Portable fm/am/sw radio
I recently bought subject radio. it worked fine with batteries. it requires 3v adapter. iplugged in a 6 v adapter and now it is barely auidble. did i really screw it up?
  • Anonymous Jun 26, 2008
    The sound is barely audible.How can it be fixed ?
  • Sarahhelm1 Aug 31, 2008
    I have a Roberts Retro analogue radio and a Panasonic DAB radio - they were connected to the wrong adapters and now neither will work. Is this something that can be fixed?
I assumed this forum was talking about the kaito wrx911 since that was the heading but apparently that is not the case.
does anyone know what happens when a wrx911 is powered by a 6V ac adaptor?  the input voltage is listed as 3V.
Posted on Aug 17, 2008
Upon further reading the kaito wrx911 manual i see where it says to change the batteries if the sound is low or distorted,so perhaps your radio was not damaged by the ac adaptor but is low on battery power.   actually there is sometimes a voltage range that a radio can operate under.  for instance,a radio may be labeled for 4 volt input but actually do fine with five volts.
and with ac adaptors there are always voltage spikes and surges. i was reading something about polarity problems with shortwave radio but im not sure if an ac adaptor would have anything to do with polarity shifts which can damage a radio. the literature i have been reading seems to suggest that using batteries to power the radio is safer than using an ac adaptor.
i attached a 6 volt ac adaptor to my kaito by accident. it was attached for less than one minute.  the radio appears to be working as before.  the manual says attaching the incorrect ac wire "could" damage the radio.
if you have to purchase a new radio perhaps you could still use your other one as a spare travel radio.  the sound is barely audible but perhaps you could use headphones.  doesnt sound like this low cost radio would be worth repairing.
From this point on six volt and three volt adaptors should be of different sizes to prevent this problem from happening in the first place and/or a radio like the wrx911 should have voltage protection.
you may have to purchase a new radio.
Posted on Aug 14, 2008
I also did screw up mine by overvolting it and it fried the FM receiver section. The TUNE light just stayed on and I couldn't hear anything despite the many strong radio stations in my area.
Posted on Jun 10, 2008
Buy a new one....
Posted on Feb 26, 2008
  • 3 Answers
The ATS-909 is a 6 volt radio. It takes 4 1.5 volt batteries; that's 6 volts. Right? The adaptor for my ATS-909 radio is rated at 6 Volts DC. So if the adaptor you connected delivered 6 volts that should not have caused any damage. The center post of the connector should be negitive polarity (-). Your adaptor should indicate the polarity. If the center post of your adaptor is positive (+) that might be the problem.
Does the radio still work with batteries?
Posted on Jan 06, 2008
This radio can use 6 to 9 volts DC.3 volts would not power it fully. 6 volts DC will not hurt it.
Posted on Dec 12, 2007
According to the side of the radio, it uses 12 volts, not 3 volts for the adaptor with the center positive. It uses 4 c cells (6 volts). The reason its "too quiet" is that you don't have enough juice.
Posted on Nov 28, 2007
  • 749 Answers
Yes you did! you overstressed the components of the radio plugging a 6V instead of a 3V adapter!
Posted on Nov 02, 2007
I have a Sangean ATS 818cs portable radio but no 6v lead input
Yes you can use any 6 volt DC for your radio but the most IMPORTANT thing to remember is to connect the terminals in the correct direcction. First of all you can solder a red wire from the positve terminal of the battery and a black wire from the negative terminal of the battery. This must be connected to the source of your 6 volt battery.You can buy a good DC jack socket female to be fitted into the vacant spot of your radio and use a male jack to supply the DC. Only be carefully to see the polarity. To avoid any reversing of polarity use can even connect a diode in the forwarrd bias towards the positve terminal. This will prevent any wrong connection of polarity to damage your set. Helpful? Good day
Jul 13, 2010 | Sangean ATS 818 AM/FM/SW Radio
My SonyICF-2010 works just fine when using the power adapter. However when I use battery power nothing happens. Please help. I love my old shortwave radio. Thanks.
This problem can be caused by a loose external power connector. This will require disassembly of the case and some soldering. it is possible that the battery terminals are corroded if any batteries have leaked.
Apr 12, 2010 | Sony ICF-2010 AM/FM/SW Radio
Dropped my portable grundig s350. Stopped working
Anything could happen in a fall, no telling what needs attention, could be a bad battery connection a cracked circuit board. If it is under warranty send it in if not a good technician is needed.
Jan 24, 2010 | Grundig S350 AM/FM/SW Radio
Sangean ATS-803A - no audio
If its not a micro-p glitch, sounds like the radio was subject to a spike or surge wile plugged into the AC adapter. If the "power" light stays on all the time, thats what happened. Believe me, I was Sangean America's tech from 1990-1995.
The fix is to replace a transistor, or fet in the main pwr supply. (Close to where the adaptor plugs in.)
I wish I could give more details, but its been 14 long, long years.
Jun 03, 2009 | Sangean ATS 808A AM/FM/SW Radio
ICF 2010, no sound suddenly
If the radio does not work with headphone then the external jack for audio may have broken loose from it's soldered points. Simple re solder may make the repair. Beyond that it would have to be diagnosed by a technician.
May 28, 2009 | Sony ICF-2010 AM/FM/SW Radio
Bad adapter?
Dear Kerman,
Sounds like AC hum on your adapter; please find out the adpter voltage and polarity, on the adapter tips, maybe you user manual might have the information. Also the current rating of your adapter.
Try a replacement of the same rating and tip polarity.
That might solve the problem.
Jan 31, 2008 | Sangean ATS 818 AM/FM/SW Radio
ATS 818 Inoperative
Unplug AC adapter from radio. Remove ALL batteries. Wait 15 min. Reinstall batteries
Jan 17, 2008 | Sangean ATS 818 AM/FM/SW Radio
Power problem
Look at right side of radio. Just above the volume knob is the keypad lock switch. Just switch it to the other postition. Should work fine.
Dec 08, 2007 | Sangean ATS 818 AM/FM/SW Radio
AM/SW no longer functioning - FM still works fine
If it can fixed at a reasonable price, it might be better to try to have it repaired.
Hope it helps.
Sep 15, 2007 | Grundig G4000A FM/AM Radio
Sangean ATS 606 A Portable Radio
Remove the battery compartment door and the batteries. There should be a small hole marked "reset" under the upper battery cradle. Press (gently...until it clicks) and hold for 5 seconds. Replace batteries and try again.
Aug 15, 2007 | Sangean ATS 606 AM/FM/SW Radio
583 people viewed this question
