Question about Singer Tiny Tailor TT700
Same here! same problem here! It worked flawlessly the first few times. Now I can't get the bobbin thread to raise anymore. help!
  • 136 Answers
No disrepect intended, but get a real sewing machine. can buy decent used serviced and ready to sew for 50 or 60, much better option, no one will touch your tiny tailor
Posted on Jun 18, 2009
HELP PLEASE!!!! Need to figure out how to fix a Singer's Sewing Machine's drop in bobbin casing for my Singer 90s Special Edition???
Sounds like bird nesting or thread nesting (a user error), where there are thread "barfs" under the fabric. This is caused by the top thread not being seated in the tension disk. Remove the thread from the machine. ALWAYS RAISE the presser foot when threading the upper thread!!! Rethread from the beginning. Verify the thread path is correct. Set the upper tension at the midway point between high & low numbers--you'll probably need to tweak it for your particular machine.
Remember, when experiencing problems, install a brand new needle. Remove the thread from the machine, RAISE the presser foot, and rethread from the beginning.
It also helps to always pull the bobbin thread to the top of the fabric, gently hold both thread tails in your left hand, and then slowly take the first couple of stitches.
Understanding Thread Tension Threads
Mar 10, 2017 | Singer Sewing Machines
Most of the time the bobbin stitch is correct. Occasionally there is a loop in the bobbin thread. Any suggestions as to what this could be?
Is it actually the bobbin thread that loops or is the loop appearing on the underside of the fabric as you stitch? If it is a loop under the fabric, that's usually an indication it is an upper thread issue. Thread irregularities that appear on the topside of the fabric are generally bobbin related.
First thing to try is installing a brand new needle. Verify it is the correct needle for the fabric and thread being used.
All About Needles
Sometimes, the fabric being stitched will "grab" the thread and hold it for a second before releasing and will cause a loop. In this case, a needle with a larger scarf and eye may be helpful.
You might also open the upper tension as much as possible, RAISE the presser foot and run a piece of UNwaxed dental floss through the tension disk a few times to clear out any gunk that may be stuck there. A piece of pearl cotton dipped in rubbing alcohol and squeezed moist/dry will also work.
Remove the upper thread. RAISE the presser foot and rethread the top thread from the beginning. Use only fresh, good quality thread--NO old or bargain bin variety! Try using the same thread in the top and bobbin. Make sure the thread is firmly seated in the tension disk and the thread path is correct. Check that there are no burrs or snags in the thread path that could be catching the upper thread. Especially, check that the thread is not catching on the spool "slit" that holds the thread when in storage. Every time the thread navigates around the thread spool, it could be catching on that slit just enough to cause a loop.
Try changing the bobbin. There could be something amiss with the current bobbin--could be nicked or could even be the wrong bobbin for the machine. Also, make sure the bobbin is loaded and turning the correct direction in the machine.
Set the upper tension to the midway point. This is usually the starting point, although it will probably require some tweaking. Test your stitch and adjust the tension so the upper and bobbin threads meet in the middle of the fabric. Neither thread should dominate one side of the fabric or the other.
Last thing to try is a different presser foot.
If you still have the intermittent loop, you might want to take it for service. Could be a problem within the tension disk.
Nov 05, 2016 | Sewing Machines
My Bernette 715 isn't picking up the bobbin thread and is getting jammed. Any ideas what's wrong?
First thing to always try: Install a brand new needle. A dull, worn, or bent needle will cause great frustration. It is also the least expensive resolution to most problems.
Second: Remove all the threads. RAISE the presser foot. Rethread from the beginning making sure it is threaded correctly.
Pull up the bobbin thread before beginning to stitch and hold the thread tails in the left hand while slowly taking the first few stitches:
How and Why to Bring up the Bobbin Thread
If still having issues with not pulling up the bobbin thread, the needle/hook may be out of time.
