Question about Sharp AQUOS LC-32D43U 32 in. LCD Television
AQUOS LC-40E67UN no power - Sharp AQUOS LC-32D43U 32 in. LCD Television
ginko
  • 19396 Answers
SOURCE: LC-37AF3X Sharp Aquos KCD TV
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
  • 8457 Answers
SOURCE: Sharp aquos LC-42D62U. Have audio but no picture.
Ur LCD inverter is dead,must replaced to get the picture back.
Posted on Dec 02, 2009
SOURCE: My Sharp 40
Backlight -6, Contrast 32, Brightness 0, Color 0, Tint 0, Sharpness 0, CMS HUE = R 4,Y 1,G0,C 10,B0,M0; CMS Value R-6,Y0,G-10, C 10, B 10, M0 ColorTemp = Low, Active Contr=Off, Film On, DNR Off, OPC = Off.
Posted on Sep 06, 2010
SOURCE: no sound on my sharp aquos lc-45gd4u 45 in
Assuming you are using the internal speakers, check and make sure you have the audio enabled. Some TV sets have a option to turn off the internal speakers. Also make sure mute isn't turned on. If you are using external audio setup, double check your connections.
Posted on Nov 25, 2012
Lc-40e67un sharp aquos. Power light is blinking in a constant rhythm with no variation. I tried the volume - and input reset. I saw a flash of the channel number and a gray screen for 1 second. Went right...
How many times do this standby light blinks at one time switch On? Count it carefully. These are called blinking codes, and from the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. If you wish to get more details about these blinking codes, check this link.http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 23, 2013 | Sharp AQUOS LC-40E67U 40 in. LCD HDTV
I have a Sharp AQUOS LC-19SB14U 19' LCD TV that won't power on
The main power transistor in the power supply appears to have failed. It has also blown the fuse. Not a job for the DIY'er unless you have serious electronics experience.
Mar 08, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
My Sharp 40'' LC-40E67UN has a dull and dark picture. Tried manual settings, not helpful. They have OPC automatic, not helpful.
Jan 29, 2010 | Sharp Aquos LC-32D40U Television
Television is not recognizing HDMI inputs
there is a possibility that there might have been a power surge sent over hdmi into the hdmi board on the tv. if on your model the hdmi board is seperate from the sine board then youll have a cheap replacement if not its gonna cost you roughly 300-400 is my guess.
call your repair guy
Aug 02, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Have DVI cable plugged in how do i get audio
There should be a HDMI input on the Sharp Aquos with audio inputs next to it. Run a audio cable from the audio out of the satellite box to that audio in next to the HDMI input.
I hope this helps,
Skyassoc
Jul 17, 2009 | Televison & Video
Red Blinking Power Light Sharp Aquos
What do three blinks of the power light mean on my Sharp Aquos LC-C5262U? I cannot power up my display.
Jul 13, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp AQUOS LC-32D43U 32 in. LCD Television Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
