Question about Car Audio & Video
DENSO car audio repair manual - Car Audio & Video
Repair leak in ac compressor
Ed, Check the attached links,instruction and guides on A/C seal replacement. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Rebuild your compressor Just in time for summer too
1993 Toyota Pickup ac compressor seal replacement Google Search
Denso 10S Series Compressor Reseal
Denso 10P Series Shaft Seal Replacement
Apr 08, 2016 | 1993 Toyota Pickup
Tested says #4 cylinder miss fired and transmission switch acting up
Replace you plug wires and fit new DENSO plugs to it. The transmission switch is another story that I can't answer. (I drive manuals which are far less costly to repair and maintain.)
Mar 04, 2015 | 2002 Kia Sedona
What spark plugs are cross refrence for a champion plug RN4C
Oct 12, 2014 | Champion International Champion& Small...
Denso 496310-1000 manual missing
You can find manuals on QB direct, dense support page
Mar 10, 2014 | Denso Office Equipment & Supplies
Toyota Denso Intelligent Tester II Toyota IT2 support all toyota?
Contact the manufacturer on this, we do not have this information.
Aug 24, 2012 | Toyota Toyota Cars & Trucks
I have two Denso BHT-6000 hand held scanners that we have not used in some years. Now we need to use them once again. However, they will not power on even after replacing with new AAA batteries.
There is a good chance that the internal battery is in need of replacement.
We will provide a free analysis and estimate of repair costs for all DENSO.
www.auto-idsystems.com
Thanks ,
Kevin
Feb 02, 2011 | Denso BHT-6045D (4963002560R)
Denso navigation problem
I had the same problem, and then I figured it out. I unhooked the dvd rom opened up the unit and noticed there were resistors on the board which were burned out and the inside of the housing showed slight signs of oxidation. I came to the conclusion that since the unit was mounted in the trunk the unit malfunctioned from water intrusion or moisture, which shorted out the board. Now I'm searching the web to see if I can find a Denso repair facility.
Jan 17, 2009 | 2005 Ford Focus
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
