Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
Blower comes on then stops running
Blower comes on all speeds then goes off, after a while will come back on, then goes off, sounds like i need to replace the motor?
  • Chevrolet Master
  • 1,051 Answers
You may need to replace the fan motor but before you do check and make sure you don't have a loose wire going to the fan motor. You might be loosing power to the fan motor. Is the fan motor making noise before it stops. Chev are famous for having the bearing on the fan motor going out and the fan will clatter against the fan motor housing. If you need to change the motor just remove the wire to the motor and pull the beauty cover off then you can remove the holding screws and put your new motor in. Be sure to remove the battery cable to ensure you don't short something out during the process and burn the wiring.
Posted on Oct 02, 2015
Furance starts, runs short time, blower stops short time, then blower comes on, burner still runniing.
Sounds like you fan limit control is not set properly. Or the blower speed is set to high.
Jan 03, 2014 | Intertherm 56000 Btu Gas Furnace
Heat makes a screaming sound - only comes on when on high, air does not come on at all - A little advice and help needed. THANKS
The screaming sound is the blower motor bearing. the fan speed switch controls the grounding side of fan motor once on high it grounds the high speed fan relay. so lower speeds goes through blower motor resistor. this may be burnt out do to bearing is screaming tight to shaft creating a larger ampere draw that burnt it out.
Nov 13, 2013 | 1997 Chevrolet K1500
Fan for heat turns on and off and sometimes stays off
If it comes and goes on all speeds, I would say its probably the blower motor. You would check for power and ground at the blower motor when it stops running.
If its only on one speed, it may be the blower resistor.
Jan 07, 2013 | 2004 Chevrolet Malibu Maxx
I have a 95 Ford Contour 6 cyl DOHC, we had ice accumulation last night and stated car ealy this morning and defroster worked fine, ran about 15-20 minutes and it was too early to leave so we shut car off....
the fan may have went out. what your feeling is air coming in as you drive. ford trick for fresh air lol. the fan needs to be tested to see if it has stopped working
Jan 20, 2011 | 1995 Ford Contour
2003 chevy avalance a/c blower moter runs with ignition shut off
If you have the automatic climate control and the blower motor won't shut off then you have a failing Blower motor speed control module. Something inside this module goes bad and the result is a blower motor that keeps running at times even though the engine is off and the key is out of the ignition. The module isn't repairable but has to be replaced. I believe it is located behind the passenger side of the dash panel.
Jun 14, 2010 | 2005 Chevrolet Avalanche
Every time i turn my heater or air condioner on it makes a ticking sound then it goes away after a few seconds it sounds like it coming from the inside by the glove box or right below it
Sometimes leaves or debris collect inside the blower motor case Also if the vehicle has alot of miles and the noise changes tones when changing blower motor speeds the motor may be failing or in need of lubrication. First i would check and clean the blower motor case of debris or leaves. This requires removing nthe blower motor and looking in the housing. Good Luck and I Hope this was very helpful.
Oct 23, 2009 | 1999 Chevrolet Silverado 1500
94 eldorado blower quit
This Sounds Like the Blower MOTOR Itself has Failed, But There Is a Relay Located...
LH Electronics Bay Board (behind Panel) (2 Door)...........Also one other Part is The Resistor.......
FRONT BLOWER MOTOR RESISTOR
This vehicle does not use a Front Blower Motor Resistor. The Front Blower Motor speed is regulated by the Front Blower Motor Speed Control which is incorporated into the Front Blower Motor and is not serviced separately.
Aug 19, 2009 | 1994 Cadillac Eldorado
1994 Carrier 58 PAV
sounds like the relay for the unit may be bad, usually if a blower motor goes it stops or has a very loud humm and only goes slow
Aug 03, 2009 | Heating & Cooling
Goodman heatpump
I think your run capacitor for the blower motor needs replacing.
If it goes out the motor will not develop full speed and will shut off on it's internal thermal protector. When it cools off it will kick back in until it gets hot and shuts off again.
The motor may be dragging and have to be replaced, but I would try the capacitor first.
Post back with any questions.
Thanks/Mike
Dec 08, 2007 | Heating & Cooling
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
