Computers & Internet Logo
A
Anonymous Posted on Apr 15, 2014
Sakeplan voorbeeld i need an example of an bussinessplan
Figurative language -idiom examples for kids
There are many different forms of figurative language; in Key Stage 2 English your child is likely to be introduced to the following:
Simile
A simile is a comparison phrase which finds similar characteristics in two objects and compares them, always by using the words 'like' or 'as'. For example:
The pond was like a shiny, round coin.
He ran as fast as a high-speed train.
Metaphor
A metaphor is a comparison which is not literally true. It suggests what something is like by comparing it with something else with similar characteristics. It is like a simile, but instead of using 'like' or 'as' it compares by suggesting that somethig is something else. For example:
He was putty in her hands. (Meaning: he could be easily manipulated by her.)
You are the light of my life. (Meaning: you give me hope and happiness.)
Personification
Personification is a type of figurative language which gives an object human characteristics (emotions, sensations, speech, physical movements).For example:
The branches of the tree danced in the wind.
She was swallowed by the waves in an instant.
The warm sun smiled down on us.
Onomatopoeia
This is when a word makes the sound of the thing it describes (for example: boom, honk, pop, crack, cuckoo, crack, splat, tweet, zoom, sizzle, whizz, buzz, hiss, rip).
Hyperbole
This is when exaggeration is used for effect. For example:
I had to read a book that was about a million pages long.
The children were so excited they were bouncing off the walls.
1helpful
2answers
My instruction manual was destroyed...need to print new manual
try typing in the name and model number of your cell phone and see if you can find one
example( Motorola 2020 manual)
or
example( cell phone Motorola 2020 manual)
or
example( android 2020 manual)
Apr 20, 2016 • Cell Phones
2answers
Mla work cite poem
Including a link with samples on MLA work cites.
Purdue owl
Ik ben geblockt op mijn hotmailadres nu zegt men daar dat ik op [email protected] een code kan zien om dit weer te openen, hoe kom ik daarin??
Ga naar deze website en volg de instructies
https://account.live.com/password/reset
Uw wachtwoord opnieuw instellen
Account ?
Uw wachtwoord opnieuw instellen, voert u uw Windows Live ID en de personages in de afbeelding hieronder.
Windows Live ID:
Voorbeeld: [email protected]
I need to know what the power consumption is for my serger as we will be moving off the grid. thank you.
Hi gladysmorin...
We would need the info from your metal tag on the surger motor before we can tell you what the power consumption would be.
So you will need to look on the metal tag that is attached to the surger motor and retrieve that information, you will need the amperage and the voltage.
But you can also figure out how many watts any appliance will consume in power...you will do some math.
If you want the watts,volts or amps for a given appliance follow the examples below:
Amps X Volts = Watts
example: 3.0 amps X 220 volts = 660 Watts
Watts ( / ) divided by Amps = Volts
example: 100 watts ( / ) divided by10 Amps = 10 Volts
Watts ( / )divided by Volts = Amps
example: 60 watts ( / ) divided by 120 volts = .5 Amps
( / ) = the right slash means...divided by.
Please take time to rate me
I heb de Dell All in one printer A810 en hij doet alles behalve het volgende: Ik scan een document, wil dit per e-mail versturen, hij komt goed op het scherm bij voorbeeld, kan verzenden. Tot zover gaat...
Hallo Rose,
Probeer het formaat van scannen goed te zetten.
Het kan zijn dat de scanner groter of kleiner scant dan het papier.
Of scan het gewoon en verzend het als bijlage.
Derde optie is om de software te updaten.
Groetjes!
Straps to be attached to back of 3 in one 2009 model. Where do you fasten straps on the back of the seat?
you need to provide more information (type of car seat, model of car) for an accurate answer, however:
most (if not all) car seats made these days have a ******** either side with a clip like this on the end (http://www.babysafetycarseat.info/wp-content/uploads/Car%20Seat%20Latch.jpg) which attaches to two hooks located between the seat cushion and the back cushion (http://autostol.info/wp-content/uploads/2010/08/Isofix-voorbeeld-11.jpg).
simply attach the clips to hooks, put your weight on the car seat while pulling the straps tight, and you're done.
