Question about Samsung Dryers
Drum roating and clunking
Even with the drum empty it sounds like the drum is off track and it falls onto support
3 Suggested Answers
Rotu
  • 175 Answers
SOURCE: Drum makes a clunking sound when rotating, even when empty
This machine has roller wheels in the front that are not adjustable, but rather need to be replaced if they have a bad spot or something. Usually what I see with a clunking noise(clunks once or maybe two quick clunks in succession) is that the dryer has been set down hard on the ground and has put two dents in the roller surface of the drum. To check this, just unplug it, pop the top off (3 screws in the back and tilt it up) and look at the very front edge of the drum. rotate the drum by hand (carefully so you dont pop off the belt) and look for any imperfections in the suface, such as dents. If you are getting more of a vibration type of noise, I would also suggest taking off the lower front cover then taking of the blower wheel cover located to the left side and checking that there is no lint built up in the blower wheel as well. Good Luck!
Posted on Dec 17, 2006
hunter19_46m
  • 7482 Answers
SOURCE: Dryer is making a clunking noise, even when empty
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication. If you have a front loading machine, Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor. Now is a good time to check the belt condition for wear. Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps Please rate me, Thank You
Posted on Dec 28, 2009
My Washer/Dryer combo will not spin properly when the cycle is on spin. It all just spins sslloowwllyy. There is a sorta bang sound when it tries to spin :-(
if it is a front loader it could be the bearings, or the bracket that holds the drum could be broken (have been known to corrode and fall apart). open the door and try to move the drum up and down by hand. if you get a clunking movement that's your problem - time for a new machine or expensive repair.
Jul 06, 2016 | Washing Machines
My Kenmore stackable washer makes very load noises in the rinse and spin cycle but still works. Anyone have idea why it's making so much noise
Try spinning the drum by hand when empty, the faster the better. Does it sound noisy or is there a grinding sound? It should sound silent or whir as everything turns. If noisy then it may well be the drum bearings. If it clunks then it may be one of the arms that holds the drum in place has broken.
Oct 05, 2015 | Kenmore Washing Machines
Clunking noise
open the door.........hold drum at the top and see if it lifts up a bit................if it does.......the bearing on the drum will be knackerd..............cheers
Apr 15, 2014 | Samsung DV330AE Dryer
I have an LG washing machine Model WM1814CW. It makes a loud clanking sound in the spin cycle and the back of the drum has a thick black greasy substance on it & has leaked onto the floor. What could...
Thanks for choosing FixYa and welcome to the site. It sounds like it is your spin bearings. It would explain the grease and the noise also. The spin bearings have to do with the spinning of the washer. Usually, if there are loud noises associated with the washer, it is either the motor drive or the spin bearing.
Apr 22, 2011 | LG WM2432CW Front Load Washing Machine
Dec 28, 2009 | Dryers
Clunking sound while driving
inner joints a plunging joints have problems acceleration jolts from a dead stop... the outer rezzepa joint clicks usually when turning thats the balls falling out trunion..... not usually clunking ... possible wheel bearings they are pressed in on front wheel drives... or even a tranny mount maybe ...it almost sounds like somethings loose ...its hard to diagnos online..srry i need more info about the symptoms...
May 07, 2009 | 1999 Ford Taurus
Drum set
I USE THE INTERNAL DRUM MACHINE ALL THE TIME, BUT ONLY ONE TRACK AT A TIME PER SONG. I CAN CUSTOMIZE THE SONG BY CHANGING THE TEMPO, STYLE, AND LENGTH. EACH SONG SOUND GREAT. TRY IT. (DAYSHIFT).
Jan 31, 2009 | Tascam 2488 Portastudio Multitrack...
Very loud noise as drum is spinning
Hi, I think that the bearings may be wearing down and need to be replaced. Or the belt may be faulty and needs replacing.
To tell if the bearings are wearing down or need replacing, turn the drum by hand when it is empty and it will make like a grinding noise.
If the belt is torn, frayed or coming off the motor you will need to physically look.
Nov 21, 2008 | Frigidaire ATF6000ES Front Load Washer
Clunking maytag dryer
the machine is opened and inspected from the front
opening from the front there is no heavy lifting or moving of the dryer needed,
the usual causes of a ' cyclic clunk '
a worn spot on a drum felt. when that area reaches the bottom, the weight of the
drum causes a clunk.
a damaged belt that clunks when the tear hits the drum
a collapsing drum roller(replace in pairs)
each is easy to fix, cheap,
Sep 03, 2008 | Maytag Atlantis MDE6400AY Electric Dryer
Dec 11, 2006 | Asko T781 Electric Dryer
Dryers Logo
12 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
