Question about LG Refrigerators
Our LG refrigerator freezer model GR=A207BLQ WORKS FOR PLUS MINUS 12 HOURS THEN AN ERROR CODE "oH" APPEARS. BY SWITCHING OFF AND ON AGAIN ALLOWAS FOR 12 HOURS OPERATION. HOW CAN WE OBTAIN THE ERROR CO
MODEL GR-A207BLQ error code "oH"
SOURCE: Kenmore Coldspot Model 71182101
I have the same problem. The refrig and freezer are cold but not freezing and not cold enough. I have a friend tell me it probably is the relay. His did the same and that was the issue.
Posted on May 23, 2008
  • 110 Answers
SOURCE: LG Refrigerator Defrost Error ER DH
it the def t-stat, def. thermistor, or def. fuse whatever lg decides to call it this week that is causing your issue
Posted on Jun 13, 2008
  • 110 Answers
SOURCE: LG Refrigerator Defrost Error ER DH-- Defrost fuse
the fuse is in the fz compartment behind the evap cover panel once you get the panel off it will be at the top right-hand corner wedged between the evap coils
Posted on Jun 23, 2008
  • 1122 Answers
SOURCE: where is this fuse located on the LG refrigerator is displaying a ER DH code error
GO TO SEARS .COM ,CLICK ON PARTS,PUT YOUR MODEL NUMBER IN AND YOU WILL FIND WHERE THE PART IS,LET ME KNOW-MIKE
Posted on Jul 07, 2008
SOURCE: LG GR-292R freezer works/fridge does not.
well i have the exact same refrigerator but opposite problem.... the freezer works but the entire refridgerator is a freezer....why is the fridge part freezing everything. This appeared to happen after the power went out and the entire fridge is a freezer now.
Posted on Dec 18, 2009
LG GR-B206GTQA Fridge Freezer ER CF Error Code
The fan is almost certainly run by a sensor in the condenser. If it doesn't get hot enough, the fan doesn't run. Sounds like short of gas. Try wiring the fan to the compressor live and see if it runs all the time then.
Apr 18, 2014 | Refrigerators
The fridge is not cooling. Error ER DH showing on door. Freezer works fine. Was told that the PCB board is to be replaced as well as the defrost module. Cost will be approx $600. Can you advise o
The "Er dH," also known as the Defrost Heater Error message, is displayed when the unit fails to reach 46? F within 2 hours of beginning its defrost cycle. This may be an indication of the defrost heater having broken or the temperature fuse having been pulled out of its slot. Contact customer service if the problem persists after having attempted a system reset.
Quick Fix
  • Unplug the refrigerator for 30 seconds and then plug it back in. Doing this will reset all the codes. Sometimes an error appears by fault. If it does not appear again after restarting, then the refrigerator is fine. If the code appears again, then there is a problem with the defroster.
Defroster Problem
  • The error code itself means that the defroster mode has failed. This means that the defrost mechanism cannot reach 46 degrees Fahrenheit within two hours to defrost ice in the freezer properly. Unplug the refrigerator and move all the items that can spoil into a backup fridge or freezer.
Repair
  • Look in the back top of the freezer. Use a screwdriver to remove the ice maker machine that blocks the back defrost panel. Remove the two side screws and pull away the plastic cover guard. Check the wire. If it is unplugged, then secure it to see if that is the problem. If the plug is connected, then remove it to check for more problems. Look for any faulted wires on the defroster. If it appears that the wires are fine, you need to replace the defroster panel. Contact your local LG dealer for the specific part number
Read more: http://www.ehow.com/info_8705867_lg-refrigerator-error-code-erdh.html#ixzz2udv3MZKA
Feb 28, 2014 | LG LFC21760 Bottom Freezer French Door...
LG Fridge-Freezer model no. GR-T632DVQ The upper freezer lights works. The lower fridge light stopped working. When tested the light bulb works and is NOT broken. There is a combination double...
looking for a door for lg refrigerator GR-T632DVQ
if anyone can help me plz ring 0421203100
perfect fridge, had it for 10 years, door fell off today :(
i've been searching everywhere, *sigh
please help if u can
Mar 16, 2011 | Refrigerators
LG LFC25760 not working
This error appears when the fridge goes into defrost mode (after a few hours of initial startup and therefore a sign that your PCB is probably just fine). Look into the thermostor in the freezer compartment (mine was bad, a $2 part from Radio Shack), the defrost heating element or the temperature sensor in the freezer compartment.
May 03, 2009 | LG LFX25960 Bottom Freezer French Door...
Mar 02, 2009 | LG LFD25860
Error Message: Er dH
The error codes are listed in the service manual (p. 32) at the address below:
LFX25960 Service Manual
"Er dH" seems to be a defroster issue.
Aug 14, 2008 | LG LFX25960 Bottom Freezer French Door...
Jun 13, 2008 | Refrigerators
Error Code ER FF
FF is your freezer fan. You may need to defrost the unit.
Feb 28, 2017 | LG French Door Cabinet Depth Refrigerator...
Refrigerators Logo
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
