How to wire a garrison non programmable thermostat model 25-2566
I got this from a friend and it didn't come with the wiring diagram was wondering if you could help me figure out how to wire it up
SOURCE: Wiring diagram for Hunter Model 42260
my thermostat has gone in program mode i can not reset it
Posted on May 24, 2008
  • 8 Answers
SOURCE: Wiring Hunter Thermostat to 6 wire Carrier fa4bnf036
you probably purchased a 4 wire thermostat which we call heat/cool you stated you have 6 wires which signifies a heat pump you have to purcahase a heat pump thermostat and then write down the color of the wires to there related spots example...yellowe-y red-r white- w and so forth also before you do this kill the power the voltage typical for residential is only 24v's but if the wires touch you could blow a fuse
Posted on Dec 15, 2008
SOURCE: rewire an old 2 wire thermostat to a honeywell 5-1-1 programmable
I connected the blue wire to the R and the white wire to the W on the old thermostat and shoved the new Honeywell 5-1-1 Day programmable thermostat up the first guys *** that i ran into at Canadian Tire
Thanks for your help
Posted on Dec 29, 2008
  • 140 Answers
SOURCE: Electrolux Model E switch wiring diagram
The black wire coming from the power cord connects to one side of the switch and the other black and the red wire go to the other side of the switch. If it turns on with the switch in the off position reverse the sides. Good luck. If you need anymore help just ask. Please rate me so I know if I helped. Thanks.
Posted on Dec 31, 2008
hvac1960
  • 2133 Answers
SOURCE: User Guide for Garrison Programmable
Please try with :
x-msg.net/related.../garrison-programmable-7-day-thermostat-user-guide.html
Posted on Dec 30, 2010
Wiring instruction for a White Rodgers 1F78 non-programable thermostat.
The White-Rogers 1F78 thermostat is a single stage 5/2 day programmable thermostat. Home Depot has the manuals for one model of this thermostat, 1F78-151, on the product page: https://www.homedepot.com/p/White-Rodgers-Single-Stage-Digital-5-2-Day-Programmable-Thermostat-1F78-151/202771121 . The wiring diagrams are in the Installation manual. The direct link to this manual is https://www.homedepot.com/catalog/pdfimages/f9/f955280d-67a2-4502-bb94-4975cd857c0b.pdf . Emerson Climate also has the wiring diagram here: http://www.emersonclimate.com/Documents/White-Rodgers/instruction_sheets/0037-6615.pdf .
If you have a different White-Rodgers 1F78 thermostat, check for the manual at Emerson Climate by starting at http://climate.emerson.com/en-us/products/thermostats/thermostat-manuals . Click on the Enter Model Number button and start typing in the model in the search box. I found a number of models with 1F78 listed. After selecting a specific model, I found a link to the installation guide on the left side of the page, below the search box. (Note: the manual link was above the Suggested Replacement header for the models that I checked.)
I hope this helps.
Dec 15, 2017 | White Rodgers Home Security
How do I change the lithium battery in my Garrison Programmable Thermostat Model No. 52-8896-6?
The front faceplate simply pulls off - no tools required. The Garrison uses 3 AA batteries. Once you pull off the faceplate you will see where the batteries go.
Hope this helps!!
Nov 01, 2014 | Heating & Cooling
User Guide for Garrison Programmable 7 day thermostat
Please try with :
Dec 29, 2010 | Heating & Cooling
I tried to insatll my new honeywell programmable. the old t-stat had a white and red wire connected allread. there were 3 other wires unused, G,W,R. I hook up the original R,W wires to the new t-stat and...
The red and white wires go to the R and W terminals on the thermostat. Disconnect what you have now and hook the red wire to the R terminal and the white wire to the W terminal on the new thermostat and see what happens.
Jan 09, 2010 | Honeywell Programmable Thermostat Heater
Wc wiring on thermostat
sounds like you have a heat pump the w2 on old thermostat is for a second stage heat. If you can give me a little more information on type of system you have (forced air furnace with heat/cool, Heat pump or boiler)? How many wires are on old thermostat? Is it a no programmable or programmable? How old is the furnace?
Jan 17, 2009 | Honeywell Programmable Thermostat Heater
I had an old thermostat that i had to change need wiring diagram
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
Dec 20, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
126 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