Sewing machine won pick up bobbin thread hook timing fix
Feb 06, 2016 | Sewing Machines
Hello. I own a Singer 4423 Heavy Duty sewing machine. It has been working fine overall, but today it is giving me problems with jamming. At first it jammed underneath the plate and created a huge ball of...
Make sure thread is not laying across the bobbin when you look down into the plastic slider that covers the top loading bobbin case. The bobbin on mine I observed was loose in the case so that as the machine ran, eventually the bobbin thread would jump out of the stitch finger (the silver piece to the far left of the bobbin case, past the tension slots). I solved this problem and so can you! Take the extra felt spool pin felt in your accessories kit that came with the machine, remove bobbin from case and drop this small felt circle into the bobbin case. Replace bobbin. On the 4423, the bobbin thread goes counter-clockwise and drops into the tension discs, and goes all the back until it falls into the space left of the silver stitch finger. Make sure take up level raised all the way up! Then pull the needle thread toward you until bobbin thread comes all the way up. If you start sewing and you actually can SEE the bobbin thread laying across the bobbin, STOP and tethered because that would mean your thread did not slide all the back behind the silver stitch finger--however, I assure you, if you go one step at a time, you did it correctly! You will be smiling in no time! Why? The felt helps to make the bobbin rest in the correct position to keep it from jumping out of the groove. I hope this helps you.
Jimmy
Jul 29, 2011 | Singer 4423 Sewing Machine
The threaded needle will not pick up the bobbin thread. It seemed to be in perfect shape when last I used the machine, a Pfaff Tiptronic, but now, suddenly, it will now work. The threading of the bobbin...
Hi, here is a few suggestion...........
A few suggestions:
  1. Re-thread top of machine from scratch with the presser foot raised, i.e. remove thread completely from all thread guides & paths and start from scratch, making sure thread is securely seated between tension disks. Once the needle is re-threaded, lower the presser foot and give the tail end of the thread a tug to make sure there's tension on it.
  2. Make sure the bobbin is turning the correct direction for your machine - and that the thread tail is under the tension plate or bobbin tension guide (depending on machine).
  3. Blow out any fuzz.
  4. Insert a new needle, making sure needle is pushed all the way up.
  5. Oil machine (in locations recommended in your owner's manual).
If the basic cleaning and re-threading (above) don't help, your machine(s) may be out of time or have another mechanical issue that will require a repair technician. We recommend a tech trained on your specific brands - they'll be better trained and able to get any repair parts that may be needed.
Take care
Feb 21, 2010 | PfaFF Sewing Machines
How do I load the bobbin on a touch and sew model 775
To thread the bobbin, open the slide plate, make sure the machine is threaded all the way up as normal, take the thread and wind it round a few times round the presser foot screw, push the little lever over near the bobbin to raise the winder, slowly press on the foot control and it will wind the bobbin, when you have enough thread, close the slide plate and draw the thread to the back of the machine and start sewing.
Oct 13, 2009 | Singer Sewing Machines
I can't raise the bobbin thread. The needle raises before the bobbin thread can 'catch'
readjust the hook to just grab the thread loop as the needle raises it will take a few tries to get the exact setting for the hook (maybe you will see a mark on the hook shaft to show you where the hook's set screw was located before it slipped)
May 03, 2009 | Singer 3343 Mechanical Sewing Machine
The bobbin is getting caught and needle is jamming
This sounds like there is cotton stuck in the bobbin holder. Check it thoroughly. Take the bobbin out and turn the wheel to lower the needle a few times. This will show up any thread caught. Pull it out gently. You may have to perservere to get it all out.
Oct 19, 2008 | Singer 15ND Mechanical Sewing Machine
Raising the bobbin
Use a SA 156 metal bobbin (ebay, 20 of them for $8.99 free shipping) and make sure the bobbin thread is turning the right direction, read you manual or call singer at 1-800-4singer
Aug 23, 2008 | Singer 3116 Simple
Sewing Machines Logo
179 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
