Question about True GDM-12 Refrigerator Commercial
REPLACE COOL CONTROL OR THERMOSTAT FOR TRUE REFER T-23 PART888386
  • rchoo Jun 18, 2009
    HOW TO REPLACE
  • Isaac Garcia May 11, 2010
    I'd like to help you, but can you rephrase your question.
    Novelist:
  • 112 Answers
Not fun the first time. Unplug the unit. There will be a plate with two screws that the thermostat is mounted to either on the right side or right front of the coil cover. Remove the two screws and pull the plate and thermostat down in one piece. Unplug the two wires from the stat and remove the plate from the stat making sure to note which way the plate and thermostat are oriented. The thin capillary from the stat runs up to the back of the coil. You have to reach your hand into the opening created by removing the plate and feel your way to the capillary entrance at the coil. You may be able to just see it through the hole. Make a good mental note of its position in there and pull the old capillary out. Measure how deep the capillary was in there and try to get that far in with the new one. I generally put a little piece of tape on the new capillary about where I want it to stop at the coil. You just want to make sure the capillary is clear of any wires and doesn't rub against anything in its routing. Reinstall is reverse of uninstall.
Posted on Dec 12, 2010
How do you get the heater to work on a 2003 Chevy venture mini van
When you change the mode from floor to vent to defrost do you hear switching taking place behind the dash or inside ?
Air Delivery Improper
Test Description
The numbers below refer to the step numbers on the diagnostic table.
The measured voltage should be near the specified values for each mode position.
The HVAC control module is supplied by two ignition 3 voltage circuits. Test the ignition 3 voltage circuit that does not supply the blower motor switch.
Step
Action
Value
Yes
No
Schematic Reference: HVAC Schematics
Connector End View Reference: HVAC Connector End Views
DEFINITION: Air does not flow correctly from the air distribution outlets.
Did you perform the HVAC Diagnostic System Check?
YES - Go to Step 2
NO - Go to Diagnostic System Check - HVAC Systems - Manual
Turn ON the ignition, with the engine OFF.
Place the blower motor switch in the OFF position.
Is the blower motor OFF?
YES - Go to Step 3
NO - Go to Blower Motor Always On
Place the blower motor switch in each speed position.
Does the blower motor operate at all?
YES - Go to Step 4
NO - Go to Blower Motor Inoperative
Does the blower motor operate in each speed position?
YES - Go to Step 5
NO - Go to Blower Motor Malfunction
5
Except for the blower motor speed, are all of the functions of the HVAC control module inoperative?
YES - Go to Step 14
NO - Go to Step 6
6
Place the blower motor switch in the maximum speed position.
Place the mode switch in the vent position.
Place the recirculation switches in the recirculation position and in the outside air position.
Does the recirculation door move to the correct position for each selection?
YES - Go to Step 7
NO - Go to Air Recirculation Malfunction
7
Place the mode switch in each position.
Is the air flow sufficient from the correct outlets in each mode?
YES - Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
NO - Go to Step 8
8
Inspect the air distribution system for the following conditions:
• A dirty HVAC air filter, if applicable
• An obstruction to the air flow
• Air leaks
• Misaligned air ducts
Did you find and correct the condition?
YES - Go to Step 23
NO - Go to Step 9
9
Inspect the mode door and the mode actuator for the following conditions:
• A misaligned mode actuator
Refer to Mode Actuator Replacement .
• Broken or binding linkages or mode door
• An obstruction that prevents the mode actuator from operating within its full range of motion
• Missing seals to the mode door
• Misaligned seals to the mode door
YES - Go to Step 23
NO - Go to Step 10
10
Turn OFF the ignition.
Disconnect the mode actuator.
Probe the ignition 3 voltage circuit of the mode actuator with a test lamp that is connected to a good ground.
Does the test lamp illuminate?
YES - Go to Step 11
NO - Go to Step 20
11
Test the ground circuit of the mode actuator for an open or high resistance. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
YES - Go to Step 23
NO - Go to Step 12
12
Measure the voltage from the mode door control circuit of the mode actuator to a good ground.
Place the mode switch in each mode position while observing the voltage.
Does the voltage measure near the specified values for each mode position?
