Question about Drive Medical Silver Sport (2) 18 Wheelchair Black
Will not move
Belts r good have power
    Top Expert:
  • 10,875 Answers
Http://www.drivemedical.com/index.php/silver-sport-2-wheelchair-969.html ,for this wheelchair,you need to have a person behind the chair or have use of arms to move it. will not move - 24134627-4xvsciucyrxwqvq5ys1rwwmi-1-0.jpg
Posted on Jan 03, 2015
Install new drive belts and mower still wont move forward or reverse.
Belts dont move mower back and forth, there is a bar that engage the hidrolic transfer, perhaps you move it and you have not tracking power, or, there are a series of rods that actuate the hidrolic, coud be that any of those rods came undone, if any of these to scenarios is happening to you, consider have the hidrolics chec out.
Good luck to you.
Jun 27, 2015 | Troy Bilt 175HP Manual 42" Riding Mower
Yamaha kodiak
These atv's are belt driven. If you remove the right side crankcase cover you will see the drive belt as well as the primary and secondary sheaves. When you accelerate, there are weights in the sheave that move making the sheave grip the belt and give it traction. When this happens your drivetrain is powered. Sounds like you either have a worn belt, worn sheaves, or need to service sheave (usually just a good cleaning and re-grease the weights). The easiest thing to do is remove the cover and power the ATV and you can witness the belt engaging with the sheaves and probably will be able to diagnosis from there.
Mar 17, 2014 | Motorcycles
Plymouth acclaim, the power steering went out a week or so started making a noise wen turning or taking off, I noticed the belt had a crack in it, tried to make it home & the belt just shredded apart,...
well as for the tear on the belt the power stering pump is proably not so good enymore if the pully spin with the belt then it no good and when your put the belt back make sure you got it on right if you crank it and the power steering pulley isint moving then your just gonna shred another belt after another
Jan 18, 2013 | Cars & Trucks
1996 Cherokee serpentine belt no moving.
Sounds like you have something locked up.
Take a picture/draw a diagram of serpetine belt routing.
Remove the belt, then try turning each individual item the belt powers to see which one is locked up.
I'd start with the AC Compressor first, then alternator, the belt tensioner, power steering pump, and whatever else is powered by the belt.
Sep 24, 2009 | 1996 Jeep Cherokee Country
15 38 hxl moves slowly, trans won't pull on incline
If the transmission whines, the brake may be sticking. you may have to relocate the brake return spring, to the rear of the flange that the spring is currently attached to
Aug 13, 2009 | Toro Lawn Mower With Toro Power Tools
I can change the serptine belt but i wanna know how do i take out the small belt right next to it,because I dont see a tentioner for that small belt.1998 dodge caravan.
Good day
it sounds like the power streeing pump belt, all you have to do is loose the pivot bolt and then loosen the adjustment bolt and you will be able to move the pump to remove the belt. If you don't know what the pivot or adjustment bolts are look at the pump and you will see bolts just loosen those until the pump moves
hope this helps
Cheers.
Jul 13, 2009 | 1998 Dodge Caravan
Power but no movement
Your belt is either off track or broken. Refer to your manual for routing of a new belt. 20 dollar fix. Good luck.
Apr 16, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Replace the serpentine belt
First note the route of the belt. make a drawing.
Adjustments are made by moving the power steering pump. far right of belt system.
loosen top fixed bolt above center of drive wheel on p/s pump.
loosen bolt below drive wheel on p/s pump.
Push p/s pump to the left to loosen belt.
Remove old belt .replace following route of your drawing.
move p/s pump to right .
top of belt should have 1/2 inch deflection.
tighten bolts
The end
If you dont have belt route mail me at
andymalt61@hotmail.com
for drawing
Good luck .Andy Bartolo
Mar 17, 2009 | 1998 Jeep Cherokee
Belt and auto-tensioner
While installing a used belt just to get the truck home, I discovered that the pulley-bushing on the power steering pump was worn. This allows the pulley to move fore and aft, thus throwing the belt occasionally. What I learned from all of this can be catagorized as very basic troubleshooting. If you lose a belt that looks to be in good shape, then before you replace that belt, check all of your pullies and devices(water pump, alternator, power steering pump, AC, etc.). Look for pullies that can move or wiggle. And, look for lose or missing mounting bolts on the various devices. A loose or missing bolt may allow that device to become cocked at a slight angle, instead of remaining straight and true, thus throwing the belt.
Thanks
jklong, Alaska
Jan 17, 2009 | 1986 Ford Bronco
Drive Medical Silver Sport (2) 18 Wheelchair  Black Logo
93 people viewed this question
Top Drive Medical Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Robin Hill
Robin Hill
Are you a Drive Medical Health and Beauty Expert? Answer questions, earn points and help others
