Question about Thomson DPL 550HT Theater System
DPL 500 reset - Thomson DPL 550HT Theater System
Can not log-in..forgot password and user name
Search the Internet with the make and model of your router along with the words: default password
If someone changed the default password they are the only one that knows the password.
Go to the manufacturer's website and follow the instructions to reset the router to its default setttings which will restore the original password but you will have to reconfigure it for your network again.
Aug 08, 2011 | Computers & Internet
I forgot my password
No one here has any idea what you set your password as.
Find the hard reset button and press it. It will be by a straight pin inserted through a tiny hole in the bottom or rear of the router. Unplug the device and press the button.
You didn't mention the make or model of the router making it difficult to provide more a more specific solution.
Thank you for your question
May 27, 2011 | Computers & Internet
Need to change seetings but cannot login to router config page because i dont have a password or username.
you did not gave us the router version
so look here for your password http://www.phenoelit-us.org/dpl/dpl.html
scroll down to D_LINK and look for your version and your use and password.
If that didn't work, that means that someone has already changed the password.
Go to the router and reset it and the default password should be here
Could have helped more if the router model was mentioned.
Please rate 4 stars if this helped you. Thank you
Apr 25, 2011 | D-Link Computers & Internet
How can we open the router configuration without password.......& usernane
Dear Friend,
If you don't have change your password from factory defaults then look into manual for user name and password...
If you have change your password then, Sorry you have to reset your router. this will delete all your configuration but will set your login id and password to factory defaults... ( there is no other way)
Please rate the answer
Jun 08, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
Cant get router settings due to lost user name and password need to open ports
There should be a recessed button on the back of the router that you need a paper clip or something similar to access. Press that button down for about 20 seconds and it will reset the router to default settings. Then use the default login/pw to reconfigure it. There is no way to recover a lost password from a router. If you know the exact model of the router, you can download the user manual from dlink's website.
Oct 13, 2009 | Computers & Internet
My prestige 600 has a personalized password to log into it, i have forgotten the password, anyway that i can get into the configurations of my modem?besides having it factory reset.
Hi, you could try to see if there is a back door log in for your model.
You could try:
User name options: root, 1234, admin, blank (i.e. no username)
Password options: 1234, blank (i.e. no username)
Or these links may be able to help you
http://www.phenoelit.de/dpl/dpl.html
http://www.governmentsecurity.org/articles/DefaultLoginsandPasswordsforNetworkedDevices.php
Jul 10, 2009 | Zyxel Prestige 841 (91-004-226010) Modem
Got a new laptop and cannot remember the password for the belkin router i have reset the router but still cannot use it
hi hope this helps:
hold the reset for 15-30 sec while the device is on.
Oct 16, 2008 | Belkin Computers & Internet
Lost my pass word for my D link wireless router
If you lost your password, you'll need to reset the router using the button on the back.
Once reset, then it will have the default username/password
D-Link is normally admin with no password
Jul 06, 2008 | Computers & Internet
Attempting to reset router, forgot password have a new wireless card will not connect. can not open http://192.168.1.1
Hi dprude;
what model is your router? do you remember placing a new password into it? if yes, you might want to do a hard reset, (pressing the reset button at the back of your router to 10seconds) in order to get the default password back but just make sure you know all the settings before doing so because everything will be erased.
try this site for default passwords:
ill be waiting for your feedback :)
Jun 29, 2008 | Computers & Internet
Thomson DPL 550HT Theater System Logo
121 people viewed this question
Top Thomson Audio Players & Recorders Experts
shaun taylor
Shehu Pro
Shehu Pro
 Mikey
Mikey
Are you a Thomson Audio Player and Recorder Expert? Answer questions, earn points and help others