Feb 28, 2011 • Baby Gear
Can't change it from dutch to english
try other country code maybe this one help you see following:
for example HT752GB02164 will give you a English-WWE or Arabic rom.
for example HT751GB06969 will give you a English-WWE or Arabic rom.
for example HT751GB10969 will give you a English-WWE or Arabic rom.
for example HT751GB07164 will give you a English-WWE or Arabic rom.
for example HT751GB10164 will give you a English-WWE or Arabic rom.
for example HT750GB02164 will give you a English WWE rom.
for example HT736GB05969 will give you a English WWE rom.
for example HT736GB03969 will give you a English WWE rom.
for example HT738GB06164 will give you a English WWE rom.
for example HT751GB16969 will give you a English WWE rom.
for example HT751GB17969 will give you a English WWE rom.
for example HT751GB18969 will give you a English WWE rom.
for example HT751GB19969 will give you a English WWE rom.
for example HT751GB17164 will give you a English WWE rom.
for example HT751GB18164 will give you a English WWE rom.
for example HT736GB02164 will give you a Russian rom.
for example HT736GB01969 will give you a Russian rom.
for example HT736GB00969 will give you a Russian rom.
for example HT738GB02164 will give you a Finnish rom.
for example HT736GB20969 will give you a French rom.
for example HT736GB08969 will give you a French rom.
for example HT736GB04969 will give you a French rom.
for example HT736GB02969 will give you a French rom.
for example HT736GB13969 will give you a French rom.
for example HT750GB17164 will give you a French rom.
for example HT738GB26164 will give you a French rom.
for example HT738GB27164 will give you a French rom.
for example HT738GB28164 will give you a French rom.
for example HT752GB24164 will give you a French rom.
for example HT736GB22969 will give you a Spanish rom.
for example HT736GB16969 will give you a Spanish rom.
for example HT752GB20164 will give you a Spanish rom.
for example HT750GB08164 will give you a Italien rom
for example HT750GB09164 will give you a Italien rom
for example HT750GB11164 will give you a Italien rom
for example HT750GB13164 will give you a Italien rom
for example HT736GB23969 will give you a Italien rom
for example HT736GB12969 will give you a Italien rom.
for example HT750GB16164 will give you a Italien rom.
for example HT752GB03164 will give you a Italien rom.
for example HT752GB04164 will give you a Italien rom.
for example HT752GB05164 will give you a Italien rom.
for example HT752GB09164 will give you a Italien rom.
for example HT736GB09969 will give you a Dutch rom.
for example HT736GB11969 will give you a Dutch rom.
for example HT736GB17969 will give you a Dutch rom.
for example HT751GB03969 will give you a Dutch rom.
for example HT751GB03164 will give you a Dutch rom.
for example HT751GB04164 will give you a Dutch rom.
for example HT751GB03165 will give you a Dutch rom.
for example HT751GB04165 will give you a Dutch rom.
for example HT738GB25164 will give you a German rom.
for example HT738GB30164 will give you a German rom.
for example HT738GB31164 will give you a German rom.
for example HT750GB14164 will give you a Portuguese rom.
for example HT738GB04164 will give you a Swedish rom.
I need good example of er diagram
Hello
Click here or here to get detail with examples of ER Diagram.
Hope this helps
My pc cannot detect my cellphone
Please re-post your question and include the make and model number of your phone (example: Samsung Jack SGH-i637) and include the type of computer you are using (example: PC or Mac) and the operating system (example: Windows XP). Also include the program you are using (example: Motorola Phone Tools or Samsung PC Suite, etc).
We need more information to assist you. Thanks!
Jan 15, 2011 • Cell Phones
Grand Canyon Tech
Grand Canyon Tech
