the cartridge well and put it back & check, replace with another cartridge, check half test page if no print on paper check on image on cartridge drum( while printings approx half page open the door remove cartridge & paper check print on paper,on cartridge drum) check transfer roller & replace
If no image any ware replace "Power supply PCA"..
Sep 10, 2011 | HP LaserJet 1010 Printer
I think i have a fuser error. When I print something the right side of the paper is very light in color. If I print multiple pages, it gets lighter by every page.
Put paper in the manual feed tray. Print. When the page gets half way into the printer, open the cover. Remove the toner. Look down at the paper. Is the right side lighter than the left? If yes, replace the toner cartridge. I don't believe that a fuser could cause your problem.
Aug 11, 2011 | HP LaserJet 4240n Printer
Dell Color Laser 1320c printer. The left side of page prints lighter than rest of page - color faded or lighter
I also had this problem with faded print down the left hand side. I decided to strip the printer down. I had to completely remove the laser imaging unit which meant removing all the covers and a couple of circuit boards. I then cleaned the lenses/mirrors inside the open front and laser head (behind a flap with laser warning sticker) with compressed air. This cured the problem but took a couple of hours. I wouldn't recommend doing this unless you are reasonable competent with electro mechanical devices.
Having seen the laser imaging unit out of the printer, it seems a real shame that it wasn't manufactured to be air/toner tight as this could have been achieved at a small cost.
I hope this is helpful ;)
Jun 09, 2010 | Dell 1320c Laser Printer
The black print jobs have a shadow about 3 inches down the page
Apr 07, 2010 | Xerox Phaser 6360 Laser Printer
A copy with a lighter image of the copy on the page
Do printed pages come out better than copies?
If they are the same, you may try another toner cartridge (especially if it is a remanufactured or compatible toner), otherwise, you need your optics cleaned (mirrors and lens under the contact glass)
Mar 06, 2009 | Canon Office Equipment & Supplies
My HP printer 2420 leaves "ghost" prints on the pages.
This can be caused by one of two things.
1. faulty wiper blade on your toner so that the previous image in not being wiped off the drum.
2. worn fuser sleve.
To work out which it is you will need to do a half stop test: print off a normal document then when it is about half way through the printer ( unfortunatly you may have to repeat this to get the timing right) open the front cover. remove the toner cartridge. if you can see the ghosting on the page the it is the toner. if its not there then its a new fuser. to save on money and if your confident enouh you may be able to just chane the fuser sleve depending on the state of the fuser on a whole.
hope this helps
feel free to email me if you have any other questions:
pete@wedotoners.com
Oct 21, 2008 | HP LaserJet 2420 Printer
Mirrored printing
I WOULD REPLACE PHOTODRUM usually this will fix it
Jan 17, 2008 | Lexmark C912 Led Printer
24 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
