Question about Hotpoint HSS25GFP Side by Side Refrigerator
Not cooling properly
Cooling at 57 degrees instead of 35
2 Suggested Answers
SOURCE: Fridge part not cooling properly
Evaporator motor needs to be replaced. It sits in the middle of the freezer. You need to take the back off. It is 20 minutes job.
Part number: WR60X10074
Good luck.
Posted on Mar 17, 2008
Wine cooler too cold
The 2 @ 47 degrees may be low in refrigerant gas. Refrigerators are design to operate with an exact amount of gas. When the gas charge gets slightly low the system will operate colder for a time and when the gas charge loses a couple of ounces the system stops cooling. Another cause may be the thermostat isn't operating properly and or the temperature sensing bulb may be too close to a source of heat.
Feb 09, 2014 | Frigidaire 35 Bottle Wine Cooler
Fridge won't cool below 60, freezer won't go above 20
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 08, 2011 | Refrigerators
Refrigerator is not cooling, but instead temp keeps going to 57 degress. why?
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 19, 2010 | Sub-Zero 736TCI Refrigerator With Ice Box
My chevy venture 2003 only over heats when it is still with the engine on but it does not over heat when i drive it, what could it be?
Odds are your electric cooling fan[s] isn't coming on. This fan should only run when the a/c is on or when the engine temperature has reached about 218 degrees. Once the a/c is off or the engine temp drops to about 210 degrees it shuts back off again. It rarely comes on at speeds over about 35 mph because at that speed enough air is forced through the radiator to keep the engine at about 198 degrees. I would start by looking for a blown 30 amp fuse under the hood. There may be two of them marked "Cooling fan 1" and "Cooling fan 2" or something similar. If the fuses are good you could have a faulty cooling fan motor that just isn't running. Hope this helps a bit!
Jul 08, 2010 | Chevrolet Venture Cars & Trucks
Norcold fridge not cool enough
Yes very likely the cooling unit has stopped working. You need to do a bypass test by unplugging the thermistor on the inside of fridge. It will be attached to the fins. Give it 6 hours or so and check your temps. If they are the same the cooling unit is bad. If the temp goes down the thermistor or circuit board is bad. If you need more assistance feel free to call.
734 777 6432
Jan 25, 2009 | Refrigerators
Profile refrigerator section not cooling
We are not sure what precipitated the temperature swing up; however, within about an hour of emptying quite a lot of foodstuffs from top and bottom sections of the unit, I felt the cold air start to flow out of the rear vent. Within two hours, the upper section had dropped to about 50 degrees and by the next morning to 36. The freezer seemed to recoved on its own too, having risen to almost 8 degrees and then recovering to 0. Just patience and a smaller food payload?
Oct 02, 2008 | GE Profile PSW26P Stainless Steel Side by...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
12 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
