Question about KitchenAid KEBC101 Electric Single Oven
Remove oven door kitchenaid kebc101kss06 - KitchenAid KEBC101 Electric Single Oven
    Director Badge:
    Uploaded 100 video answers.
  • KitchenAid Master
  • 488 Answers
thats how I did my hinge replacement
Posted on Jun 27, 2015
5 Suggested Answers
  • 3422 Answers
SOURCE: replacing inner door glass kitchenaid kebc208ss
Click HERE for the service manual and refer page no. 21-22
This will solve your problem.
Goodluck,
Please don't forget to rate me as fixya..
Posted on Feb 16, 2008
ginko
  • 19396 Answers
SOURCE: replace inner oven door glass on kitchenaid wall oven
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Posted on Apr 08, 2009
blueextc3221
  • 15935 Answers
SOURCE: kitchenaid kebs107dal4 how do you remove oven door
This OWNERS MANUAL describes removing the door on page 45.
The PARTS MANUAL will give you expanded views and part numbers.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 02, 2009
  • 5370 Answers
SOURCE: How do I replace door
Its not very hard. 1. Open the upper oven door.
2. Raise the door hinge tabs to the "unlocked" position. 3. Close the oven door to within several inches, lift and pull out on the hinges, and remove them from the oven slots. ------------- Click this link to see the door and door hinge parts.http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fW0103109-00003.png -------------- Part number 2 is door hinge.------------ To see more diagram.Please click the link below:--- http://technoanswers.blogspot.com/2011/04/how-to-remove-door-hinges-on-kitchenaid.html ---------------- This should help.Thanks.Helpmech.
Posted on Apr 29, 2011
Replece glass oven door kitchenaid kebs278dss8
Oven doors have at least two panes of glass (air gap between so little ones touching outer glass do not get burned). You remove the screws around edges of door (top, sides, & bottom) and lift frame up and forward to get outer face off. The glass in ovens is tempered to take heat so you can not just use regular glass. You will find outer piece is sometimes the entire size of door but is painted black with the "dot" pattern that lines up with inner piece. Once you get face / frame off you will usually find the handle screws and mounts for inner glass. Sometimes inner glass sealed with high temp sealant. But make sure you use correct glass or someone could get hurt.
Jan 21, 2015 | KitchenAid Ovens
Replacing inner door glass kitchenaid kebc208ss
Goodluck,
Feb 16, 2008 | KitchenAid Architect Series KEBC208KSS...
Model KEBC277 Kitchenaid oven - I need to remove the upper door, but can't figure out how to unlatch the hinge
there will be two hinge latches that you flip to stop the door from closing. This will allow you to push the door in and then pull out the bottom. I do not suggenst using the handle as it may cause damage. use one hand on either side of the door, push the door shut and then lift up a bit and pull the hinges out of the holes.
Oct 26, 2011 | Ovens
Cracked inner oven glass window
Here is a tip that I wrote about the oven door glass replacement...
It is not that hard...
Range/Stove/ Oven Door Glass Replacement
heatman101
Jan 16, 2011 | KitchenAid Ovens
Kitchenaid kebs107dal4 how do you remove oven door for inner glass repair
Sep 02, 2009 | KitchenAid KEBC107 Electric Single Oven
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
Dirty oven window
Try to remove the door. For the Kitchenaid, thereis a hinge on each side with a latch that flips up. Once the door is removed, remove all screws and you should be able to get at glass. Be very careful, the Kitchenaid had four panes of glass.
Jan 08, 2008 | Whirlpool GBD307PRS Stainless Steel...
Kitchenaid Oven
I believe the entire door must be removed first. then remove every screw that you can find and draw a picture where they came from. then split the door open like opening a clam. then you may find additional screws to remove the glass
Jun 02, 2007 | KitchenAid Architect Series KEMC308KSS...
KitchenAid KEBC101 Electric Single Oven Logo
75 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