Vent 0.2V, Bi-Level 3.0V, Floor 6.0V, Mix-Blend 9.0V, Defrost 12.0V
YES - Go to Step 18
NO - Go to Step 13
13
Test the mode door control circuit of the mode actuator for an open, high resistance, short to ground, or short to voltage. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
YES - Go to Step 23
NO - Go to Step 19
14
Test the ignition 3 voltage circuit of the HVAC control module for an open or high resistance. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
YES - Go to Step 23
NO - Go to Step 15
15
Test the battery positive voltage circuit of the HVAC control module for an open or high resistance. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
YES - Go to Step 23
NO - Go to Step 16
16
Test the ground circuit of the HVAC control module for an open or high resistance. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
YES - Go to Step 23
NO - Go to Step 17
17
Test the off blower motor control circuit of the HVAC control module for a short to voltage. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
YES - Go to Step 23
NO - Go to Step 19
18
Inspect for poor connections at the harness connector of the mode actuator. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 23
Go to Step 21
19
Inspect for poor connections at the harness connector of the HVAC control module. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 23
Go to Step 22
20
Repair the ignition 3 voltage circuit of the mode actuator. Refer to Wiring Repairs in Wiring Systems.
Did you complete the repair?
Go to Step 23
21
Replace the mode actuator. Refer to Mode Actuator Replacement .
Did you complete the replacement?
Go to Step 23
22
Replace the HVAC Control module. Refer to HVAC Control Module Replacement .
Go to Step 23
23
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 8
Mar 14, 2017 | Mini Cars & Trucks
My 1999 Jeep Grand Cherokee Limited sun roof does not want to open.
If your motor is audible and your fuses and connectors are okay, you may have to take a close look at the plastic gear parts up in the roof. The nylon parts do wear out since they are in the roof and more exposed to different temperatures. If any of that mechanism fails then your sunroof will stop working even if the motor is still good. It is a bit of a PITA to get to it since you will have to remove the headliner to get at the mechanism and then identify the worn part and replace it CAUTION: The sunroof system is timed from the factory so that the motor shuts off automatically when the sunroof window reaches a certain position. Extreme care must be taken when removing the motor, timing may be thrown off causing possible damage to the sunroof system. Anytime the motor is removed from the sunroof assembly the sunroof glass panel must be in the FULLY CLOSED POSITION or the unit will be out of timing. The drive motor cannot be reset to the park position after being removed.
CAUTION: The sunroof motor should only be powered through the vehicle battery and sunroof wire harness. Applying power to the sunroof motor leads will cause failure of the control module.
Move glass panel to the fully closed position.
Remove the A-pillar trim. (Refer to 23 - BODY/INTERIOR/A-PILLAR TRIM - REMOVAL)
Remove the B-pillar upper trim. (Refer to 23 - BODY/INTERIOR/B-PILLAR UPPER TRIM - REMOVAL)
Remove the C-pillar trim. (Refer to 23 - BODY/INTERIOR/C-PILLAR TRIM - REMOVAL)
Remove the D-pillar trim. (Refer to 23 - BODY/INTERIOR/D-PILLAR TRIM - REMOVAL)
Remove the sunvisors. (Refer to 23 - BODY/INTERIOR/SUN VISOR - REMOVAL)
Remove the overhead console. (Refer to 8 - ELECTRICAL/OVERHEAD CONSOLE - REMOVAL)
Disconnect the control switch wire connector.
Remove headliner as necessary to gain access to sunroof drive motor. Refer to Headliner Removal and Installation for proper procedures.
Disconnect the drive motor wire harness connectors (Sunroof Drive Motor and Express Module).
Remove drive motor fasteners and remove motor from the sunroof housing
Sep 29, 2016 | 1999 Jeep Grand Cherokee Limited
Hello my freezer is not cooling properly and the defrost timer is . making a loud buzzing noise. Please help
Your freezer compartment will freeze up and not cool properly if the defrost timer does not allow the unit to go into its self defrosting mode to get rid of the ice that serves as an insulator.
Replace the timer.
Jan 19, 2015 | True T-23F 23 Cu. Ft. 1 Door Freezer
Refrigerator has to be on the highest setting to cool. The freezer is working fine.
check back of freezer look for frost if there you have a bad defrost control.the defrost control is on refer side near thermostat to the right
Oct 06, 2010 | Maytag MZD2766GES Side by Side...
Light removal
get a screw driver and loose the light holder and replace it a new one bought .
May 03, 2010 | True 23 cu. ft. / 651 liter Commercial...
The fridge freeze the food
The thermostat is probably stuck closed and bad. A good replacement would be a Ranco A12-1560. If its not the thermostat there may be a stuck relay on newer modes coolers.
Nov 05, 2009 | True GEM-23
Box Not cooling
Jumping wires out is a good way to KILL SOMEBODY!!!!! You have no idea what you are doing, PLEASE unplug it and call a refer guy.
Apr 09, 2008 | True GDM-26 Refrigerator
Refrigerator stops running
if you are sure that the fridge thermostat is the one stucking up then replace that thermostat.
when you say for a while, how long?.. 5 minutes?...10 minutes?...or long enough to cool the fridge?
Feb 22, 2008 | Whirlpool GS6NBEXR Side by Side...
True GDM-12 Refrigerator Commercial Logo
983 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
